Question about Dell Inspiron 2650 Notebook
Replace cd drive
Dell inspiron 2650 cd removal
  • dvpogue Mar 08, 2008
    wanting to replace cd drive with dvd burner
  • 58 Answers
Hi there!
removing the optical drive is just easy. just follow these steps and let me know if you got it out. http://support.dell.com/support/edocs/systems/ins2600/en/sm_en/upgrades.htm#1013462
hope this helps!
Karlox
Posted on Mar 11, 2008
Dell Inspiron 2650 will not boot to Windows install CD after UBUNTU Linux installed on machine.
have you went onto the BIOS to make sure that the boot options are correct e.g. CD DRIVE 1st priority?
Aug 06, 2012 | Dell Inspiron 2650 Notebook
Got Dell Inspiron 2650 2002 from a friend, free. Want to restore to factory settings. How? Installed Windows XP and Norton Anti Virus
Hi and welcome to fixya!
There are two ways to restore this machine to factory settings;
First is thru the Recovdery partition in the hard disk itself:
  • 1 Close any windows currently open and click the Inspiron's "Start" button. Select "Shut Down" and choose the "Restart" option.
  • 2 Tap "F8" when the Dell image appears on the screen. Continue tapping the key until the advanced boot menu loads.
  • 3 Scroll down to "Repair Your Computer" and press "Enter" to access the DataSafe local backup screen. Click "Next." Select "Dell Factory Image Recovery and DataSafe options."
  • 4 Click the "Restore without preserving new or changed files" radio button and click "Next." Click "Next" three more times and click "Restart" to restore the disk drive to its original condition. Follow the on-screen prompts to set your operating system settings.
If the hdd was already repartitioned or corrupted, the second option should work:
  • 1 Insert the Dell recovery disk in your Inspiron's optical drive and close the "AutoPlay" window when it appears. Shut down any other open programs. Click "Start" and select "Restart."
  • 2 Tap "F2" as soon as the Dell image appears on the laptop's screen. Scroll to the "CD-ROM" option and press "Enter." Tap any key when you see the "Press any key to boot" option.
  • 3 Press "Enter" when the setup screen appears. Press "F8" and highlight the Dell's hard drive partition. Press "Enter."
  • 4 Follow the instructions on the screen to choose the Inspiron's operating system options. Click "Finish" and remove the recovery disk from the optical drive. Click "Start" and select "Restart."
Hope this helps!
Takasashi
Jul 19, 2011 | Dell Inspiron 2650 Notebook
Where is switch for wireless on inspiron 2650
hello,
the Dell Inspiron 2650 PC Notebook does not have a wireless lan services.
it only operates with a cabled network service.
take care
Jun 12, 2010 | Dell Inspiron 2650 Notebook
Does not reconize hard drive
turn off the laptop and then take out the hard drive from the laptop. Go ahead and reseat it back into its slot and then turn on the laptop and press F2 to go into the BIOS. It should see it in there. If it doesn't then you know the hard drive is bad and will need to be replaced.
May 18, 2009 | Dell Inspiron 2650 Notebook
Dell inspirion 2650 does not for mat hard drive it
you might have to Debug and then format the hard drive heres the link for debuging the harddrive and then try to format..hope this helps.
http://en.community.dell.com/forums/t/19020652.aspx?c=uk&l=en&cs=ukdhs1&s=dhs
Regards,
Khushroo
Mar 09, 2009 | Dell Inspiron 2650 Notebook
Dell Inspiron 2650 laptop is not recognizing hard drive
Do you have the dell diags cd that came with the computer.If you do ,boot to the cd and run a diag.Once in the menue do a quick test,check the device you want to check and wait for the result.You may want to test all devices since you want to make sure the computer is working and you might have only a failed hard drive.
Feb 22, 2009 | SimpleTech (STT440HD/40) 40 GB Hard Drive
How do I reinitialize my Dell Inspiron 2650?
You should have a CD that says something like OEM CD. Or OPERATING SYSTEM. Put that disc in and reboot your PC. You should see a prompt to press any key to boot from CD. Press enter and follow the prompts to reinstall your operating system... If you don't have that CD you'll need to purchase one from the store or look at installing a free Operating System like Linux. Option 3 (less likely) You have a recovery partition installed and you should see a prompt during boot up that says "press F10 to start recovery" in this case all of the information on that CD is store in that partition on your HD.
Jan 04, 2009 | Dell Inspiron 2650 Notebook
Keyboard
Try this:
Shut down, unplug the AC adaptor, removed the battery, and hold the power button for up to 1 minute to discharge.
Make sure there are no stuck keys.
Restart.
Apr 08, 2008 | Dell Inspiron 2650 Notebook
Dell Inspiron 2650 Boot problem
Hey, Ive had a few laptops with similiar problems. If there are no beeps then most likely there is a problem in the motherboard.
You could try removeing extra hardware like the cd/dvd drive and try to start up again but most likely the motherboard would need to be replaced.
In most cases the price comes near the price of a new laptop so it might be better to buy a new one.
You can remove your harddrive and buy a converter to connect it into your desktop pc or to your replacement laptop. to save your files.
If you need more asistance, let me know.
Mar 18, 2008 | Dell Inspiron 2650 Notebook
Dell Inspiron 2650 Notebook Logo
149 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
