Cannot go on line
I cannot go to the web site . I tried to optimize the browser, ip address is correct , were able to get reply to modem and web site, two of our computers works fine except this one
  • Preeti Mekala May 11, 2010
    Please check your firewall settings on this computer, in case you are using an anti virus software and the windows fire wall is turned on please diable both of them and then try to connect to the website and see if it works. Please get back in case the issue is not resolved.
  • Anonymous Mar 13, 2014
    web browser wont load ip address
  • 148 Answers
Is it only website you cannot go to ? or can you not connect to the internet at all ? What system are you using desktop/laptop? connecting via modem? router? dial up? wireless or ethernet ? Was this computer on the internet before and now will not connect, or is this the first time setting up connection?
Posted on Mar 08, 2008
How do i set up td-w8968
Configuring the PC
After you directly connect your PC to the modem router or connect your adapter to a Hub/Switch which has connected to the modem router, you need to configure your PC's IP address. Follow the steps below to configure it.
Step 1: Click the Start menu on your desktop, right click My Network Places, and then select Properties (shown in Figure 3-1).
2q==
Figure 3-1
Step 2: Right click Local Area Connection (LAN), and then select Properties.
swdfx3buhbuq8vtnw4buabext2fny6dn2yb3j8q11lqaa7caob5uowhnnroyklp8j49rogds1dhcra0pr2tkhnrwpxy9rwuva1si2takep29ra9ra4za1ud8vb3sawtr4nrnchs9zi6jyqads=Figure 3-2
Step 3: Select General tab, highlight Internet Protocol (TCP/IP), and then click the Properties button.
z
Figure 3-3
11
TD-W8968 300Mbps Wireless N USB ADSL2+ Modem Router User Guide Step 4: Configure the IP address as Figure 3-4 shows. After that, click OK.
2q==
Figure 3-4
IV' Note:
You can configure the PC to get an IP address automatically, select "Obtain an IP address automatically" and "Obtain DNS server address automatically" in the screen above.
Now, you can run the Ping command in the command prompt to verify the network connection. Please click the Start menu on your desktop, select run tab, type cmd or command in the field and press Enter. Type ping 192.168.1.1 on the next screen, and then press Enter.
If the result displayed is similar to the screen below, the connection between your PC and the modem router has been established.
z
Figure 3-5
12
i6omp5ex15+rw8zpt9gfv8vj5wpx8vvf6aaou6udwyj+bcbnckcjqlmkhemu0nmjjymslggvq3jjbwglgjydhcbxjwwpikyg9kfyzjqxllypyymxgeqznhtnzgqh5sydantn5+hwad6hmakstnizatkntp1cjsp1ktarvq1izat3k9aoapwddih1ltqzzs2hpjgaaow==w858adahab0rqghr0oahnqeixslaemvshei2orcdk0ypa9kimdshgn8rrjnr0oxunaga7kjv1gqiaow==If the result displayed is similar to the screen shown below, it means that your PC has not connected to the modem router.
2q==
Figure 3-6
You can check it following the steps below:
1) Is the connection between your PC and the modem router correct?
The LEDs of LAN port which you link to the device and the LEDs on your PC's adapter should be lit.
2) Is the TCP/IP configuration for your PC correct?
If the Router's IP address is 192.168.1.1, your PC's IP address must be within the range of 192.168.1.2 ~ 192.168.1.254.
3.2 Quick Installation Guide
With a Web-based utility, it is easy to configure and manage the TD-W8968 300Mbps Wireless N USB ADSL2+ Modem Router. The Web-based utility can be used on any Windows, Macintosh or UNIX OS with a Web browser, such as Microsoft Internet Explorer, Mozilla Firefox or Apple Safari.
1. To access the configuration utility, open a web-browser and type the default address http://192.168.1.1 in the address field of the browser.
z
Figure 3-7
After a moment, a login window will appear, similar to the Figure 3-8. Enter admin for the User Name and Password, both in lower case letters. Then click the OK button or press the Enter key.
mfvwnrkduldggaow==w858adahab0rqghr0oahnqeixslaemvshei2orcdk0ypa9kimdshgn8rrjnr0oxunaga7bgeabherbheibhezbhfebhfvbhfmbhf3bhgibhgzbhgqbhg7bhhmbhha7hgaaaow==
png;base64,r0lgodlhhwauahcamsh+glnvznr3yxjloibnawnyb3nvznqgt2zmawnlach5baeaaaaalamabqaqaaoahaaaaaaaaagdaaqidq0kcamaawgkdq0lcwaaawsgawadbaqdaamebasgcaoldqmdcaskcagdawmgcwsldqecawecawecawecawecawecawecawecawecawecawecawecawvaiaacwiceileyihmy6cggbbioc4wmzao0dpiu9yd4wixuiwjqszddhatgpalphmeeeptpbifwghancz9e8xkqaga7Figure 3-8
(V' Note:
  1. Do not mix up the user name and password with your ADSL account user name and password which are needed for PPP connections.
  2. If the above screen does not pop up, it means that your Web-browser has been set to a proxy. Go to Tools menu-Internet Options-Connections-LAN Settings, in the screen that appears, cancel the Using Proxy checkbox, and click OK to finish it.
Aug 19, 2014 | TP-Link Technologies TP-LINK TD-W8968 -...
I have no internet connection when i connect my adsl router with enhwi g2 router in WAN, then from lan1 connect my pc. Please solve my problem. Tnx
First test to see that you can connect to the Internet by connecting directly to the modem.
If yes, then check that the cables are connected correctly and that the LEDs are on. (Just a check :). Telephone line to LINE IN on modem then Ethernet/Cat 5 from LAN port on modem to WAN port on Encore router, then Ethernet/Cat 5 cable from LAN port on router to PC.)
Use browser (Internet Explorer, Safari, Mozilla) to connect to web interface of router (make sure your TCP/IP settings on PC are set to obtain IP address using DHCP).
Open browser and type in the IP Address of the router (192.168.1.1 is the default) where you usually type in the name of the website you want to go.
Go to the LAN Interface Setup page (you are now inside your router).
Change the IP Address from 192.168.1.1 to 192.168.89.1 (leave the subnet mask as it is).
Change the DHCP Client Range from 192.168.1.100 - 192.168.1.200 (the default) to 192.168.89.100 - 192.168.89.200.
Click on Apply Changes button.You may lose connectivity to the router, but you can reconnect by typing in the new IP Address 192.168.89.1. You may need to renew the IP address of the PC, but that can be easily done by rebooting the system if it doesn't happen automatically.
Let me know how you go, or leave a message if you still can't connect. I would ask that you tell me the model of the ADSL modem however.
Cheers
Dec 17, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
Wireless router was working now its not, now light showing wireless on the router, I have internet if i plug in derectly to the modem
Jus Powercycle the Whole N/w
Unplug Modem and Router
Plug Modem First and then Router
Check Wired Internet to Router if that Works, wireless will be Online
Oct 01, 2010 | Linksys Wireless-N WRT150N Router
Dell pc wont pick up internet
There are wide issues that may occur, with a issue with "dell pc wont pick up internet" is very general, so please be specific, however i went over most issue step by step, hope this help
Make sure you have the correct IP scheme for your network. This would include the:
IP Address
Subnet Mask
Default Gateway
DNS Servers
Click on start, run, type in cmd, The run IPCONFIG /ALL. A sample where a router is used is in the following graphic.
IP Address:
If you have a router, common examples would be:
192.168.0.x, 192.168.1.x or 10.0.0.x
If you are directly connect to your DSL or Cable Modem, you should have an IP address that would correspond to something from your ISP.
What you don't want to have is something like 169.254.x.x. This means you are not getting and IP address assigned and needs to be resolved first.
Subnet Mask:
Also make sure you have the correct Subnet Mask. Most commonly this would be 255.255.255.0
DNS Servers:
Make sure you have the correct DNS Servers.
Sometimes this is the IP address of your router, so it would be the same as the Gateway IP.
Sometimes (as in this example), it is the actual DNS servers used by the ISP.
Possible causes for not getting an IP address assigned are:
1. Defective cable, network card or port on the router. Make sure you are using all known working components.
2. Your router is not configured for DHCP (which would automatically be assigning IP addresses).
This and can be done from that same command prompt you used to run IPCONFIG
2. Try pinging the router's IP address
e.g. ping 192.168.1.1
If you get a reply, then your connection to the router is working.
If you don't get a reply, then you need to double check your network card, cable, port on the router. You might also see if any other computers on the network can do the same.
3. Try pinging an external site by IP address
e.g. ping 4.2.2.1
If you get a reply, then you have a connection to the Internet.
If you don't get a reply, there are several things you can try:
1. Double check that the router is connecting to the Internet. Typically you can access the router through your web browser and check it's status.
2. Take the power off your DSL/Cable modem and Router. Plug the modem back in a wait a minute or so. Plug the router back in and wait a minute or so. Then restart your computer.
3. WINSOCK Fix - It is possible that the WINSOCK Registry entries have gotten corrupted. This is getting to be a more common problem. See WINSOCK FIX for clean ones you can download
4. Try pinging an external site by Name
e.g. ping www.yahoo.com
If you get a reply, then you have a connection to the Internet and DNS is working
1. Double check your DNS entries
2. You many need to use the same DNS IP address that your ISP or Router is using.
3. On rare occasions your ISP has problems with their DNS servers. But that is rare in comparison to misconfigured computers.
If your PING tests work but you are having problems browsing sites on the Internet
1. If you could ping external sites by both IP address and Name, but cannot browse the web, likely your web browser is misconfigured.
2. Double check that you don't have an incorrect or not needed Proxy server assigned.
For the Internet Explorer - Tools / Internet Options / Connections tab / LAN settings button. Uncheck both Automatically detect settings and Use a proxy server for your LAN.
Jun 18, 2010 | Dell Inspiron 1545 Notebook
Trying to reconfigure the router and a message comes up "unable to connect to router" I've done all the steps even reset to factory settings.
If you've tried reseting it, then the IP address is probably one of the following:
192.168.1.1
192.168.0.1
If you know how, try to ping the router via command prompt. You can do this by going to:
Start Menu>Run
then type
cmd
A black window will appear, try typing:
ping [one of the IP addresses above]
if nothing "replies" then you have a bad connection. If one of them does reply.
Try typing that IP address into the browser address bar to bring up the routers web interface.
If it's a linksys, try this for the username and password
Username: admin
Password: admin
for Netgear:
Username: admin
Password: password
Apr 03, 2010 | Linksys Wireless-G Broadband Router
Internet connection problems
Troubleshooting Internet Connection Problems The purpose of this section is to give general tips
on troubleshooting your Internet Connection
While there are many possible configurations, I'll try and cover the most common ones.
Making Sure You Have Correct IP Information
Basic PING Tests
Browser Configuration
Making Sure You Have Correct IP Information 1. Make sure you have the correct IP scheme for your network. This would include the:
  • IP Address
  • Subnet Mask
  • Default Gateway
  • DNS Servers
2. There are a few ways you can see what IP addresses are being assigned.
But generally for:Win9x - Start / Run / command
Windows2000/XP/Vista - Start / Run / cmd
ipconfig.jpg 3. IP Address:
192.168.0.x, 192.168.1.x or 10.0.0.xIf you are directly connect to your DSL or Cable Modem, you should have an IP address that would correspond to something from your ISP.
4. Subnet Mask:
Also make sure you have the correct Subnet Mask. Most commonly this would be 255.255.255.0 5. Default Gateway:
Make sure you have the correct Default Gateway IP address.
With a router, this is typically the IP address of your router. 6. DNS Servers:
Make sure you have the correct DNS Servers. Sometimes this is the IP address of your router, so it would be the same as the Gateway IP.
7. Possible causes for not getting an IP address assigned are:1. Defective cable, network card or port on the router. Make sure you are using all known working components.
But you need to have this correct before proceeding.
Basic PING Tests 1. This and can be done from that same command prompt you used to run IPCONFIG 2. Try pinging the router's IP addresse.g. ping 192.168.1.1
3. Try pinging an external site by IP address e.g. ping 4.2.2.1
3. Winsock Fix - It is possible that the Winsock Registry entries have gotten corrupted. This is getting to be a more common problem. See WINSOCK FIX for clean ones you can download
4. Try pinging an external site by Namee.g. ping www.yahoo.com
If your PING tests work but you are having problems browsing sites on the Internet 1. If you could ping external sites by both IP address and Name, but cannot browse the web, likely your web browser is misconfigured. 2. Double check that you don't have an incorrect or not needed Proxy server assigned.For the Internet Explorer - Tools / Internet Options / Connections tab / LAN settings button. Uncheck both Automatically detect settings and Use a proxy server for your LAN.
Mar 28, 2010 | HP Pavilion dv9720us Notebook
How do I log in to a motorola cable modem??
Depending on what model of "modem" you have you may not be able to. If the Motorola unit is just a modem (not a gateway) then you can't, and you don't need to. There is nothing that needs to be configured in a modem.
If the "modem" is a gateway (a modem and router in one physical unit) then you need to open a browser (Internet Explorer) and enter in the IP of the router. For example, http://192.168.1.1. Depending on the model of the unit, that IP address (the numbers) may be different that what I typed. You can determine what IP address it is by looking at the product documentation, or double-clicking on your network connection icon in Windows and reading the "Default Gateway" address.
Once you get the correct IP address entered into the browser, the page for the web interface will load. That is where you can configure it.
Jan 18, 2010 | Linksys EtherFast 10/100 16-Port Workgroup...
Pc desktop
after you format your computer u need to install the drivers for your internet.....install the driver for your network and u can go live
Mar 08, 2008 | Computers & Internet
Netgear wpn824x2 Router
The pc will have to have the ip address changed as the router will give a different one to your old modem. open up your web browser and go to tools, internet options and see browsing history, click on delete and delete all temp internet files and history, then click the connections tab and ensure that your modem is showing as the default dial up or if its a modem router ensure never dial a connection is ticked. go to your network card properties in network connections and on the TCP/IP line click properties again and ensure obtain an ip address is ticked, click ok, then restart pc. When rebooted, open web browser and refresh a few times, you should then be on the net.
Oct 01, 2007 | NetGear RangeMax WPN824 Router
Computers & Internet Logo
Alun Cox
David Payne
David Payne
