Question about Samsung RS2630SH Side by Side Refrigerator
FREEZER SOUNDS VERY NOISY
SOUNDS LIKE FAN BROKEN IN FREZZER. NOISE STOPS WHEN DOOR IS OPEN SAME PROBLEM,FREEZER SOUNDS VERY NOISY WHEN DOOR IS CLOSE,AND STOPS WHEN DOOR IS OPEN
SAMSUNG RS269LARS (MODEL)
  • 2 more comments
  • Anonymous Mar 26, 2014
    When the doors are closed the fan is very loud. When they are open the noise goes away
  • Anonymous Mar 30, 2014
    Very loud noise like fan a fan but it quits when you open the doors
    Noise is there when the fridge dors are closed stops when the doors are open freezer door doesn't make any difference if it is open or closed the noise is still there
  • Steve S
    Steve S Apr 09, 2017
    Common Samsung problem with ice buildup on coils near fan. Fix: remove back panel defrost Coils, then move the frost sensor from right side of coils (clip on to coils sensor 2 wires) so that it continues defrosting if ice is present on coils by the fan. Just defrosting will only be a temporary fix. Ice will come back. Relocating sensor allows the defrost system to detect ice on coils near the fan and continue operating until fully defrosted.
    Brigadier General:
  • 3,614 Answers
Fridge problem could be the fan is bad or that it is hitting ice. When the noise is kind of a buzzing like it is hitting ice...defrost your unit by unplugging and waiting a day or so for full melt out...then check your door gaskets for cleanliness and good seal.
Thanks.
Posted on Mar 08, 2008
  • micromaster
    micromaster Mar 08, 2008
    Check the cooling fan behind the unit, behind the lower panel access.
    Or could be the bearings are probably wore out. If they get dry due to no lubrication they will whine while running. May just need a new fan motor.
    For such replacement:
    Replaced the cooling unit as a whole. The fan blades may be out of balance or cracked. If the motor has ben seezed for some time, you may want to replace it as well. The motor was $79 alone, but $89 for the entire unit.
    Guru:
  • 1,894 Answers
Hello sir
  • dewan nafees ahmed Mar 08, 2008
    this is a fan in the freezer that circulates the cold air between the FZ and FF sections.
    The fan motor may need to be replaced.
When freezer drawer is closed, very noisy. Noise stops when you open freezer door. Is is the fan?
It sure sounds like the fan is either just going bad or there is possibly is hitting the blades. if it is a buzzing sound then ice is probably the problem. if it is a rattle or squeal then the motor is bad.
Mar 13, 2015 | Samsung RF4267HARS Stainless Steel French...
My LG ice maker fan is making a really loud noise right after the water stops going in
Hello, Self-defrosting refrigerators use a circulating fan to move air through the freezer and refrigerator compartment. This fan runs when ever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall,near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, half way up or near the top.
Overtime the fan may become noisy, usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise,just open the freezer door and push in any fan/light switches, if the noise is louder when the door is open, the evaporator fan motor is the cause. You can lubricate or repair this motor. You must replace it.
There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor(if self-defrosting), or the defrost timer (if self-defrosting).
Thanks
Jun 17, 2010 | LG LSC26905TT Side by Side Refrigerator
With the doors closed, the refrigerator is making a noise like a fan rubbing. When we open the doors, the noise immediately stops
That is because the fan has no resistance when drawing in air from the outside. When the door is closed, it becomes a sealed environment, and now must circulate air from the freezer to the refrigerator compartment. Sometimes a noisy fan indicates a frost buildup and the defrost system must be serviced. This consists of a defrost timer, Defrost thermostat, and defrost heater. Any one of those 3 may need to be replaced.
Mar 10, 2010 | Refrigerators
Buzzing sound
If noise stops when you open the door, you may have a noisy fan (or could have ice build up, causing fan blade to hit ice and cause noise). I gather it is a frost-free model ie has a fan in the freezer compartment. If noise is caused by fan hitting ice build up, you may have a problem with the auto defrost system, as you should not get ice build up in a frost free.
Noise stops when you open door because fan turns off when door is opened.
Aug 09, 2009 | LG Refrigerators
I turn off the power of refrigerator for 24 hours and defrost the frezzer. The noisy sound stopped. I think sometimes we did not close refrigerator tightly, the ice built up caused the problem.
Jan 04, 2009 | Jenn-Air JCD2389G Side by Side...
that because the internal fan is hiting the ice or has bad bushings you can hear the noise just with the door close because when you open the door there is a switch the one turns off the internal fan so when you close the door it turn on the fan again if you wants to hear that with the door open just open the door and push the botton swich with your fingers and you'll hear the noise
Dec 29, 2007 | Freezers
It could be the fan is bad or that it is hitting ice. If the noise is kind of a buzzing like it is hitting ice...defrost your unit by unplugging and waiting a day or so for full melt out...then check your door gaskets for cleanliness and good seal. Avoid 'windowshopping".
Dec 22, 2007 | Samsung RS2630SH Side by Side Refrigerator
Noise Problem
Is it a frost free freezer ? if it is it sounds like the evaporator fan motor making the noise
Aug 29, 2007 | Danby 16.7 cu. ft. / 473 liter Upright...
Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
May 07, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
575 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
