Question about RCA P46812BL 46" Rear Projection Television
Picture distorted I have a RCa P46812BL with a distorted picture (scrambled picture). Any advice/solution would be appreciated, is it worth repairing??
  • puterguy May 11, 2010
    What exactly does scrambled mean? Can you be more specific?
  • RCA Master
  • 3,459 Answers
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Picture distorted - bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on May 30, 2010
T-Con Board failure symptoms?
No picture but backlights, blue screen, scrambled picture, distorted picture to name a few
Apr 04, 2018 | Televison & Video
Convergence
sounds like the problem my fisher 40" was having.
start by giving all of the circuit boards a very thorough cleaning, you can pick up crc qd electronic cleaner at autozone and other local stores. just make sure whatever you use is plastic safe, and you can use a soft bristle toothbrush to clean out any persistent crud. after everything is thoroughly clean and dry, test it.
if it doesn't work pick up a can of freeze spray from a local supplier, let the tv warm up, then use the spray to cool the components on the convergence board. see if the problem disappears. if this doesn't help, do the same to the power board.
if this does work, identify the component that is overheating and replace it.
if it doesn't work, check for dry solder joints (tedious process but worth it). this was the issue on my tv, am in the process of fixing it right now.
if you are still having the issue at this point, do a visual inspection for any capacitors that look like they have leaked or are discolored, test and replace any that are bad. do the same for other components.
this problem is more often than not caused by the convergence board or the power board, unfortunately for me and you both, i haven't been able to find a supplier of either board for my tv or yours.
hope this helps,
trin
Nov 18, 2007 | RCA P46812BL 46" Rear Projection...
The sound stopped working on rca projection TV
FBT flyback transfomer and hori output transistor
Jan 01, 2010 | RCA P46812BL 46" Rear Projection...
Sony KV-32XB25 Distorted Picture
In most of the case, the problem is a defective LCD panel, if is it, there is not worth to fix.
Aug 02, 2017 | Sony KV-32XBR250 TV
W2606c picture scrambled
Um...well when mine does that i unplug it and hold the power button for ten seconds and then plug it back in. Always works for me ;-) hope it works for u.
Aug 19, 2008 | Dell W2606C 26 in. HD-Ready LCD Television
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA Projection TV
that would be the inverter board, supplies power to the bulb, you would need to replace this part, but don't touch the board without wearing rubber gloves, as it can store a lot of voltage when they fail . when you get the board out discharge the capacitors to make it safe. cross the live and negative on the capacitors.
Jul 08, 2017 | RCA Televison & Video
Mitsubishi WE-52525
. Suspect the FMT PCB part # 930B924002 when set is warm.
Jul 31, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
91 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
