Question about Canon i860 InkJet Photo Printer
Paper does not feed
Everyone once in a while I can feed 1 paper and if I push it in at the correct time it works.. Otherwise it does not take the feed at all.
Any help?
  • 88 Answers
Try to adjust your margins in the paper feed tray, chances are they are too loose. Do not space your margins too loosely or too tightly, just enough for your paper size to fit.Also check if your paper thickness is setup for boards or thicker paper types.
Posted on Apr 09, 2008
Sharp calculator EL-1197P III paper feed stuck
Hi
I trust you are well.
This might be trivial however when you replace your paper roll the edge of the edge paper must be cut straight otherwise the paper will not feed correctly.
Hope this solution is as easy as that, If not open the claculator paper feed compartment and check the gear mechanism for chipped teeth or foreign objects stuck inside.
Hope this helps you
Kind regards
Aug 15, 2014 | Sharp EL-1197PIII Calculator 12-Digit...
My printer keeps showing the message "Clear paper jam, then press (check mark), there is no jammed paper in the printer.
If I load my paper at the 'proper' height, it will not feed. If I push the paper down too far, I get a 'paper jam' message. What works for me (even though it's a royal pain) is to feed 1 sheet of paper at a time. Put 1 sheet in so it's level with the top of the feed tray, then gently push it down 3/4 of an inch. That works for me. Good luck.
Sep 19, 2010 | Lexmark X5470 All-In-One InkJet Printer
Epson CX5000 Paper will not load. Tries to but says paper jam even when there is no paper jammed. Blank pages will go through during reset but not otherwise.
Most of our printers pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Finally, turn the printer upside down and carefully shake it for 10 to 20 seconds to see if something falls out of the paper feed path. Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print again.
If it still fails to feed the paper correctly, please reply with the following information:
What type and brand of paper were you using? Have you ever used this type or brand of paper before and if so what were the results? Once we have this information we will try to fix the unit through email support.
Apr 29, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Only 8 1/2 by 14 paper jamming at the DADF
Does it feed sometimes, and just jams frequently, or every single page?
Are you sure the paper size in the tray is set correctly? Otherwise for frequent or constant jams when the paper simply stays in the tray, then the feed rollers are likely worn out.
Mar 16, 2009 | Office Equipment & Supplies
Riso tr1510
Take one of those flat plastic rulers and push it through all over.. so that any forein ripped paper whatever, clears the way.. The paper is supposed to buckle on entry.. That's how it's designed. It could be a timing issue.. when the paper is fed in it buckles against the timing roller.. the roller turns only when its supposed to. Each sheet stays buckled against the timing roller until it turns, that's how the machine draws only one piece at a time. It's could be the feed clutch.. There's a little magnetic clutch that actuates the feed roller to pull the paper in. when this feed clutch gets weak it barely works or it slips and doesn't pull the paper in at the right time. I've replaced these often on my equipment.. but I've also found that static electricity plays a big role. If your area is too dry, the paper sticks together increasing the resistance, pulling either multiple pages or just too much resistance for the feed rollers.. screwing up the time.. Make all adjustments to the feed rollers first to ensure it's not a huge problem before you start looking for a clutch. Essentially if the paper doesnt make it into the feed roller on time it is a timing issue.. but it's starting from the feed rollers.
Feb 03, 2009 | Sweet Beginnings Cabana Stripes Crib
Paper Feed errors on 2400W
It is a timing issue, mine does the same thing. Here is fix. Open top door, remove drum cartridge, look inside for pickup roller ( the one that is shaped like a half-moon) reach down there and rotate it towards the front of the printer and downward so the curve ends up being pointed down to the bottom of the printer. You should here a loud click, that is the cam being reset. The cam is to the left behind the 2 gears. remove any paper feed jam, reinstall drum and close the top lid. This should reset it back correctly. Do the above steps with paper in tray and the power left on. Do not reset the printer after resetting cam position. Also it might take a few attempts to get the timing reset right, so dont give up after 1 failed attempt. I have had to do it 10 times before to get the timing right. Just make sure the curved area points downward.
Sep 27, 2008 | Konica Minolta magicolor 2400 Laser...
Brother HL 2070N red paper light blinks but won't print.
Just fixed my printer issue, had the same problem, Would load 1 sheet, then jam, sometimes it won't pull the paper out of the tray, sometimes it would pull the paper to the toner area, but never into the toner, opening and slamming the paper tray while it attempted to load would usually work, but who wants to slam the tray 50 times? I was using Walgreens generic paper, 20lb, took some higher-quality 24lb HP paper and VOILA! It works every time! EVERYONE WHO IS HAVING THIS PROBLEM, CHECK THAT YOU ARE USING 24LB PAPER!!! Brother says 20-24 is acceptible, but sneaking one sheet of 20lb paper about 15 sheets down in a 20 sheet print job and it will stop at it every time, You can feel the difference, less like toilet paper and more like real paper.
24 LB PAPER! USE IT NOW AND THANK ME LATER!
Jun 27, 2008 | Brother HL-2070N Laser Printer
Error Code E0200D
I think making sure the paper is properly aligned fixes that problem. I get it once in awhile.
Feb 19, 2008 | Canon imagePROGRAF W6400 InkJet Printer
Paper feed
Feed roller is dirty or worn thin, wipe rubber roller with damp cloth.
Nov 03, 2007 | Kodak EASYSHARE Printer Dock Thermal Photo
Lexmark x1185
You have two issues at same time. 1: your printer may have a jam somewhwere. remove all paper, and open unit cover, and see if you can find any bits of paper jammed, remember they can be minute and will still cause big problems. check thoroughly behind unit too, sometimes it helps to use a torch. When you put paper back in, only place a very thin stack, too much will cause feed problems and jams. Make sure paper rest is correctly installed too, and the paper guides either side are not pressing too tight on paper stack sides, they should sit gently beside in line with it not pressuring it. Also check if roller is even, inside and down back. Flick paper stack in fingers to separate pages and never feed bent dogeared or marked paper into unit, even a tiny little notch in it will catch. Try printing now. The scanner issue can usually be resoved by uninstalling the whole printer and reinstalling it, ensuring a thorough reset. Good luck and post back if no help.
Aug 29, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Canon i860 InkJet Photo Printer Logo
178 people viewed this question
old marine
old marine
