Question about Dryers
The dryer just makes a humming noise when I turn it on, but won't turn all the way on
    Novelist:
  • 142 Answers
When you say it won't turn all the way on, does that mean the drum isn't rotating?
If yes, the belt from the motor that goes around the drum might have broken and you can hear the hum of the motor spinning but no longer rotating the drum.
The other thing I can think of is that the motor itself has failed, possibly seized, and you can hear the motor trying to spin but it cannot. With the dryer unplugged and empty of clothes, try to rotate the drum. If it rotates extreamly easily, then the belt has broken. If you cannot rotate it at all by hand, then chances are the motor is seized. It should rotate with moderate effort.
Posted on Mar 08, 2008
ginko
  • 19396 Answers
SOURCE: Frigidaire Dryer
If Dryer does not tumble , check the following:
" It won't tumble If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it."Source Repaiclinic
Posted on Sep 08, 2008
  • 163 Answers
SOURCE: dryer makes a humming or buzzing noise and the
motor is going bad.
Posted on Mar 08, 2009
  • 1122 Answers
SOURCE: My kenmore dryer 90 serise won't start...makes humming sound....
your dryer motor is shot,it is to weak to kick on,sorry-mike
Posted on Jun 03, 2009
hunter19_46m
  • 7482 Answers
SOURCE: dryer drum won't turn...makes a humming noise
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Please do not forget to rate me
Thank you
Posted on May 15, 2010
Testimonial: "thank you so much for getting back to me......I think your diagnosis is probably correct so will try to repair."
  • 489 Answers
SOURCE: Dryer makes loud humming noise
Check to see if the drum will turn by hand. If so, leave the door open but push the light switch button down and start the unit. Once you hear the humming sound, manually turn the drum with your hand to start. If the drum turns normally, you have a bad motor and needs to be replaced. If the drum does not turn, something is jamming the motor and needs to be disassembled and inspected.
Good luck
Posted on Oct 04, 2010
Whirlpool dryer won't spin
Most dyers after you pull the top up, the front should just lift a little and it should come loose, sounds like you may have the belt intact, but the motor is not conected to the belt.
Jan 12, 2013 | Whirlpool Dryers
Indesit G74V dryer won't spin
Some dryers have a belt tension idler and switch combination that works to keep the belt under tension and shuts down the dryer if the belt breaks or falls off.
Apr 28, 2017 | Dryers
Frigidaire dryer not working drum won't spin,
Hi How old is it , ? and dose it soun like the motor is running but not turnning the drum ? this would be a bad belt , you will need to do some more investagating for me to help you
Dec 06, 2011 | Frigidaire Dryers
Has power. drum won't spin. Makes a humming noise. Lint trap & hose are clear. Was running fine.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 14, 2011 | Whirlpool Dryers
When I push the button to turn on its making a a humming noise and won't turn on. Its less than 2 years old
heatman101
Aug 11, 2011 | Frigidaire Dryers
I get a loud humming noise . The dryer works good but makes a loud humming noise when it's working .
The motor is going bad and this will make that loud humming when it is running...
heatman101
Sep 25, 2010 | Maytag Dryers
Dryer makes humming noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
bb
May 15, 2010 | LG DLE2512W Electric Dryer
Hums when turned on-won't turn over
belt may have broke. if you are hearing a humming sound . thats the motor .whitch is good, sounds like the belt broke or slipped off.
Sep 12, 2009 | Kenmore 73952 Gas Dryer
Dryers Logo
392 people viewed this question
Top Dryers Experts
Marvin
Marvin
