Question about Ovens
Oven will not heat to right temp
Hi, I have a ceramic top frigidare that was in the house when we purchased it. I have tried to bake in it, I am a baker, however the temp stays 25 degrees below the desired temp. is there a way i can fix this?
    President:
  • 2,651 Answers
You can calibrate you oven try presiing and holding the bake button for 3-5 secs. it should beep and put a 00 in the display. using the temp up or down arrows you should be able to adjust ther temp to a max of 35 degrees + or -. after setting to desird 25 presss start and that setting will be ingrained in the memory forever(or until you change it again)power failure will not effect it either . of that doesnt work gimme the modle and ill ck further
Posted on Mar 09, 2008
Neither oven or broiler work. Upper elements work well. Why is the bake light flashing / blinking?
if it is not coming on then you may have the same problem again with the ignitor.
May 04, 2014 | Ovens
Oven taking too long too bake.
If you still have your Frigidaire Oven there is an reason why it take longer to bake. Frigidaire Oven has an safety limit control inside the oven and it is place on top of your oven. We know that the heat go up,so that control is cutting the heat will the thermostat is asking for heat.I had a Frigidaire oven, I change 2 control a the end a purchase a new one. When I scrap the old one I notice that problem,
Jan 18, 2014 | Frigidare Ovens
My oven is not heating up properly, it either doesn't heat up or it takes a very long time to heat up. The range top works fine and the broiler works, but when i set it to bake it doesn't or takes long.
There are two possibilities for problems with the range. If it has a "timed bake" setting for the oven then it's possible that the last person who used it neglected to return the setting to the manual mode. In "timed bake" mode, the oven will heat to approx. 160 - 185 degrees, what is called a "keep warm" temp. It will maintain that heat setting regardless of what you set the oven temp control to, as long as you're not in the time frame that it's set to bake. This will make trying to bake anything a very difficult procedure.
The second possibility is that the oven glo coil igniter is cracked and will not heat to the proper temp to allow the electricity to flow through it to the oven gas safety valve to allow it to open and let the gas flow to the burner. These things are ceramic and for some reason crack in normal use. If it has a top broiler, that unit is obviously good. Unfortunately, the igniters are seldom interchangeable. You would need a tech to check the igniter with an ohmmeter.
Mar 23, 2011 | Amana Ovens
We purchased our Frigidare Double Oven, Model Number FPET3085KFA, October 2009 (15 months ago). We ran the self-clean process for the first time yesterday on the top oven using the 4 hr option and it...
try turning your breaker off for 20 minutes, then try it again,, if this does not help it could have burnt out a element or the main board has went out,,, also make for sere you are getting the full 220 volts to the unit,, this will involve taking the unit out
Jan 19, 2011 | Frigidaire 30 in. Electric Gallery Series...
Preheat takes too long
does the oven bake properly when it does reach temps?
if this is a newer oven, with a hidden bake element, they do take longer to preheat so may not have any problems, just give it about 15 minutes to preheat.
if it is older and doesnt bake right, then you may have a bad bake element.
the unit will heat but wont bake right.
unplug the oven and take the bake element to your local parts house, they can check it and sell you a new one if needed.
Jan 10, 2010 | Frigidaire Ovens
Gas oven not heating
Hi, the oven temp sensor is not registering correct temp signals. i recommend replacing the oven temp sensor asap.
Mar 24, 2009 | Frigidare FGB24S5DC Gas Single Oven
Only oven element will not heat
look on the oven element and see if you see any blow out holes,let me know-mike
Oct 07, 2008 | Frigidaire Ovens
Know display anel getting EXTREMELY hot
Laura_kucari
I think you are feeling the heat coming from the oven vent. The fan still runs as it tries to cool down the temp in the compartment housing the electronics.
Regards
Aug 31, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
OVEN TEMP STUCK ON 100F
check your house connections to the stove turn the breaker off first then reply to me
Jun 02, 2008 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
310 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
