Question about SanDisk Sansa e260 MP3 Player
Sansa Rhapsody E260 will not let me delete folders and songs on the player. Has lots of "Bad Songs" but can't format or get rid of them. Help!?
  • 8,596 Answers
Use Windows Media Player instead.
Posted on May 23, 2008
Windows mEDIA PLAYER SAYs my sansae260 is full, but device won't sync. It says no song. I tried to reset, but still says no song
change the usb modes also....MSC will allow you to see the expansion card ( 2Gig E200 series 4gig Fuze) mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion.....
Delete songs and Format (Helps with trying to delete BAD TRACKS and folders that will not delete full memory(Some ripped CD folders).. Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders themselves then format a couple of times hope this works
Jun 21, 2010 | SanDisk Sansa e260 MP3 Player
Deleted songs from sansa e260 still show up on the menu
Turn the player off.
Push the HOLD button to the locked position.
Press and hold the RECORD button while connecting to PC.
Let go of RECORD button when you see Welcome to Recovery Mode on the player's LCD.
You are now connected in, you guessed it, Recovery Mode. Open My Computer and you will find a new removable flash drive labeled, 16MB-FORMAT.
DO NOT ATTEMPT TO FORMAT THE 16MB-FORMAT VOLUME!!!
Open the 16MB-FORMAT volume in My Computer and create a new folder on the drive in its root directory. Name the folder sansa.fmt, use the Safely Remove Hardware icon in the system tray, and disconnect the player from the PC. The player should now format itself. If all goes well the format will be successful. If not, I suspect you might have a defective internal memory module. If it is defective, you can replace it with one from another v1 or Rhapsody model unit. You can often find defective players on eBay for parts. The memory module from the e250, e260, e270, or e280 will work just so long as its from a v1 or R model.
Aug 28, 2009 | SanDisk Sansa e260 MP3 Player
Deleting songs.
Your DB might be corrupt. Folow the delete procedure one more time:
Delete Music Files
1) Connect your Sansa to the computer.
2) Select Open device to view files using Windows Explorer on initial
connection.
3) Select the place where you want to delete music files from
4) Highlight and delete the music file/s or folder from My Computer\Sansa
e200\...\MUSIC
folder. (You can also select from a variety of music
software programs to transfer/synchronize your files).
If that fails, go ahead and update the firmware - it will delete everything, and allow you to start over from scratch among other things.
-Tha Mp3 Doctor
Feb 16, 2009 | SanDisk Sansa E280 MP3 Player
Royally screwed up e260
help! i have tried to download my copied cds through rhapsody & windows media player. nothing happens in rhapsody & windows gives me an error occurred message after each song when i try to copy to e260.
thanks for your input,
trish127
Mar 21, 2008 | SanDisk Sansa e260 MP3 Player
Music files corrupted, then disappeared
I had something similar happen to mine (corrupted music files). In Explorer right click on your F: drive, choose Properties, go to the Tools tab and then click the Check Now for error checking. Check both boxes then click Start. Once finished go back into Explorer, click on the Tools Menu, choose Folder Options, in the windows that comes up click on the View tab. In the Advanced settings section click the Show Hidden Files and Folders, then click OK. Now look at your F: drive and see what is there. There should be a MUSIC, PHOTO, PICTURES, PLAYLISTS, RECORD, SYSTEM, TMP, & VIDEO folders. Look in the MUSIC folder to see what music is in there. See it they still show up as corrupt when you turn on your Sansa. If so you may need to delete all the music files in the MUSIC folder and re-copy them to the device. Also, if you see any folders call FOUND.000 I would delete them, these will contain corrupted files that Windows found when checking the drive and are now useless too you. Hope this helps.
Jan 31, 2008 | SanDisk Sansa e260 MP3 Player
How to delete songs from rhapsody channels
go to rhapsody and go to where it says sansa. it will show all of your music. right click any song and the option to delete will appear
Dec 28, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e260 How to delete songs ?
This MIGHT fix the problem: Make sure that Windows Explorer is set to show hidden files and folders. In Windows XP, click TOOLS, FOLDER OPTIONS, VIEW and make sure you have selected "Show hidden files and folders".
Jun 15, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e250 getting worse since "upgrade"
Format your player and re-transfer your songs. The best way to format the player is by changing the player to MSC, then connect it to your computer and open My Computer and right-click and format the player remove the quick format then click start. :D
Jun 11, 2007 | SanDisk Sansa e250 MP3 Player
Help
Hi tater. Hmmm. The product category you selected is for a Standard E260. But if your player is an E250R (Rhapsody player), here's a set of procedures that might help you. Deleting songs from your E250R can be done in 2 ways: By using Windows Media Player 10 or 11, or by browsing the player through Windows Explorer. Before you delete files, though, it's important to know that your player comes in 2 modes: "Rhapsody" and "PlaysForSure". The reason why is that music files saved in one mode would not be seen in the other mode, and vice versa. Therefore, if you can't find the music files in your player, switch to the other mode. Here's how to do it: Use the "Menu" button to navigate the player as follows: Menu > Settings > Mode > This will give you the option of: "Rhapsody" and "PlaysForSure". Here's how to delete your songs: (1) By Using WIndows Media Player: > Plug your Sansa to your computer and open your Windows Media Player. > If your Windows Media Player is version 10, then click on the "Sync" tab and you should see your player ("E250R") on the right pane along with its folders, named "Data" and "Media" or "Music". Expand the "Media" folder and you'll see the "Music" folder containing your songs. Right-click on a song and select "Remove" to delete them. > If your Windows Media Player is version 11, then either click on the "Sync" or "Library" tab and you'll see your player listed on the left pane. The music files will be displayed on the center window. Right-click on a song and select "Delete" to delete the songs. (2) By browsing the player in Windows Explorer Note: the folders containing the music files on your player are "Hidden" and you would need to set your Windows Explorer to show "Hidden Files and Folders". Open your Explorer, select "Tools" on the top menu, select "Folder Options", select the "View" tab and enable the "Show Hidden Files and Folders" radio button. > Plug your Sansa to your computer and open your Windows Explorer > If your player is in "PlaysForSure" mode, then your player will be recognized as a "Portable Media Device". Double left-click on your Sansa E250R and you'll see 2 sub-folders named "Data" and "Media". Open the "Media" folder and you'll find sub-folders normally named after the Artist. Your songs are located on those Artist folders. Delete them by using the keyboard "Delete" key or right-click the file and select "Delete" > If your player is in "Rhapsody" mode, then your player will be recognized as a "Removable Drive" with a drive letter. Double left-click on your Sansa E250R and you'll see the following sub-folders: "Albums", "Music", "Photo", "Pictures", "Playlist", etc. Your songs can be found in the "Music" sub-folder. Delete them by using the keyboard "Delete" key or right-click the file and select "Delete" I hope this procedure helps. A bit lengthy but, hey, it worked for me (lol).
Apr 27, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk e260R 4.0G - Getting rid of Rhapsody
I had the same problem. In the end I reformatted the e200. To reformat hook up to your pc and there should be a reformat option on the e200 icon.
Feb 07, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
49 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
