Question about Sony PlayStation Portable (PSP) Console
Psp problem my psp cut off in a 1/2 hour why
  • robert smith
    robert smith May 11, 2010
    try a nother battery and does it still do it while you got the charger in it ?
  • 32 Answers
You might need a new battery.
Posted on Mar 31, 2008
Psp E1002 has frozen and wont turn off
ok true it off now and cut it back on if it doesn't it again tell sony
Jul 24, 2013 | Video Game Consoles & Games
My psp will not cut on and i've already charged it
Hi Lanya.First things first, breathe!Ok step 1: find your PSP. 2: see is it working now. Same thing happened to my phone, going great now though!Hopefully it is.Happy to help.Kind regards, KJ
Nov 24, 2011 | Sony PlayStation Portable (PSP) Console
I charged my psp for atleast 5 hours.....but charge ended within 1 hour......what to do??
I'm just restating what you said here first...
You plugged in your psp for 5 hours.
You took it out.
You played it for 1 hour before it turned off...
If this is true, it seems that your battery just can't hold a charge. One solution would be to just buy a replacement battery, but you could try this...
Drain your psp completely. This means keeping it on until it turns off, then turn it on again, leave until off and so on. Just keep turning it on until it stays on for less than a minute.
Charge your battery overnight.
Hope this helps!!!
Oct 07, 2010 | Sony PlayStation Portable (PSP) Console
My psp has water in it how do i get it out
  1. The first thing you do is to remove the battery and the memory stick.
  2. second wipe your psp if it is wet outside...
  3. third is...(i think it's crazy but at least try this...) put your psp into a bunch of rice that hasn't been cooked yet, because the rice can **** up moist and wait a 24 hours, if it's still has water, wait for another 24 hours...that's all folks!!!
Nov 11, 2009 | Sony PlayStation Portable (PSP) Console
How long do I charge the psp battery?
most psp chargers are fitted with a cut-out.
which means that when the batteries are fully charged.
The charger shuts off.
A full initial Charge ( New-Battery ) could take 4-8 hours et,c Dependant on Capacity.
also a red light to green, can indicate full charge.
Mike @ Compurepair.
Nov 05, 2009 | Sony PSP (Piano Black)
Psp will Play video but the sound will cut out after 1:30 min
I guess after getting the videos, please use this tool to convert;
Step 1. Download this PSP videos 9 from http://www.pspvideo9.com/ and run it on your computer.
Step 2. Double click on the software to open it.
Step3. Click on Convert > Current Conversion > One-Click Convert andthen the pop-up for the directory comes up. You can then choose thevideo from the directory where it is saved on your computer (desktp,folder,...etec).
Step 4. Click on "Open" and then the conversion starts automatically. Allow the conversion go on to 100%.
Step5. After completion click on Library > Local Files > Open Folder,the file's original directory opens up and you can now copy to your pspvia cable or memory card (memory card reader).
You can convert and watch any video to the format your psp could play.
Regards
Jan 11, 2009 | Sony PlayStation Portable (PSP) Console
A bricked psp
Try taking out the battery, waiting 1-2 minutes, putting the battery back in, and then charging it for 10 hours without turning the unit on
Jan 04, 2009 | Sony PlayStation Portable (PSP) Slim...
Joser
Ok, for the PANDORA BATTERY, you'll be needing
1. A cutter
2. Your PSP SLIM battery (of course)
3. Lead Pencil
the steps:
1. Take out your PSP battery, using the cutter, run the sides of your battery along the lines(where the battery has been joined) starting from the bottom until it opens...just be careful or you might mess the board of your battery.
2. Carefully Prop out the board of the battery
3. then, using the cutter still, carefully cut the golden line (indicated by the small blue circle in the pic)...maybe 15 to20 runs of the cutter will do (that's what i did at least). Just dnt press too hard or you might cut through the whole circuit board ok?
4. Then after cutting the gold line, you're through...just close the battery again and tape it up at the sides (i used packaging tape with mine, heheh...) and you're through with the pandora battery!
*NOTE: you'll know that you're successful making the battery when you put the battery in the PSP and the green LED light automatically turns on but there isn't any display on your PSP's screen. If it doesn't turn on automatically, just try to run a few cuts again on the line on the Batt's circuit board.
Turning the PANDORA Battery into NORMAL Battery:
Now, to turn the battery into normal battery again:
1. Open your modded SLIM battery
2. Using the Lead Pencil (i don't know if it works with other pencils too), remember the line that you've cut on the board of your battery? Run the pencil on the cut to re-connect that gold (or yellow) line.
3. You're done. Close your battery again and secure it (again) with tape...Finis!
Jul 31, 2008 | Sony PlayStation Portable (PSP) Console
Psp wont turn on
You really need to send you PSP into Sony for repair.  There is not much you can do with the porblem you have. Contact Sony repair at the listing below.
SCEA Consumer Services
1-800-345-SONY (7669)
Oct 09, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
13 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
