Question about Nintendo Wii Console
Wii sensor bar
The Wii sensor bar does not seem to maintain a continuous connection to the Wii remotes. As soon as you aim your Wii remote off of the TV screen and them try to come back to the screen, the connection is interrupted and contact is lost. Is the sensor bar malfunctional?
  • 3 more comments
  • fixyafreakin Apr 26, 2008
    my sensor bar has been chewed by my cat and i've tried to get another but it does not work.What should i do
  • Anonymous Aug 29, 2008
    when turning on wii remote lights up but there is no connection or contact to the controllers..
  • 4rebeln8 Dec 15, 2008
    I keep getting "Communications with the Wii remote have been interupted. Without touching the Control Stick on the Nunchuk, Press A"
  • janetrenk Dec 16, 2008
    what could be wrong with the wii itloads the game but when you go to play a game it isnt sending the message to the system so that you can bowl or anything else
  • Anonymous Mar 17, 2014
    i connected it to another TV and I'm trying to connect it back to my TV. I don't know how they did it
Check the supply voltage to the Wii sensor bar with a multi-meter. You should get 12V across the two pins. My Wii sometimes stops outputting 12V so the sensor bar IR LEDs won't light up as can only be seen on a camera LCD screen such as your cellphone's.
Posted on Sep 10, 2008
Use two candles
Posted on Aug 31, 2008
I got the same problem. I've tried everything in this planet. Wha can I do? please help me
Posted on Aug 18, 2008
    Problem Solver:
  • 10 Answers
Possibly, or low batteries in the remote. Try placing the bar under the tv if its above at the moment, or vice versa if currently below. Also make sure sensor bar overhangs tv slightly too...
Posted on Mar 09, 2008
Cant get the cursor to show on screen
Make sure that your Sensor Bar is connected properly and that there is no damage to the wire connect it to the Wii.
You may have to place the Sensor Bar else where and reconfigure it to work again.
Ref: http://www.nintendo.com/consumer/systems/wii/en_na/ht_system.jsp
-Connect the Sensor Bar under Wii Console in the left menu.
Dec 19, 2012 | Nintendo Wii Console
How do you re-align a Wii remote?
To Adjust the Wii Remote Pointer Sensitivity, follow these steps..
Wii
  1. Access System Settings.
  2. Select "Sensor Bar."
  3. Select "Sensitivity."
  4. Aim the Wii Remote at the television.
  5. Use the + and - buttons on the Wii Remote to adjust sensitivity until only two blinking lights appear.
  6. Press the A button when done.
Wii U
  1. From the Wii U Menu, select "System Settings."
  2. Using the Left Stick, scroll to the "Wii Remote and Sensor Bar" icon and press the A Button.
  3. Select "Adjust Wii Remote Pointer Sensitivity."
  4. Tap "Next."
  5. Point the Wii Remote at the sensor bar and press the A Button.
  6. With the Wii Remote pointed at the sensor bar, press the - and + Buttons to adjust the sensitivity so that only two white dots are visible in the black window.
  7. When you are finished, press the A Button.
  8. On the Wii U GamePad screen tap "OK."
Please
Dec 14, 2017 | Nintendo Wii Console
We recently had a power outage. After this, the Wii console power light would not come on. I unplugged the power supply adaptor on both sides, left it 2 minutes, and plugged back in. Now, the Wii console...
The best solution would be to just move the sensor bar to the top of your TV. Then you could change the settings back to the bottom and move your sensor bar back. If that is not an option, just try your best to get back to the settings to change it back.
May 01, 2011 | Video Game Consoles & Games
Bought nintendo wii last xmas and had played quite frequently. then after a break in play of a few mths the remote controls dont seem to be being picked up by the sensor. i chenged the batteries and still...
Hello there
Hold the Wii Remote upside-down with the buttons facing downward.
Tap the remote firmly against the palm of your hand three times to remove any dust sitting between the buttons and the electronic circuit board inside the remote.
Turn the remote upright and press one of the buttons. If the problem continues, Open your Wii Remote's battery door
Check that your Wii Remote contains two new "AA" batteries or a charged battery pack. Check that no corrosion is present on the battery's metal elements/connectors.
Use a cotton swab to clean the remote's battery element/connectors if corrosion is present.
Check that the Sensor Bar cable is inserted firmly into the back of your Wii gaming system. The Sensor Bar needs to be centered above or below your television so the Wii Remote can transmit signals to the gaming system.
Stand three feet away from the Wii gaming system/Sensor Bar.
Aim the remote and press any button to test the device.
If the remote is not working, stand five to 10 feet away from the gaming system and try the device. The Wii Remote works best three to 10 feet away from the gaming system/Sensor Bar.
Move any objects blocking the signal from the remote to the gaming system/Sensor bar--candles, other remote controls (TV/cable box) and wireless computer devices/cellular phones.
Also, if any sunlight is coming in through a window, close the curtains or blinds to keep the light from interfering with the remote's signal.
Turn off and unplug your Wii gaming system. Leave the unit unplugged for one minute. Plug the gaming system back in.
If the remote still aint working;
Turn the Wii system on. Press and hold the red "SYNC" button for 15 seconds when the "Health and Safety" screen appears on your television. The "SYNC" button is behind the small door on the front of your Wii unit.
Release the "SYNC" button. Remove the battery cover and batteries/battery pack from the back of your Wii Remote.
Press and release the red button located under the battery compartment. The blue lights on the front of the remote will blink
Press and release the "SYNC" button on the front of your Wii gaming system. The "Player" light on the gaming system stops blinking and stays on, the resetting process is complete
Oct 01, 2010 | Nintendo Wii Console
The 'hand' on screen
Make sure that the Sensor Bar is setup correctly:
Check the cord on the Sensor Bar for any frayed wires or kinks, and verify that the Sensor Bar is free of obstructions.
Verify that the Wii Remote is being used between 3 and 8 feet directly in front of the TV, and that the Sensor Bar is placed properly (see Sensor Bar setup).
Verify that there are no bright light sources, including sunlight, behind or near the TV, shining towards the Wii Remote or reflecting off the TV screen. Also verify there are no heat sources (such as electric, propane or kerosene heaters, flames from fireplaces or candles, stoves, etc.). If there are bright lights shinning directly behind the TV or on the screen, turn the lights off.
If problem persist your Wii Remote need service.
Oct 21, 2009 | Nintendo Wii Console
Sensor bar inactivity on the wii videogame system
First you Should test with another sensor bar...try to take it from a friend to test it in your system...could be cracked wires from the sensor bar....try to test the wires with a multimeter and resolder the wires from the cable...or you can take your sensor bar and test it in another wii...you need to known if its really bad ,or if there is something wrong with your wii system...
Sep 09, 2009 | Nintendo Mini Wireless Sensor Bar for Wii
Wii remote
Is your sensor bar connected to the Wii? Check the sensor bar cable for cuts or severe bends (like a V shape) as they might cause the detection problems with the Wii-mote. A cheap fix is to put lit candles in front of your TV and see if the Wii-mote picks it up then.
Jul 27, 2009 | Nintendo Wii Console
No connection from remote to screen
Your sensor bar is definitely burned out, you can get a new wireless one at wal-mart for $20. Often wii sensor bars burn out because people put it directly on the tv instead of using the stand, the tv gets hot and the LED lights in the sensor bar burn out. If you want make sure that it's the sensor bar that's broken, get a video camera and video tape the sensor bar while it's plugged in and the wii is on, if you can't see four LED lights on each side then it's broken.
Jun 14, 2009 | Nintendo Wii Console
We moved our Wii to another location and a new TV and now the remotes point and click is inaccurate and we cannot easily aim at all. I thought it was the bar sensitivity but I think that's fine. Any ideas?
Cursor is off-center, jerky, erratic, disappears, etc.
  • Verify that the Wii Remote's pointer lens is free of obstructions and contamination (stickers, heavy smudges, etc.). The pointer lens is the tinted rectangle at the end of the Wii Remote. If the Wii Remote Jacket is being used, verify that it's securely in place on the Wii Remote. If the Wii Remote Jacket is askew, it might be partially blocking the infra-red sensor on the front of the Wii Remote.
  • Try a new set of batteries. Occasionally weak batteries can cause this type of behavior.
  • Reset the Wii Remote:
    1. Take the batteries out of the Wii Remote, wait for one (1) minute, and then re-insert them. (How to)
    2. Wait a few seconds before pressing any buttons to wake up the Wii Remote.
    3. Re-sync the Wii Remote by using the steps listed above in the white box titled "Try these steps!".
  • Check the Directional Sensor Functionality by holding the Wii Remote with the button side down. Without using much force, tap the button side of the remote against the palm of your other hand. Doing this does not take a lot of force, so be sure not to tap the Wii Remote very hard.
  • Verify Sensitivity Setting dots:
    Go to the Sensor Bar's sensitivity setting in the Wii menu (click here for directions on accessing this feature).
    • If only one or no dots appear on the sensitivity screen, there is likely a problem with the Sensor Bar. Please click here for repair information.
    • If there are more than two dots, then it appears there is an additional light or infrared heat source being picked up by the Wii Remote. Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
    • If both dots appear and the erratic behavior continues even when you move closer to the TV, there is likely a problem with the Wii Remote and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further
Nov 27, 2008 | Nintendo Wii Console
Wii
(1)
Verify that the cable bar sensor is plugged into the back of the Wii console and that the sensor bar is properly aligned with the centre of your TV screen.
(2)
Check that the Wii remote is synchronized with the console using the POWER button on the remote control to turn on the Wii console. (The POWER button is the white button with the red symbol which is located in the upper left corner on the Wii remote.) If it does not work, try to synchronize the remote control, then turn the console and controls that respond correctly to commands.
(3)
Verify that the distance between the Wii remote and the TV display to be between 1 and 3 meters, that there are sources of intense light that can interfere with the proper functioning of the remote (read Guidelines game for Wii for more information ) And that the sensor bar is placed correctly (see Setting up the sensor bar). Avoid the presence of sources of infrared light as electric stoves, gas propane or kerosene, candles, fireplaces, stoves or other heat sources close to the console.
If the steps described above do not solve the problem, the sensor bar could have a problem. Read the following instructions:
On each side of the sensor bar are five infrared lights that located the position of the Wii remote. If these lights do not work, the cursor on the remote will not appear on the screen and you can not step through screens of settings. To see these lights, you must look on the LCD screen of a digital camera or a mobile phone. Verify that the sensor bar is connected and that the Wii console is turned on, and then framing the bar sensor so that it appears on LCD camera or cellphone. If you see five infrared lights on each side, the sensor bar works. Maybe you'll need to slightly adjust the position / tilt the camera or the telephone, but is rather easy to see these lights on the LCD screen
Jun 22, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
418 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
