Question about Kenmore 63942 Dryer
Fuses WHere do I find the Thermal Fuse my dryer will not start
  • 6 more comments
  • passion_1031 Mar 08, 2008
    got it fixed thx after $220 in parts it came down to the power cord....go figure
  • passion_1031 Mar 09, 2008
    Ok the repair man was wrong it was not our power cord after all. we are at a loss and have no idea where to go now please help its a Kenmore Ultra Fabric Care Model # 11086980800
    please help
    we replaced the power cord, the Thermal fuse and Thermal cutoff, also the timer and the power switches...checked the door latch switch power there. Repair guy said not enough power from the cord to dryer our wall outlet checked ok its got the right 220 power
  • passion_1031 Mar 10, 2008
    My Fuse was in the back under the panel along side the heating unit not sure on your model. We are still stumped why there is not enough power get'n to the dryer.
    My dryer does nothing at will not start... nothing. all and the # I posted is 11086980800
    we got all our parts through Sears with it we finaly gave up and called a repair man after $200. in parts and he said was the power cord then he left. I got a new cord and still nothing so he has to come back out to re evaluate it. I am hoping its an easy fix at this point. :(
  • pcolacchio Sep 22, 2008
    My Kenmore series 70 dryer will not heat.
    want to check thermal fuse but do not know where it is.
    model no. 68702894
    please help
    pat
  • acroisant Nov 30, 2008
    I have a Kenmoe electric dryer 90 series.
    I have replaced the themal fuses 4 times,
    It lasts a week or 2 and the blows again.
    My vent is NOT clogged
    At $35 every 2 weeks, thats more than the Laundry mat!
  • b75_richards Jan 19, 2009
    My dryer doesnt start. It has 220 coming from everywhere its suppose to. I wass told it was the thermal fuse but do nnot know where it is located I have a Kenmore Elite # 110.63942101 can any one help with its location?
  • Heather Tanner May 11, 2010
    If you list your model number, I should be able to tell you where it is located. The model number can most likely be found inside of the dryer door, on the back of the control console, or on the lower front of the machine.
The thermal fuse would generally be under the rear panel, mounted on the plastic outlet hose mount. This could be the problem to the dryer not turning on at all. Easy to replace (about $13), however, this would not cause a not having heat problem. It's a safety feature to prevent overheating and a fire. The no heat problem may very well stem from excessive lint in the hose itself. Good Luck!
TheMechanic
Posted on Oct 06, 2008
I can find the thermal fuse on my kenmore gas dryer model# 110 70982990
Posted on May 10, 2008
    Problem Solver:
  • 12 Answers
I think that if you have no heat it is the thermal fuse Sometimes the dryer won,t start if the thermal fuse is blown.Also why is the thermal fuse blown usally caused by clogged venting. If that doesn.t solve your problem there is a broken wire that has to be traced out.The thermal fuse is usally located near where you hook up the vent hose in behind the back panel. Good Luck
Eeggman
Posted on Mar 11, 2008
  • 52 Answers
Without your entire model number, it is hard for me to tell. There are numbers missing from the one you provided, which I assume are the first three numbers (they are bold, and don't appear to be part of the model number, but they are).
If I had to take a guess at it, I would assume that the dryer you have is similar to the one I have at home, and if so, the thermal fuse will be located behind the back panel of the dryer. Click here to see a picture of what it might look like.
Please let me know if you have any other questions. Thanks!
Posted on Mar 10, 2008
  • Heather Tanner Mar 10, 2008
    Check the terminal block with a meter to be sure it's getting 220. The terminal block is where the terminals for the cord connect. What is the problem you're having with the dryer exactly, ** heat?
We have Kenmore Elec Dryer - Model # 8860293, 70 Series. Where is the thermal fuse located? Dryer starts and shuts off in less than 5 seconds.
lantzer@hotmail.com
Posted on Mar 09, 2008
SOURCE: Dryer does not start - Thermal Fuse is ok.
My Maytag Electric Dryer stopped working mid cycle and wont turn on at all now. Any ideas?
Posted on Jan 06, 2009
localwonder
  • 6784 Answers
SOURCE: keep blowing fuses
hi, make sure you are using a time delay fuse and not a regular fuse. this may be the reason why the fuse keeps blowing out on your dryer.
Posted on Mar 09, 2009
  • 1122 Answers
SOURCE: location of thermal fuse on leq9858 l dryer whirlpool
if this is a top load?if so remove the back panel and you will see the dryer heater box to your right,the fuse is on the left side of box top,the high temp thermostat is on the bootm left and should be replaced also,before you do thatmif you have a meter remove the 2 wires from the heating element and check it on omns,no meter?remove the 2 screws pull the element off and look to see if the coil is broke anywhere,let me know how you do-mkie
Posted on Apr 20, 2009
rtillx4
  • 11 Answers
SOURCE: dryer won't run
I would say that maytag has a problem with lint collection. That is why so many thermal fuses blow and why so many people just bypass this "saftey" device rendering it more dangerous.
I would advise anyone with this model Maytag dryer to pull the front body panel and clean the lint out and then replace the thermal fuse.
Posted on Dec 16, 2009
  • 222 Answers
SOURCE: Maytag dryer is less than 3 years old. Blew
Have you tried replacing the operating thermastat it's what shuts it off at the right temp and would cause the thermal fuse to go if it is not shuting.off at the right temp. It happens.
Hope this helps.
Posted on Dec 05, 2010
Last nite mid cycle my 90 series dryer quit and now i cant get it to do anything. changed the fuses in the fuse box but still nothing . might it be the thermal fuse ?
may be the thermal fuse but here is a website that can help:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Feb 10, 2011 | Kenmore Dryers
Start light on but wont start
Well most gas dryers have one thermal fuse and some have two thermal fuses wired in series with the motor. If any of the thermal fuses are blown that could be one of the reasons of your dryer not starting. So first of all you may check out the fuse.
Good Luck!!
Thanks for using FixYa!!
Jan 26, 2011 | Maytag Neptune MDG5500AW Gas Dryer
I have Model # LER5636EQ3 dryer it all of a sudden quit working in the middle of a drying cycle. I Checked fuses in house all OK. Checked to see if other cycles worked will not start or make a sound at...
This problem is commonly caused by a blown thermal fuse located on the blower housing. The thermal fuse is wired in series with the motor and the motor activates a centrifugal switch for the heating element when it runs. These setup makes the dryer fail to start and the heating element not to turn on if the thermal fuse is blown. The dryer seems to no work at all. Verify the condition of the thermal fuse by bypassing it and starting the dryer.
Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the rear left bottom of the dryer cabinet. Remove the rear panel to access the blower housing and so the thermal fuse.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced along with the cycling thermostat if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
The thermal fuse and cycling thermostat are part numbers 3392519 and 3387134, respectively.
Dec 30, 2010 | Whirlpool LER5636P Electric Dryer
DRYER STOPPED RUNNING. ALL CONTROLS WORK, BUT WON'T START. HIGH LIMIT SWITCH GONE?
It's either of the thermal fuse on the blower housing or the thermal fuse on the heater enclosure is blown. These thermal fuses are wired in series with the motor and therefore, if any of them is blown will cause the motor not to run and hence the dryer not to work except the controls.
Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the dryer door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
Bypass the thermal fuse on the blower housing by disconnecting the wires and taping them together or connecting a jumper wire between them. Close the door then plug and start the dryer.
The dryer should start and heat up if the blower housing thermal fuse is the culprit. Otherwise, the other thermal fuse on the heater enclosure is blown. Unplug the dryer then bypass the thermal fuse on the heater enclosure in the same way the first is bypassed to confirm it.
Plug the dryer back then restart it. The dryer should start to confirm that the heater enclosure thermal fuse is blown. Replace the thermal fuse (part number 307473) together with the high-limit thermostat (part number 303396).
Unplug the dryer and unbypass the blower housing thermal fuse then plug it back and restart it. If the dryer fails to restart, replace also the blower housing thermal fuse (part number 33001762) together with the cycling thermostat.
Reinstall the front panel in reverse steps of the removal steps to complete the repair.
Aug 21, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Only buzzes when trying to start my LDE7304ACE Maytag electric dryer. the drum spins freely.
Verify and indicate in which part where the buzz is coming from. It's the timer motor if it's coming from behind the timer knob; otherwise, it is the dryer motor at the base of the dryer.
The drum belt has slipped off if the dryer motor is the one that buzzes and the dryer blows out hot air. Otherwise, the dryer motor (part number Y303358) is stuck; replace it.
Check the continuity of thermal fuses, one on the blower housing and one on the heater enclosure, if the buzzing sound is coming from the timer motor. These thermal fuses are wired in series with the dryer motor and will make it inoperable should any of the thermal fuses fail. Replace also the cycling thermostat should the thermal fuse (part number 306604) on the blower housing has failed and the high-limit thermostat should the thermal fuse (part number 307473) on the heater enclosure has failed.
May 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer won't run
thermal fused are one time fuses / maytag want's you to correct the problem that causes this . so dryer is safe. hi heat caused it to fail . so either the fan is not going or there is a restriction causing no air flow . try running the dryer off the vent if it works ok then clean the vent ,, hope this helped . pls leav feed back mm
Dec 14, 2009 | Maytag PYE2300AY Electric Dryer
Gorenje Tumble Dryer WT 881 - how do I replace heating element fuse?
I would start with house fuses or breakers, if breakers then turn breakers off then back on several times then try the dryer again. Then I would check the cord where it connects to the dryer. After that I would start checking elements, thermal overloads/cutoffs, etc. most dryers have several normally closed t'stat/ overloads and a thermal fuse. If the thermal fuse or cutoff is blown you also need to check your venting. these safety fuses are not resettable and are usually an indication that the vent may be clogged and/or obstructed.
Nov 04, 2008 | Dryers
Dryer wont start replace new swtich and new cord
Good Luck!!
Apr 06, 2008 | Dryers
Dryer doesn't start
The faint sound seems normal. Sounds like it could be a thermal fuse. Also if the dryer is electric check your breaker box first.(there are two breaker fuses for electric dryers).... If one is blown then it may cause this problem....... Back to thermal fuse, they are easy to check... If not thermal fuse it could be the start switch or relay...... if you still have problems please respond back with model and make...
Mar 30, 2008 | Dryers
Dryer wont run
Good Luck!!
Jan 11, 2008 | Kenmore Dryers
Kenmore 63942 Dryer Logo
1,083 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
