Question about Kenmore Elite 45986 Front Load Washer
Tub smells of stagnant water
Have my Kenmore ELite a year and a half and recently there is a dreadful smell of stagnant/moldy water from the tub and clothes. Have tried washing at a high temp., with bleach, vinegar, etc.. nothing seems to work. I have to keep the door open at all times and it still persists. Called Kenmore and they were of no help. Any suggestions apart from ones already posted, as I have tried them all? My washing machine and the clothes washed in it have a musty, moldy odor. I have tried bleach but this only eliminates the odor for a few days. I have put baking soda in the machine washes and this helps for a few days as well.
  • 2 more comments
  • Anonymous Mar 13, 2008
    Same deal with smell of mildew in washer.  Tried tablets.......did not work for long
  • Totalhomeres Mar 15, 2008
    same problem my washer stinks of musty clothes like you left them in there for days! i tried hot water with bleach and 2nd wash with just downey. it help but did not slove the problem
  • carsensmom Mar 16, 2008
    We recently have the same problem. I don't have my owners manual, and my machine stops quite often & flashes F11, I do not know what this is... I thought maybe the smell was a result of F11. What ever that is, does your washer flash F11?
  • jillocain Oct 05, 2008
    I don't notice an order but I've found gunky gray matter in the rubber accordian type seal aroung the opening of the door. It's really hard to clean out and it's driving me crazy. Some of my clothes have had a gray spot on them and I think it's from this gunk.
There seems to be a common problem with this where the filter in the bottom of the unit gets plugged, and it can cause the unit to smell. Remove the bottom access panel, unscrew the filter, and clean it.
Make sure you UNPLUG the unit. Even though you won't be touching electrical, there is a very real chance that you can be shocked..or worse.
Let me know if that helps. Even if this solution doesn't work, it is a good idea to clean the unit occasionally. It uses a torx style screw, so you may have to buy the tool...but it's worth it.
Posted on Oct 19, 2008
    President:
  • Kenmore Master
  • 2,651 Answers
There sa new product on the market available at at major chains, and also online AFFRESH tabs!!!!!! works wonders for htat particular problem
Posted on Mar 08, 2008
My maytag neptune spins water out, the tub is empty but when you turn the tub manually you can hear water sloshing and the clothes smells moldy after washing
There will always be some residual water left in the outer tub after draining. This is normal for most washers. Purchase a container of Oxy-clean and cycle the washer a few times using hot water settings with a half-cup of Oxy-clean added to each cycle. This will help remove any organic matter left behind that might be causing odors.
Oct 15, 2014 | Maytag Neptune MAH5500B Front Load Washer
Kenmore Elite Ultrawash, possibly 11 years old, 665.155962990 toxic burning smell pumps and electricity work reading reviews for new dw's inclines me to want to have a repairman try - if the...
If you have a belt on this machine, I would change it. If the tub bearings are worn, then the motor will spin the belt faster then the tub/drum can turn causing burning. Worn pump or tub bearings can also cause this smell. Make sure pump is clean and tight.
Dec 31, 2010 | Kenmore Dishwashers
Neptune MLG2000A doesn't drain completely and has moldy smell
You need to clean the stationary "brush" that collects lint and debris from the water during the cycle. The brush can be seen around the tub directly touching it along the bottom/front of the device. Right were I pour my detergent in, after the cloths are in there. To remove the debris I use a bottle brush. You can expect to use trial and error for your attempts. As far as the water being left.... My device has always left water in the bowl. I periodically just run a cycle with no cloths and bleach...HOT.....Mine is not spinning at the moment...again....I think its another call to the local dealer....AGAIN....
Jun 11, 2010 | Maytag Neptune MLG2000A Front Load Stacked...
Brown dirt-like looking "gunk" coming out of the washer
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
Jan 10, 2009 | Kenmore 44832 Front Load Washer
Moldy smell
Turn it off, unplug it. Remove filter and check if filter and/or filter and pump housing are clogged with something "smelly". When you're at it check the drain pipe for too.
May 08, 2008 | Kenmore Elite 45986 Front Load Washer
Moldy smell in front load kenmore washer
I had the same problem. Have you cleaned the filter under the front panel? Simply remove the three screws holding the panel below the door and remove the 2" white screwcap. Be sure to have a basin handy to catch the water. (possibly a couple of gallons if the stainer is really clogged) I suspect you'll find several moldy items that are causing the odor. Good luck.
Feb 28, 2008 | GE WSXH208A Front Load Washer
My Kenmore Elite He3 sounds like it has water in the tub after washing AND smells of MOLD?
there is always some water left inside the machine and that is probably what you are hearing are you using liquid detergent? if so this is almost certainly the cause of the smell. liquid detergent leaves a nasty slime inside thge machine and smells like drains. put on a boil wash with no clothes and revert to using powder detergent
Apr 02, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Set the water level to it's highest level and let it fill on hot. When it starts to agitate, stop the machine and add 2 gallons of hot water to raise the level above the tub ring. Add 2 cups of bleach and 2 cups of powdered dishwashing detergent. Let it agitate for several minutes and stop it again. Let it sit for several hours. Then let it finish it's complete cycle. This should elimate your odor..
Jun 05, 2006 | Kenmore 15864/15862 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
274 people viewed this question
Sal De
fordexpert
Robert Rankin
