Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Dish washer leaking
My Kenmore dish washer is leaking around the motor area
  • hudson2610 Sep 01, 2008
    my dishwasher is leaking water in the motor area
I called a repair man...
Posted on Mar 09, 2008
Kenmore model #16761691 leaking at the bottom of the door. Where is the gasket located? Or is it another problem?
does it leak all the time or did it just start?try running it with nothing in it and see if it leaks,if the dishes were racked wrong the water can get deflected and leak out through the door,also,remove the bottom rack,look at the screws going around the bottom part under the wash arm,if any of those are loose it causes a wave in the dish washer and the water leaks from under the door.if it's leaking from one of the corners the gasket could be bad
Apr 17, 2011 | Kenmore Dishwashers
Water leaking from under washing machine. Took off cover. Hoses ans water pump look good. Seems water is leaking on spin cycle above the transmission.
90% of the time the water leaks from either the drain pump module or motor, or through the centre seal and bearing.Couple of not so common areas are the various pipes:small holes in the drum:the soap dish etc. Possibly remove the lid and place the washer on 4 bricks and then run the machine so you can pinpoint the area.
May 20, 2010 | Washing Machines
Did not drain last night
how much water? there should always be at least an inch to 1&1/2 inches in bottom to keep seal at top of motor wet if seal drys out thern washer will leak around motor.if alott more than what i wrote then check float valve if it is sticking then see if anything is under it l/e a fork or something that may be keeping the float from dropping down to the proper draln level
Dec 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Leaking oil
The transmission or, gear box housing is compromised. it has cracked for some reason. you will need to replace the transmission in this case.
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore under counter ultra wash dishwasher model 665.15825691 has started leaking at the lower corners of the door. The leaks seem to occur during the final rinse while the water is being heated. I...
Happened on my dish washer too. Remove lower rack, remove lower spray arm by removing the center plastic nut, check screws (torx) on outside edge of pump. Tighten these as necessary, mine were loose causing water to spray forward against the tub causing leakage.
Jun 27, 2009 | Kenmore Dishwashers
Dishes not rinsing well,
I would check the bottom drain area. Sometimes food can stay down there and block the drain or get back around onto the next load.
Apr 06, 2009 | Kenmore Dishwashers
Kenmore series 80 washer leaking.
about the #1 leak on ken more/whirlpool washers are the pump.it is in the frount middle.you can dry up around washer and slide news paper under it then run load.that will narrow your surch area unless just over filling thats another matter.God bless,tom
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Leaks water onto floor in front of washer after spin cycle, help
open the door though, put your hand around the rubber boot assy, run *** all around looking for small tears, and or holes, if so replace it. only other thing to do is remove the lower access panel and watch it spin a load and youll be able to detect where te waters coming from
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
Dish washer door leaks
This sounds like a case of the water rising too high in the machine. If your unit has a float to control the water level (located in the wash area), it is likely stuck. Free it by letting water into the machine and then exercising it to get the 'goo' out. If it has a pressure switch located in the motor area, clean out the line.
Feb 10, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
113 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
