Question about Brother MFC 420CN All-In-One InkJet Printer
Near empty black
I've just bought new ink catridges (black and color), i keep getting (near empty black) on the pronter screen, i checked the color monitor and the level of the black color is very low and the color are almost low although there are new
  • gazetteed Mar 09, 2008
    We have just installed a complete new set of ink cartridges, black and color, and now get an error message that Magenta is empty. Removal amd reloading does nothing. Unplugging unit and plugging it in to power again only gives another error message, telling that Magenta is 'near empty.' Nothing allows us to print a black copy, which is what we want. Is this dead in the water, complete with a new set of cartridges, or can it be reclaimed?
    Any help appreciated...
  • 832 Answers
Take ALL carts out of the machine. leave scanner open and unplug from POWER OUTLET.
Wait 5min.
Replug to power. Wait until machine demands carts.
Insert carts again.
Close cover AND ANSWER THE DISPLAY questions if you have changed the carts. Give answer by pressing 1 (Yes) or 2 (**). You should answer for the new cart of course with 1.
This will reset the ink counter.
Posted on Mar 09, 2008
Ink cartridge not properly installed
I have gone through all the forums but none of them worked...
The correct solution for the problem is the canon printer needs to have both the color and black catridges present in the printer...
So even if you purchased new black catridge only you need to have the old color catridge to be placed in the place of color catridge....
So it will detect the catridges and if any of the one is empty it asks to select black at the time of printing and simply select it you will get a black print...
So make sure both the catridges either empty or full need to be placed to detect the catridges....
I hope it will be helpful.....
Feb 18, 2011 | Canon PIXMA iP1300 Printer
Replaced the ink. black works colored does not.
Normally, new catridge has a thin layer close the output of the ink. See that thing. If it close, pull it over, Or.
May be the catridge is not suitable with the printer.
May be the the catridge is quite old and the ink is dry, if it is refill catridge, put several drop of hot water in it.
Hope this may help.
Jan 20, 2010 | HP DeskJet F380 All-In-One Printer
How do I print with black ink only so the printer doesn't keep taking color for b & w printing? I am out of color and the printer won't print unless i go out and buy more color cartridges when i only...
When you bring up the print screen, click on the printer properties tab (top right) and on this screen you will find 'use black ink only' and 'print in black and white'
Nov 20, 2009 | HP Office Equipment & Supplies
Replaced color cartiage, now only one color prints, red? Help
Try to check the level of your ink in your color catridge maybe is running low or empty then if its empty then remove the catridge then replace another color catridge full of ink then run your printer again. If you successfully installed new ink catridge then it will automatically reset the level of your ink monitor to full.
Jun 16, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
Problem with One Color (Yellow) not printing on Epson R280
Hello sir; Why don't try to press "resume" key before you print.
Apr 17, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Brother MFC-210C does not reset after ink is replaced
The usual obvious fix is to buy a new catridge, insert, power off machine, then switch back on to reset any sensors. But if the circuitry on the machine itself is faulty it wont fix it.
I used to own an MFC 260C. It had a perfectly good full ink catridge in it, that was working fine, until...it suddenly did not recognise the cartridge anymore.
I pulled the machine apart and found that 2 of the 4 sensors on the cct board at the back of the cartridge housing were loose. These sensors pass light through the exposed part of the cartridge to see if ink is there. So if these are faulty, you will never clear the "No Cartridge" or "Ink Empty..." or "Near Empty Ink ..." messages on the MFC260C and probably other similar printers in the MFC range.
Why did they fail? Because the soldering on these sensors was poor quality.
I would never buy another Brother machine because of this, also because they design the machine to be totally useless unless all the ink ccartridges are full. Shame on you Brother, and kiss my *** for the $160 pile of junk I bought off you that was only on its second batch of cartridges (ie very little use)
Nov 21, 2008 | Office Equipment & Supplies
Color printing
GO TO MAINTANANCE SECTION IN THE MENU TRY TO TAKE SELF TEST PRINT.
IF IT COMES THEN GO TO NEXT STEP AND TRY TO CHECK THE INK LEVEL OF THE CATRIDGES IF THE INK LEVEL IS LOW DO REPLACE WITH THE GENUINE CATRIDGE ITSELF.
Feb 29, 2008 | Lexmark X4270 All-In-One InkJet Printer
Printer says ink near empty
Black electrical tape works like a charm on a Brother MFC-465CN. Thanks for the tip! :-)
Jan 16, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
411 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
