The alternator is most likly the problem. If it was ok before and you had the alternator replaced the problem should be the new alternator. The above answer is if static is your problem. If you can not pick up stations there is a good chance that you have a antenna problem.
old post, and my first radio noise post.
im an old radio guy USN, and ex ham.
Q1: AM or FM? (even on cassette or CD?)
1: bad antenna, and for sure, there are upgrades !
2: too far from station, AM is worst for static, but FM has shorter distance for same station power. (I heard XERB in VietNam! AM)
3: bad radio. (rare for both am and fm bad)
4: bad alternator can sing, play with throttle and it sings higher for higher RPM bingo. stop engine, singing gone?, bingo. Alternator.
5: and last ignition noise, so stop engine still have ignition popping sounds. no more? , then Ignition noise, clicks or pops. (spark)
6: noise has 2 sources , radiated or conducted.
if conducted on power line, 12v to radio , we can buy a filter to stop that.
older cars do this. what year is yours. a honda what a 73 civic?
Have you tried different cd's?I f so then the loading tray may be at fault.If you don't want to fix it here is a solution.Buy a cassette adapter with a 3.5 mm connector and use a mp3 player you can transfer your cd collection to your mp3 player via you computer
this is not strange at all, the problem is the symptom of a defective antenna or the antenna ground to the chassis sheet metal of the car, also the coax to the radio can be defective.
