Add slave hard drive
Want to add slave-seagate-20-u6 on pakard bell with a seagate-80-u6, no wizard cheers
  • ryanbridger Mar 08, 2008
    i have to admit i have only been doin this for for 2 weeks dont no all terminoligy, ur wright the ribbon connector is first 80 then 20 but what is jumpers is it a small cable inbeetween power and ribbon 2 connect both hard drives directly togehter thanx ryan ps cant swap master, slave ribbon till i switch of
  • 148 Answers
I am assuming IDE not SATA ? did you set the jumpers on the drives themselves? the seagate 80 to master the 20 to slave. The jumpers are on the front of the drives next to the connectors. Next connect to the motherboad behind the master drive or seperately on a 2nd IDE connector. If you are connecting both with one cable make sure the master is added to connector at the end of the cable.
Posted on Mar 08, 2008
  • TERRI RODDEN
    TERRI RODDEN Mar 08, 2008
    the jumpers are not a ribbon .. the jumpers sit between the IDE connector (connects between the motherboard and the harddrive) and the power connector (connects harddrive to power supply) ... take a look at this illustration
    http://www.seagate.com/images/support/en...
    hopefully there were jumpers accompanying the HDD when you bought them, if not you can probably take them from old harddrives or get them at any computer store. Again, you will set the 80 to master and the 20 to slave.
  • TERRI RODDEN
    btw .. you will only need one jumper as the slave drive is set to slave with no jumpers, remove the jumper from the 20G slave drive and you should be good to go.
My seagate is an old hard drive and I want to use it as a slave along with my Excelstor Drive. The Old drive cannot be detected in any way. Could anyone post a detailed step-by-step on how to get my...
Firstly check if the drive spins up, if it doesn't it means the drive is blown, and the only way that you could get that working is to replace the board, which can be tricky.
You would be better off getting a new drive altogether.
Nov 01, 2013 | Seagate U6 (ST340810A) 40 GB Hard Drive
What's your problem?IS MY SEAGATE ST380020A COMPATIBLE WITH MY SEAGATE ST3100011A
The compatibility issues would be with *********** board and your operating system support. Are they both SATA drives?
murf427
Aug 01, 2012 | Seagate U6 (ST380020A) 80 GB Hard Drive
Internal hdd made external
just buy an external enclosure with the correct output wires, most come with usb
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 11, 2012 | Seagate U6 (ST320410A) 20 GB Hard Drive
Not detecting hard disk. when i plug my IDE hard drive the red and yellow LED in my computer always light
Be sure about Master-slave pin jumper. If it is sharing same cable from main HDD please set it as slave, but if alone, then set is as master or Cable Select.
Dont forget to rate!
Jun 17, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
How to format IDE hard drive?
This drive is an IDE drive. The jumpers can be set on it to make it a slave.
Once set as a slave, you can identify the drive letter given to this drive and format it either at a command prompt: C:> format [drive:] /s (to make it bootable) or no /s to just format it.- OR within Windows: right click on the drive letter and select format.
Jun 01, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
How to make IDE slave hard drive?
You can make it slave with jumper settings check in back side of harddrive you can see jumper which is connected to 2 pin of harddrive.
Read instruction on harddrive you can read how to set jumper for make it slave.
Then you ca use it as slave.
Let me know if you need further assistance.
Thanks for using FixYa.
Computers & Internet Logo
336 people viewed this question
David Payne
David Payne
