Question about Denon AVR-3802 Receiver
Wiring speakers to denon avr 3802
Hi im a novice so bare with me pls, ive borrowed a denon avr 3802, and need to wire my two b&w cdm speakers, which have four speaker ports each( woofer and tweeter).
Where do i wire them to on the denon ?
    President:
  • 624 Answers
Those are not compatible speakers for this unit. The Denon receiver does not have any speaker outputs for that type of speaker.
The Denon speaker outputs are full range outputs. Your speakers are not designed for that, they need an amplifier that has seperate outputs for the highs and lows.
By using these speakers you will probably damage them and they will not sound very good as well. The tweeters will end up fried and it is also likely that if one of the speakers goes bad, it will blow one of the channels in the amplifier.
If you really want to do it anyways, and don't say I didn't warn you, you could connect them using the "A" and "B" speaker outputs. Connect the woofers on one set, lets say "A", and the tweeters on the other, lets say "B". Right channel "A" would be the woofer and right channel "B" would be the tweeter for one speaker.
When listening to the unit you would need to engage both the "A" and "B" speaker to hear anything from both speakers, there are buttons on the display for the speakers marked "A" and "B" and in the display you would see little icons that light up when the speakers are engaged.
I can not stress it to you enough that this is not a good idea to use these speakers with this type of receiver. Do this at your own risk and be prepared to pay about $150 to $200 for the repair bill after the amp blows a channel.
Posted on Jun 22, 2008
Denon 3802 connected to blu ray player but playi g dvds, how do i get dd 5.1?
You cannot get 5.1 sound from DVDs that are not encoded with 5.1 sound. They may be stereo, which will only send sound to the main front L/R speakers.
Nov 23, 2013 | Denon AVR-3802 Receiver
My denon avr 3802 reads no back speakers and there is no power to them. any ideas
You must TELL it it has back speakers and assign the amplifiers for them. It's in the manual. Page 10-12.
May 29, 2011 | Denon AVR-3802 Receiver
AVR-589 Denon Receiver Keeps Shutting Off
even if the wires are not touching they can still arch. make sure there is no bare wire showing ie. cannot see any unshielde speaker wires. id unplug then replug back in
May 18, 2009 | Denon AVR-3805 Receiver
AM,NEED REMOTE CONTROLL DENON AVR-3802 HOW I,BUY?
I had the same problem. Unfortunately Denon no longer mfgs. the remote for this receiver,
their solution is to offer a remote for a "similar" model. Problem is it doesn't work on all the
functions for the AVR-3802. My solution was to purchase an aftermarket universal remote
(Logitec Harmony 550 in my case}. The cost was a little less (approx. $90) vs. the price
quoted by Denon (somewhere around $120), and it works on all the functions.
I don't know if a budget priced remote (All-in-one, etc.) would be able to do th same.
There are several different programmable remotes on the market that should do the trick,
Logitec just happens to be one of them.
Good Luck
Mar 24, 2009 | Denon AVR-3802 Receiver
Denon AVR-3802 Problem
Check that your speaker cables are not touching each other at the amp end and also at the speakers as this will cause the amp to shut down.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Denon AVR-3802 Receiver
Denon avr 3802
First check the speakers one by one ,if they are good your audio amplifier ICs is near to go in to short circuit.
May 27, 2008 | Denon AVR-3802 Receiver
Set up
You don't need to fake it with a VCR - on the back left side near the bottom there is a Monitor section with an RCA connection and an S-Video connection. Connect one of these to an input connection on your tv and switch your tv to show that input. Select the AMP setting of your remote and press Setup.
Mar 01, 2008 | Denon AVR-3802 Receiver
Denon 3802 Amp issue
check the output res. from the DVD, your Denon may not pass high res 720p, 1080i or 1080p and also check the component assignment in the Denons setup
Oct 08, 2007 | Denon AVR-3802 Receiver
Denon AVR-3802 Receiver Logo
276 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
