2002 WS-65908. Timer light is blinking. Set won`t turn on. Eletric co. having problems. Power on/off.
  • 8,617 Answers
That model has had some issues with bad capacitors on the DM board going bad. Does the LED blink constantly?
Posted on Mar 08, 2008
  • Sonny Berry
    Sonny Berry Mar 08, 2008
    There are 4 1000uf capacitors grouped tightly together on the DM board some models have 7 they. replace those capacitors with some available at radio shack and that should solve your problem. If you need more info let me know
The on/off relay does not stay engaged
Based on model number listed here:
If set powers up and green light comes on and goes out a few seconds later:
Press and hold menu and input (source) buttons at same time on the front of the set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks, 2 blinks, pause and repeat it for a total of five times.
If the set has been unplugged you will have to plug it in and turn it on letting it fail (unplugging will clear all errors).
Let me know error code and I will explain--2,2 is most common and most easy one to fix.
Jun 12, 2012 | Mitsubishi WS-65908 TV
Green timer light won't stop flashing on mitsubishi ws 73711.
the green light blinking is normal if set has been unplugged--when set is plugged back it should blink for about 70 seconds and then go out--then you can try to turn it on---it is the DM unit inside the set booting up.
If the light just blinks and never stops you have likely bad caps in the DM unit---there are kits available for that.
The other possible reason is that so called reset switch may be bad--fairly easy way to find that out and it is more common than you would think, let me know if you have questions.
SD TECH
May 06, 2012 | Mitsubishi WS-73711 73" Rear Projection...
Mitsubishi WS-65908 will not stay on
Its a color convergence problem from description:
If green light comes on for a few seconds and goes off:
On the front of the set (not the remote) press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and release both.
Watch power light: it will blink a two digit error code, in your case I suspect it will be 2 blinks, 2 blinks and repeat several times.
Let me know error code and I will help.
Apr 16, 2012 | Televison & Video
The Mitsubishi Diamond Series WS-65908 does not power up. The troubleshooting code is 2-4
1blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
If it is 2,4 you have a problem in the vertical circuit and I would suggest you first look for any signs of glycol there.
Let me know if you need more information.
SD TECH
Oct 01, 2011 | Mitsubishi WS-65511 65" Rear Projection...
I have a WS 65908........it has the same problum--listed on this site.......power on for 3 seconds...and it said this.... Do the self test this model has: When set shuts off and on front of set power...
Error code 23 on this set means that the Horizontal Deflection circuit of the set has failed. Usually this points to a damaged Horizontal Deflection IC and sometimes the HOT(Horiziontal Output Transistor) as well, not to mention the resistors that are blown when the IC failed. Replacing these parts should resolve the problem.
PS:Note that the Deflection circuit involves certain high-voltage components and prior to repair it is advisable to discharge the high voltage before attempting the repair. You will also need to know how to use a multimeter(to test the HOT and look for blown resistors) and a soldering gun. If you think you can do it yourself, let me know and I will provide you detailed step by step instructions.
Sai.
Sep 15, 2011 | Mitsubishi WS-65908 TV
Power on for 3 seconds then shuts off
When set shuts off and on front of set power light goes out:
Press and hold on the front of the set both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will blink an error code: most common is 2 blinks, 2 blinks a pause and then repeats it several times.
This feature will narrow down where the problem is.
Let me know what error code is found and I will tell you what it means.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Sep 29, 2010 | Mitsubishi WS-65908 TV
I have a ws-65908 that won't power up. When I press the power on button, the green light at the ON button comes on then goes off 3 seconds later. Any ideas on how to fix it?
Have you tried to access the self diagnosis feature by holding in the menu button and the device/input button on the set for five seconds? The led should blink a series of blinks then pause briefly then blink another series of blinks for the 2nd digit let me know what the blink code is an I will assist you.
Jun 25, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
