Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Phillips 60pp9202 60 in
Green half oval shape on bottom of screen
  • 4 more comments
  • jtgeorgatos Apr 22, 2008
    phillips 60pp9202 60 , green and pink outline oval around the bottom of screen, but now wont even turn on
  • methodites May 09, 2008
    same issue here also.
  • negron1507 Sep 01, 2008
    phillips model 60PP9202/17F, 60in , green and pink outline oval around the bottom and top of screen, and the picture seems to be double as if watching 3D without the special glasses.
    I have changed the surge protector, I have unplugged the cord for 2 days, tried diferrent wall receptacle and problem remains.
  • Anonymous Sep 02, 2008
    3d picture
  • danzerjen1 Mar 12, 2009
    same here, now it will not cut on, but i can hear it turning on and off over and over again
  • Anonymous Mar 27, 2009
    Well, it just cost me $69.95 to place a trouble call and $380.00 to have it fixed and 90 days labor warranty. With a little more I could have bought me a LCD or HDTV flat panel 42 inches +
I need a replacement removeable protection sreen
Posted on Mar 17, 2009
  • Philips Master
  • 3,459 Answers
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problphillips 60pp9202 60 in - 2c07611.pngbr />2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 15, 2009
  • 138 Answers
If the it is bowed in the probleis the convergence IC'S and the part number is 90035
932212344682 and contact www.andrews.com for a price.Get a service tech toinstallit.
Posted on Aug 19, 2008
How to put the blade into the black and decker 3.4 amp powered handsaw
#1) You have to locate the blade release button on the saw (see your manual). The opposite side of the release button is a screw-like OVAL shaped PIN. To insert the blade, the direction( or position) of this OVAL shaped PIN has to match the OVAL shaped hole in the blade. You could use a screw driver to change the direction/position of this OVAL shaped pin. You have to push down the release button when you use the screw driver to turn.
#2) Hold the blade in Vertical position in your right hand. The "Oval" hole is on top. The teeth is facing your left hand. You will see that the "oval" hole on the top of the blade is a "horizontal" oval.
#3) Hold the saw (handle) in your left hand as if you were going to saw using your left hand.
Now peek through the hole of the saw and find the direction of the OVAL PIN. It has to be a "horizontal" (or lied down) OVAL. If it is not, use the screw driver to adjust it.
#4) Hold the blade using your right hand. Oval hole on top, teeth facing your left hand. Insert
the blade from the bottom of the saw. What you needed to do is to insert the PIN into the hole
of the blade. When you inserted the pin into the hole of the blade, slowly turned the blade upward, the blade will lock by itself.
Oct 15, 2013 | Black & Decker PHS550B Powered Handsaw...
My hitachi 55" ultravision hdtv has a green pear shaped color on the screen, only when it has a dark background, other than that no distortion, no blueing in the corner, no blurriness, nothing. What i
Damaged Optical light engine, this is not the only Hitachi with this problem the ones before the oval was red and was finally settled two years ago in a class action lawsuit.
Dec 15, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
Rival 3745 4.5 qt. (with ivy leaves) need stoneware liner
I have both parts if anyone is still looking
Apr 09, 2012 | Rival 3745 4.5-Quart
How do you adjust the headlights for a 2011 Nissan Altima?
2011 Altima adjustment screw is inside the oval shaped hole by where the headlight assembly attaches at the top of the fender support. If you look in the hole you will see a green plastic adjustment screw. Use a #2 Phillips head screwdriver.
Feb 29, 2012 | Cars & Trucks
The blue is oval shape drawn upward on the bottom and oval shape drawn on the top middle
YOU HAVE CONVERGENCE PROBLEM. you need to have an electronic technition replace convergence ics and related resistors and pico fuse. J.D.W.
Jun 25, 2010 | Samsung HCM5525W 55" Rear Projection...
While watching tv half the screen goes black
Download software from the Phillips web site. Use a usb flashdrive to transfer the download to the TV. This worked well for us and our picture is better than ever.
Apr 09, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Fuzzy picture, oval shaped, scrolling up slowly
I would start by checking the large filter capacitors in the power supply. I can't be sure since I'm not seeing the set, but it sounds like you're describing AC ripple. In a 20-year-old set, some of those electrolytics will be drying out. A few replacements may take care of the trouble for you.
Jan 01, 2009 | Panasonic PT-56WXF95 56" Rear Projection...
Blue Half-oval on screen
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
Feb 12, 2008 | Hitachi 51F510 51" Rear Projection...
Oval shaped picture problem with Mitsubishi WS55807
Self test: Turn on and Press the input and menu buttons on front panel together and hold for 5 sec. after 5 sec the power LED will blink a 2 digit seq. This will let you know what error code. Count the first blinks then a short pause then the second blinks. Example 2-3, 3-4, 4-1. Let us know what it is
Nov 21, 2007 | Mitsubishi WS-55807 TV
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
308 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
