Question about Technics SA-DA10 Receiver
SA DA -10
WOW! Thought "someone" would be able to help me out. Still having problems with "overload" showing up, I have disconnected everything, reset the unit, unplugged it, you name it, I have done it. STILL showing "overload"
Can SOMEONE help me out here? PLEASEEEEEEEEE!!!!
I'm having the same problem with the "overload" I have been searching the net looking for an answer. So far I've noticed the fan looks as if it has never came on and this could be causing a temp problem. What I read was take the fan out and tie the wires together so that the receiver thinks there is a fan. Have not tried it yet but I'm checking into a new receiver.
KC
Posted on Apr 11, 2008
    Genius:
  • 1,175 Answers
If all the speakers are connected proper and it still says "Overload!!!!!"
Your output amplifier module is most likely failed.
Posted on Mar 12, 2008
I have a panasonic sa-he70 av control receiver, it is showing on its screen OVERLOAD, SWITHC OFF POWER, i did it twice and still apperas same message. Is my equipment damaged or I just need to reset it?
Page 16 of the manual has recommendations.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Jul 27, 2011 | Panasonic SA-HE70 Receiver
Have recently had an "overload" displayed. Have
HI:
Usually receivers go into overload due to a bad speaker make sure you disconnect the speakers also to make sure its overloading from a bad speaker. If the unit still shows overload even with all speakers disconnected, then your main amplifier output has a short usually a shorted output transistor is the cause. Unplug the speakers one at a time to and turn the unit on after disconnecting one of the speakers , to determine which speaker is at fault.
Jan 23, 2011 | Panasonic SA-HE200 Receiver
DISPLAY SHOWS "OVERLOADED" MESSAGE
Disconnect all speakers at the receiver then turn the unit back on. If it stays on, post a comment and I will walk you thru troubleshooting. If it still shows "overload" it needs to be serviced. Hope this helps
Dec 22, 2009 | Panasonic SA-HE70 Receiver
My receiver (SA-HE70) shows overload on the display, I know that someone probably shorted the speaker wires. How can I fix this or get a service manual for it?
Diusconnect all the speaker wires. Still overloaded? Y= take it in for service. N= isolate which speaker path is causing the problem.
Dec 11, 2009 | Panasonic SA-HE70 Receiver
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
Reciver overload
More than likely, it's not a problem with the receiver. The fastest way to tell is to disconnect all speakers at the back of the receiver and turn it on. If it does not shut down, your receiver is ok and is just protecting itself from damage. If it stays on, check all your wiring, what it sounds like is that you have one or two braids of wire touching the other terminal. Not enough to cause a "short" at turn on, however, when you turn up the volume the resistance increases and creates a short, thus "overload" shows on the receiver. Hope this helps. If you need more help troubleshooting, post a comment and I can help more.
Aug 16, 2009 | Technics SA-DX930 Receiver
Overload displays on the screen
If it say's overload with no speakers connected and the unit on, it needs service. If you need further help, post a comment and I can help you troubleshoot.
Aug 11, 2009 | Panasonic SA-HE70 Receiver
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
Technics SA-DA10 jumps into overload after 10 minutes
Have you tried connecting speakers? What was the result?
Yes, when you turn the volume up on these amps (or when the output gets past a certain level) the cooling fan should automatically come on.
Oct 14, 2008 | Technics SA-DA10 Receiver
Bonilla
Se a tensão das saídas estiverem abaixo de +5 volts então muito provavelmente é um resistor queimado! Tente descobbrir algum resistor queimado que conduz a tensão positiva de +5v sb da fonte(fio violeta) às saídas ps2 e usb, ou ligar um resistor de 10 ohms da saída da fonte(+5v sb) ao +5v(fio vermelho) das saídas usb frontais na placa ou em qualquer outro lugar disponível.A tensão baixa não permite que o teclado seja reconhecido no início.
Boa sorte
Moisés.
Eu queimei o resistor da minha placa quando conectei um maldito mouse novinho da clone!
Aug 29, 2008 | MSI : P4MAM2-V (7095-010)...
Technics SA-DA10 Receiver Logo
265 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
