Question about Dell W4200 42 in. HD-Ready Plasma Television
Service menu looking for the remote sequence to get into service mode to do a n alignment
{INPUT} {6} {1} {9} ON REMOTE FOR SERVICE MENU. DO NOT DO ADC CALIBRATION - KISS IT GOOD BYE
Posted on Jul 24, 2008
Which board is it
hi this is screen burn mode, press the menu button on the remote to stop it you may have to retune tv back in, if this don't work, you will need to go into the service mode and turn the screen burn mode off,to do this press menu on the tv and menu on the remote, you should see another screen pop up, select screen burn mode to off if the first sequence don't work try ok on the tv and ok on the remote, thanks
regards
shaun
Mar 25, 2015 | LG 37LG60 37 in. HDTV LCD
Philips magavox model 19pr15
1. To enter the Service Alignment Mode (SAM), press the following key sequence on the remote control transmitter: 0-6-2-5-9-6-Status.
2. From the top level SAM menu, use the Menu Up/Down keys to highlight the Geometry sub menu.
3. Use the Menu Left/Right keys to enter the Geometry sub menu.
4. In the Geometry sub-menu, use the Menu Up/Down buttons to select VAM.
5. Using the Menu Left/Right keys, adjust VSH so that the horizontal bar is properly centered, top to bottom.
6. Using the cursor up/down keys, select VAM from the Geometry sub-menu, and use the Menu Right key to
increase the value to obtain a slight overscan.
7. If other Geometry adjustments are needed, proceed to the necessary adjustment using the Menu Up/Down
buttons.
8. Upon completion of Geometry adjustments, press the Menu button to return to the top level SAM menu.
9. To exit the Service Alignment Mode, turn the set off with the Power button on the remote control.
Oct 30, 2007 | Philips 19PR19 19" TV
Tip
SERVICE MODE AND ERROR CODES CHECK
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
May someone please send the service mode specifications for a Samsung LED 40 inch TV UA40EH5000R?
I don't have service mode specifications but I do have a Samsung and looked around for how to get it in service mode some time ago because the HDMI cables somehow disconnected themselves a lot. Thought it was an electronic problem but it turned out to be a parenting problem instead SO I have never used this information and can not vouch for it. I cut and paste it from a note I copied from a forum entry to use at your discretion:
First post:
To enter "Service Mode" Press the remote - control keys in this sequence :
From Standby Info-Menu-Mute-Power On
- The buttons are active in the service mode.
Remote - Control Key : Power, Arrow Up, Arrow Down, Arrow Left, Arrow Right, Menu, Enter, Number Key(0~9)
Careful though there are things you shouldn't touch in this menu.
avforums.com/forums/lcd-led-lc­d-tvs/601553-samsung-service-m­enu-research.html
Another post:
Method 1
Put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu.
Method 2
Turn the power off. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
Method 3
With the TV in standby, press the {DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Method 4
With the TV in standby, press the {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
Method 5
With the TV in standby, press the {DISPLAY} {MENU} {MUTE} {POWER} on the remote.
Method 6
With the TV in standby. On the remote, press Mute followed by 1, 1, 9, Enter in sequence.
Samsung LCD Monitor Service Menu Instructions
End quote.
Good luck. Just a basic suggestion you probably don't need: keep track of any changes made by writing them down so you can put it all back if you have to.
Dec 20, 2014 | Samsung Televison & Video
Sony DVP-CX995V Test Mode
Thought I could add a few suggestions for anyone else experiencing this issue.
1.The SLIDER AT THE TOP OF THE REMOTE MUST be in the DVD Position. The sequence will not work if remote slider is in Disc explorer mode or TV mode. It doesn't specify this in the service manual either.
2. Sometimes it just doesn't work the first couple times, so keep trying. For best results, do the sequence from about 5 feet away, pointing the remote at the receiver on the player (lower left), and slowly and firmly press each button, pausing 1/2 to 1 second between each button press works best for me.
3. Also, it could just be low batteries in the remote and If it still doesn't work and it is worth putting more $$ into try a new remote as suggested already.
Just my 2 cents probably worth noting for future visitors to this question.
4. + LINK to FULL FREE Service Manual
SONY DVP CX995V SM Service Manual free download schematics eeprom repair...
NOTE: at the link above Click the Get Manual under the preview to download
Mar 30, 2014 | Sony DVP-CX995V Multi-disc DVD Player
Akira tv universal remote accidentally went into service mode cant reset
Press menu-display-power in sequence on the remote control.
Jan 08, 2013 | Televison & Video
I have audiosonic colour television KMC TH68. The word "Factory" appear on the top just on the middle.The worse part is that is locked. One symbol like "lock" is on the left buttom in...
finally have a solution for this problem. Finally got my tv back to normal. Try this: Make certain the TV is receiving a signal.
Press in sequence on the remote [MENU] > [6] >[4] > [8] > [3].
[FACTORY] is displayed.
Press the above sequence again to enter [White Balance] menu.
Press the above sequence again to enter [Adjust] menu.
Press the above sequence again to exit service mode.
Dec 09, 2010 | Televison & Video
I just replace a lamp on Sony vpl-cs20 and lamp timer is still high
You should turn on the VP-CS20 with the button on projector, NOT THE REMOTE or the instructions wont work.
Using the remote commander while the unit is powered up, press "ENTER", "ENTER", "LEFT"
and "ENTER" in sequence. A prompt will appear on the screen asking if you wish to enter the factory mode.
Press the "UP" key on the remote and the unit is now in service mode. This sequence will add two new groups
to the customer setup menu. Press the "MENU" button to view.
Whenever the lamp is replaced, the lamp timer should be reset. With the unit in the "factory" mode, press
"RESET", "LEFT", "RIGHT" and "ENTER" on the remote commander. Verify the lamp hours have been reset to zero in the service menu.
Hope it helps,
FVazquez
Sep 22, 2010 | Sony VPL-CS20 Multimedia Projector
The word "Factory" has appeared on the screen in red
Hi.
Factory on screen means that the TV is stuck in service mode (Durabrand and more). The problem is fixed accessing Service mode and resetting to factory default settings.
On Durabrand TVs problem is fixed using a programmable remote, entering service code on remote, and accessing service menu.
Procedure is listed on TV service manual.Most durabrand use Menu and key combination 683 to access service mode.
If that does not work, calll manufacturer number to get the key sequence to enter factory menu.
Jul 06, 2010 | Televison & Video
No color adjustment
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Dell W4200 42 in. HD-Ready Plasma Television Logo
144 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
