There are several models in the Acer Aspire Switch 10E line. If you start here: http://www.acer.com/ac/en/US/content/drivers . Either enter your machine model or use the drop-down menus to select Notebook, Aspire Switch and then your model. Click on the Documents tab. There should be a User Manual link to download a .zip file. Extract the contents to read the enclosed PDF. Note: the User Manual W10 includes notes for using Windows 10. It doesn't have the contents of the general User's Manual.
I would try to find specific drivers that are relevant to your make and model. However, drivers will only apply to devices that pertain to certain criteria so if you were to install the latest it wouldn't harm your device, it will just most likely not have any affect.
Hi As u said that replacement Battery is not charging then i would like to suggest to check the battery's hardware. Try to change the battery once as it could be the battery's fault. If you have any more trouble do come back in Fixya. Thank you
May want to go in the control panel and under sounds icon, double click and check to see where the settings for the pc speakers are set, you may have an equallizer on that can be adjusted> try that
The link below shows the full Instructin Manual for for your One for All (Model: URC 7740). You will find all you need to set it up with all the devices you like.
http://www.rockabilly.net/files/manuals/URC-7740.pdf
It's in PDF format document. You can download it, Print it, or Bookmark it FOR FUTURE REFERENCE.
