Proline LD 1702W T.V. Sound/Vision failure
Can you possibly help with the following fault on my ProlineLD1702W TV:
Sudden collapse of the picture and sound. Video and sound disappeared and returned for a few moments then has now gone completely. 12V power supply checked out o.k.. At present the only indications are the green 'on' light and a faint ticking or 'knocking ' from the speakers, other wise a completely black screen. Any help would be most appreciated. Mike.
  • sjbaxter72 Sep 02, 2008
    I have a similar problem loss of picture first then no sound with the power supply light flickering and a ticking noise from it.
    I done a very technical thump of the transformer and the tv sprung back into life but only for a short while but i cant seem to find a suitable replacement transformer on the net...
Dear Team, many thanks for your call back re my Proline flat screen T.V.. ** the fault is still existing however after speaking to a couple of whizz bangs I have been pointed in the direction of dry or broken solder joints particularly in the power supply section. This I will look at tomorrow....Here's hoping anyway.
Posted on Mar 09, 2008
SOURCE:
What is an LD board/ LDHM board?
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Dec 22, 2016 | Sony Televison & Video
Why do I have sound and no picture on my vision 60 4k P Series tv
Contact the authorized service center. Your TV need a through checkup. Electro help
Mar 06, 2015 | Vision Televison & Video
My daugther's apex LD television model3288 32" isn't displaying a picture. I connected it to another cable box and we still can't anything. She can't find the remote and the tv hasn't been used in ove
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 13, 2014 | Televison & Video
My 42LH2000 tv has a problem with picture
possible lcd failure or time-control board failure maybe with a photo I might be able to answer more accurate for your problem !!!
Jul 04, 2014 | LG 42LH2000 42 in. HD-Ready LCD TV
I have a CRT tv and the picture is just a thin band in the centre of the picture tube. The sound is ok
That is called "Frame Collapse" because the picture "Frame" has collapsed into the single horizontal line.
It may be caused by dry joints or output failure of the frame output stage.
A fairly inexpensive repair.
Mar 03, 2011 | Panasonic TC-21PM10RQ 21" TV
There is a white horizotal line across the screen of sansui standard TV with a picture showing within this line. The sound is OK. What causes the problem?
Your fault it known as "frame collapse" because the pictures frame has collapsed. It may be caused by a bad solder joint or a failed component. Not a problem for a TV engineer.
Jan 31, 2011 | Televison & Video
Toshiba Model 53HX71: Bottom half of screen and sound is fine; top half of screen has collapsed to a horizontal line in the middle of the screen. Repairman I spoke to briefly said it probably won't be...
Hello
Your TV has vertcal scanning problem. All picture tube based TVs have, both vertical and horizontal scan to spread the picture to entire screen. When vertical scan section meets with a fault, the picture will collapse horizontally and fi horizontal scan section has a troubl, picture will collapse vertically. Your TV s fault , we technically say, to be vertical foldover. This is due to the vertical output section, a circuit part, inside the circuit board of your TV.
To rectify this fault you must open your TV. Unplugh it from the power socket, and open it. Locate the vertical output section, which is easy to do. Look at the deflection yoke, the coil fitted on the neck of the picture tube, and you will see four wires from it going to the main circuit board. Out of which, two will be thick, normally red and blue in colour, connected to the opposite direction on the deflection yoke, and the other two will be thin. follow the two thin wires, said later, and you will reach to a plug in point on the printed circuit board.
Before doing anything, just look at the soldering of that section carefully for any loose soldering, or bad soldering. Usually, the components in the vertical output section will get heated during working, and ahve a cahnce to get loose contacted soldering joints. Just resolder all the suspected points by applying a little more solder, and see the effect. If thi doesn't help, check the IC used in that section for trouble. Some capacitors will be there in this section, will get dried as aging, replace them first, as they are ver few in numbers, When replacing capacitors, note their polarity, as electrolytic capacitors have both positive and negative terminals like torch cells. Before replacing the vertical IC, replace all the capacitors, especially, two or three large capacitors on that section. Just do these and if you want any more assistance feel free to contact me through Fixya. OK
Dec 08, 2010 | Toshiba 27AF42 27" TV
Watching dvd, great pictue and all of a sudden black out
7 Blinks is the failure of the SC/SU/SD PCB's (1 2 or 3 depending on how lucky/unlucky) you are.
Panasonic have a great warranty usually. Give them a ring, it has failed.
The flashing LED is the fault code.
Sep 06, 2009 | Panasonic TH-42PZ77U TV
Blurry vision on picture
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | JVC AV-48WP30 48" Rear Projection...
Audio ok, but Video goes from color to black.
the tv turns on fine, but after 5 - 30 min or so, "sometimes MORE " the picture all of a sudden go's black. Sound is ok it is 100% loose contact problem. 1 please check for any connector or print for loose. 2 in signal processor ic there might be loose. remember there is no component failure.
Sep 24, 2007 | JVC AV-32D305 32" TV
Televison & Video Logo
214 people viewed this question
Top Televison & Video Experts
Ekse
