Question about Mitsubishi VS-50605 50" Rear Projection Television
TV problem Do I need to check D951 or any others and how how is it done? REDCAT55
  • Mitsubishi Master
  • 8,617 Answers
You have to lift one leg out of circuit and touch the leads to each end of the diode then reverse them and take the second reading,
Posted on Mar 08, 2008
Hitachi 50ux26B keeps turning off.
There is a chance that the one of the power relays are causing the problem. They have been known to be intermittent and even work for 5 sec. or 5 days before failing. When the back is off, turn the set on and when it shuts down lightly tap the relay/s in the power supply lightly and see if the set comes on for any length of time. If it does, replace the relay
and you will fix the problem. Let me know what you find.
Hope this helps,
Skyassoc
Jun 29, 2009 | Hitachi 50UX26B/27K 50" Rear Projection...
Hitachi 50UX26B no picture no sound
The deflection board needs replaced.
Dec 05, 2007 | Televison & Video
TV problem
Use the analog meter reverse your probes you should get no reading one way and get a reading when the probes are reversed. You will need a diode vhecker to test for a leaky diode as often times a diode will fail under load. Its best to replace a questionable diode if you dont have an actual diode checker meter.
Mar 08, 2008 | Mitsubishi VS-50605 50" Rear Projection...
TV problem
Check the diodes and regulators out of circuit that feed the IC especially pin 1 and pin 4
Mar 02, 2008 | Mitsubishi VS-50605 50" Rear Projection...
TV problem
Let me go over the schematics and I will post what i can find that maypossibly keep taking out the IC
Tv problem
Check the connections on your front control panel PCB to see if they are all secure then trace them back to where the plug into the chassis and check the connection there as well
Mar 01, 2008 | Mitsubishi VS-50605 50" Rear Projection...
TV problem
1) Unplug the AC cord.
2) Connect a 100 Ohm resistor (R) between
pins 4 and 5 of the IC951. This discharges C960
that may still be charged if the Over Voltage
Protect circuit was activated.
3) Remove the 100 Ohm resistor and apply
power to the set.
If the problem still exists, the IC is probably defective.
Feb 24, 2008 | Mitsubishi VS-50605 50" Rear Projection...
TV problem
Over Current Protection
Pin 1 of IC951 is also the Over Current Protect input.
The internal FET.s ground return is at pin 2 of
the IC. The voltage drop across R955 and R956
indicates the FET.s current, and is coupled through
R953 to pin 1 of the IC. The Over Current Protect
circuit is activated if the voltage at pin 1 of the IC
exceeds 1.35 volts.
Stabilization and rough regulation are provided by
feedback from pin 3 of T951 to pin 1 of the IC. Fine
regulation feedback is from a secondary supply,
through the Photo Coupler, PC951, to pin 1 of IC951.
Its possible that Diode D953 is leaky allowing the voltage to rise on pin 1 of the IC
Feb 23, 2008 | Mitsubishi VS-50605 50" Rear Projection...
DEAD TV
Look for 2 resistors off of pin 2 of IC951 R955 & 956 they are hooked in parralell and the tail end of those resistors are grounded.
No picture or sound
You probably have one or two diodes bad which would have to be unsoldered to replace. Since it is a small TV, it may not be worthwhile to take it to a repair shop -- if you can find a good electronics tech with soldering equipment and a multimeter, have them check out D951 a 12 volt zener diode near the power relay. If good, then I would check out D941 and D942 in the power supply. If all three diodes are bad, the set probably took a power surge or lightening strike and could have other shorted components as well.
Dec 11, 2006 | JVC AV-20920 20" TV
Mitsubishi VS-50605 50" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
