Question about Blaupunkt Woodstock DAB 52 CD Player
No Audio when fitted to new truck
I have had the DAB 52 working perfectly ok in an06 registered Leyland DAF truck. I now have an 08 registered Leyland DAF which came fitted with a Blaupunkt TRD 47. But when swap TRD 47 for the Woodstock it powers up Ok but I have no audio. I know that the Woodstock is ok as have tried it back in the old truck. In both Trucks I use the fitted ISO plugs neither of which have been changed in any way. Any help gratefully received
Eagleeyes
  • 199 Answers
SOURCE: Blaupunkt IDC A09
hi whats your email?
will email you.
mark
Posted on Jul 21, 2008
blueextc3221
  • 15935 Answers
SOURCE: No sound coming from speakers Blaupunkt GTA470 Amp
Amp Failure:
There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors:
In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals.
Posted on Dec 31, 2008
  • 5 Answers
SOURCE: car audio code
Need to contact previous/original vehicle owner who should have the security code recorded (or local distributor or car manufacturer with VIN number of your vehicle) - code is the biggest deterrant to would be thiefs
Posted on Jun 26, 2009
  • 4979 Answers
SOURCE: Blaupunkt GMBA radio to boxer van discnected to
The instructions should be one of these
http://www.radio-code.co.uk/post_in_radio_code_model_selection.php?m=Blaupunkt&search=peugeot&Submit=Search
Posted on Oct 16, 2009
SOURCE: blaupunkt cd autochanger doe not work.
bought replacement on ebay
Posted on Feb 09, 2010
Why wont my leyland daf 45 Horsebox start after it ran out of diesel then was refueled
you have to vent the air in the injection pump crack the injector pipes and crank the engine till fuel come out then re secure the pipes it will start then
Jul 28, 2014 | 1970 DAF 44
I Have a Leyland daf LF 45 When the engine warms up the turbo stops cuting in, I've had a fitter look at it and he said the turbos work and ideas any one thanks
turbos work from exhaust gas temperature and exhaust gas flow. There is nothing else that works them so can you be more specific as to what you mean by "stops cutting in"
Jun 21, 2014 | Cars & Trucks
Need a diagram for for heater fan in leyland daf 45 120
Blower motor resistor or heater fan resistor. It should be located in the plenum air flow to keep it relatively cool. Also check the wiring harness for any melted wires, or corroded connections on the resistor block. Any deformities in the plastic warrant replacement of that part of harness connector since I do not think your local vehicle inspection laws would allow it to be soldered to the harness.
Feb 12, 2012 | DAF 44 Cars & Trucks
What is the manafacturers recommendations for anti freeze in a m reg leyland daf 45
50/50 mix is the most you can go,,,this will stop it freezing well below -40F
i all ways go 50/50,
Dec 01, 2010 | E-Z Red S102 Anti-Freeze Hydrometer
FITTED A SONY CDX-DAB6650 RADIO BUT WHEN IT CHECKS
yes you prob will do as you need a very good signal for dab radio the one supplide is like using a wet peice of string ie not very good
Oct 12, 2009 | Sony Car Audio & Video
Codes
0= 98 BO BA 52 D3 21 08 B4
1= D2 EA 29 B7 B5 52 E9 AD
29TH NOV GOOD LUCK
Nov 29, 2008 | StarTech.com StarView SV211K 2-port KVM...
New codes
telepest codes 29TH NOVEMBER 2008
00=98 B0 BA 52 D3 21 08 B4
01=D2 EA 29 B7 B5 52 E9 AD
Codes for eurovox for virgin media please help me thanks
hi go to wizardmod co.uk .
download the keys tool bar and the keys worked for me.
u must register on this site other wise u cant download.
Blaupunkt Woodstock DAB 52 CD Player Logo
95 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
