Question about Sony Cyber-shot DSC-W55 Digital Camera
Can 40D camera
I have a new Canon 40D and when I take a picture error 99 comes up and I have to turn off and on again to clear. It keeps happening all of the time. It was a gift for my birthday from parents.
  • Anonymous Mar 21, 2008
    I have the same problem (error 99) with three years old Canon EOS D60.
    I cleaned electrical contacts (lens, battery), used spare lens, reformated the memory card but in vain.
    May be possible to do something else except for the repair service?
    Thank you at advance.
    Nikolas.
    Novelist:
  • 155 Answers
Unfortunately, the ERR99 code is a catch-all code that means an UNKNOWN error has occurred. Because of this, it is going to be very difficult to pin down exactly what is causing the problem.
It could be a fault with either the camera (main circuit board, software, shutter mechanism etc.) or even the lens.
For starters, I would make sure that the lens electrical contacts are clean and the lens is mounted correctly and fully locked home. If you have a spare lens, try that also.
Next, I would reformat the memory card (do this in camera). If you have a spare memory card, try that also.
Check that the battery contacts are clean, and also the contacts of any external hardware such as vertical grips.
If none of these solve the problem, the only option left is to return the camera to Canon for a warranty repair, however if it is brand new, I would take it back to the store for an exchange.
Hope this helps,
Matt
Posted on Mar 08, 2008
Shoot 5 pictures and get error 99
There are over 40 different malfunctions that can cause an error 99 on a Canon 40D. The 2 that account for over 95% of the error 99's are either a bad shutter mechanism or a bad mirror driving motor. It takes special diagnostic software to determine the exact cause. Otherwise, a repairer just has to start replacing parts until the problem goes away.
Bob Kilbourn www.camerarepairs.com
Oct 22, 2011 | Canon EOS 40D Digital Camera
Err 99 keeps coming up
It is due to some kind of electrical (contact) failure.
For more details and common causes of Err 99 read the following article:
http://www.lensrentals.com/news/2008.12.31/canon-err99
May 16, 2010 | Canon EOS 40D Digital Camera
Error Message
On my 50D error 99 kept coming up to, but upgrading to latest firmware fixed the problem. I'm not sure if this your problem, but try Googling more information.
Oct 21, 2009 | Canon EOS 40D Digital Camera
Problems with Canon 40D, it won't turn on.
restore the factory settings
Oct 16, 2009 | Cameras
Every time I attempt to take a picture with my cam EOS40d, I get an error 99.I turn of the camera but error keeps appearing.
Check for clean lens to body gold contacts.
Take the lens off the camera. Look at the gold contacts that are in the body and on the lens. Many times, it's a simple process of rubbing a pencil eraser on these to remove dirt/film on them to allow proper contact. BE CAREFUL not to allow eraser crumbs to fall in the camera body. You can tip the opening slightly downward while you're cleaning... a lens brush can help remove any crumbs too
Let me know if it clears up your error.
K
Jun 17, 2009 | Canon EOS 40D Digital Camera
Canon 40d error 99
Try the following diagnosis steps: -
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 12, 2009 | Canon EOS Elan 7ne 35mm SLR Camera
Eos 40d error 99
Error 99 can mean many things. Have you installed the latest firmware for the camera (version 1.1.1)? If you don't have, download it here (for equipment purchased in USA or Puerto Rico):
http://web.canon.jp/imaging/eosd/eos40d/eos40d-firmware-e.html
If you have the latest firmware, try this:
  1. Switch off the camera and remove the CF card and battery
  2. Keep the camera idle for 30 min
  3. Clean all the contacts of the camera (battery contacts, lens contacts etc) with an eraser. Do this keeping the camera facing down so that no debris fall into the camera.
  4. Attach the lens and insert the battery.
  5. Switch on the camera
  6. Insert the CF card
  7. If the error persists, format the card again
  8. If this does not work, try using another CF card.
Feb 06, 2009 | Canon EOS 40D Digital Camera
Err99 40d canon body only
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Oct 28, 2008 | Canon EOS 40D Digital SLR Camera Digital...
Canon eos 40D error 99
Check this link: www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Oct 20, 2008 | Canon EOS 40D Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
37 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
