Question about Dishwashers
Kenmore Ultra Wash Dishwasher Model 15882
After my last washing we found a round plastic disk inside that appears to have fins in it for circulation. This is the information that is on disk, a number 8268296 4, a code of PAfsp MOLL. What part of the dishwasher would this have come from, I can't find a spot where it's missing from.
Thanks for any info. Send response back to rwsmit2002@yahoo.ca
Ron
  • 1 more comment
  • rwsmit2002 Mar 10, 2008
    The whole part number is 665.15882. will thaat help with the part number for the pin. Is it a cotter pin.
  • ozziee Jul 08, 2008
    I found a white disc in my dishwasher that seems to be a part - but I can't tell where it came from and can't find any pieces other than this disc. on one side it has what appears to be spinners - and on the other it has the following "8268296 4 PA FSP MOLL"
    any ideas? can I still use the dishwasher without this piece installed? It is a Kenmore Elite series washer less than 2 years old.
  • jreal Apr 25, 2009
    I've also experienced the same problem i.e. the FSP Moll disc-type part lying in the dishwasher. Can you advise on the repair/solution?
    Thx, Vic
  • 52 Answers
It most likely belongs in the center of the dishwasher’s ceiling and is usually held in by a plastic pin. It is used to spray water on the dishes in the upper rack. I would need your full model number (including the part that comes before 15882, like 665. or 110. for example) to know the part number for that pin, since it is probably broken. Hope this helps!
Posted on Mar 08, 2008
Kenmore ultra wash III portable dishwasher. Model #1765991. Lower wash arm came off. How do I re-attach?
Hello. The lower spray arm screws down onto the center, round, plastic part (spinner) that has threads on the center portion. It's very loose and spins easily because it uses the water spray to drive it. At the top of the threads, there will be a flat piece of plastic. Set the spray arm down onto the threads. Hold the flat plastic area that sticks out above the arm with pliers. Spin the spray arm counter-clockwise while holding the spinner. It will thread itself down about a turn or so. Snug firmly--DON'T OVER-TIGHTEN the spray arm onto the spinner. Remember, it only uses water pressure to spin so it doesn't have to be "gorilla tight"! I hope this helps you!
Oct 14, 2015 | Kenmore Dishwashers
On my Kenmore model 665.13489K900, it does not clean well and appears to have a problem with getting or circulating water inside to all areas, especially the top shelf.
Check the center wash arm assembly. If the center wash arm isn't getting water, all of the dishes in the upper rack will come out dirty. Check to be sure the center wash arm assembly is mating properly with the water supply nozzle in the back of the dishwasher. Also check to be sure the little holes in the center wash arm aren't clogged or blocked. * Run empty cycle using vinegar and baking soda lime scale problem will resolve.
Nov 13, 2013 | Kenmore 15912 Built-in Dishwasher
Water in bottom of kenmore elite ultra wash dishwasher
you must check the filters that are at the bottom under the spray arm
then you must start and then hold down cancel or stop and it should kick in the automatic water discharge mode and activate the water pump if this does not work you need new dishwasher pump installed which can be found online by googleing your model number. gut if this all works then the small flapper thats internal on the pump isnt sealing and allowing water to flow back into the bottom. last but not least you might need a new control board.
Nov 02, 2012 | Kenmore Dishwashers
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Jul 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
Jan 17, 2009 | Dishwashers
Kenmore ultra wash dishwasher control lock light flashing
Just press the 'Air Dry' button for 5-6 seconds....I have an ancient Kenmore Dishwasher (ULTRA)
Oct 02, 2008 | Kenmore 15899 Built-in Dishwasher
Kenmore ultra wash 665 dishwasher heating element melted down in one corner
I know no other way the heating element could have ended up bent up like this.
Mar 05, 2017 | Dishwashers
Kenmore Ultra Wash Dishwasher wiring diagram
if unavailable on line, contact mfg's parts and you should be able to order it.
also, they likely do not make the unit. the sears may be able to tell you who made it. that company would be able to get you a diagram. just make some phone calls.
Nov 02, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Permanent (?) stains on inside of door
Have you tried a treatment (not sure of the name) that you wash plastic dishes with that takes the orange stains out? It can be found at Walmart for under $10. I don't know of anything that can prevent this problem but I don't see why a product that takes it out of plastic dishes can't take it off the plastic of the dishwasher. Hope it helps!
Sep 05, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
702 people viewed this question
Top Dishwashers Experts
