Question about IBM Wheelwriter 30 Typewriter
Ibm wheelwriter 6
I need to know how to print and save forms i lost the instruction manual
  • troymurach Mar 10, 2008
    That was very helpful thank you. How do i play the entire list of stored items? and how do I delete them?
    thank you very much.
  • 478 Answers
1press and hold the code key and type the # 1 thru 99 wher you want to store the job(chose any one number)
2 the store light should blink
3 the ARtn light comes on
4 the carrier returnes to the left margin
4 the printwheel spins
5you may begin typing when the store light is on solid
6 let the carrier return automatically at the end of each line of type
7close the store when finished by pressing and releasing the store key
Posted on Mar 10, 2008
  • James Cagle
    James Cagle Mar 10, 2008
    Playing the directory
    1 be sure the store light is off
    2 insert paper into the typewriter
    3 hold down the code keyand press the D key
    Deleting storred job
    1 press and hold down the DEL while you type the number of the job you want to delete.
    Delete all stored jobs
    1hold down CODE+SHIFT while pressing DEL
IBM Wheelwriter 6 powers up, then beeps. No lights, changed batteries. What is problem?
I have an instruction manual for IBM Wheelwriter 1000. The troubleshooting page in my manual for the machine coming on and having no lights is to make sure the cord is securely plugged into the typewriter and the wall or power strip and to switch the machine off and back on. Mine has a power saving mode where the lights go off after a while to enter power saving mode. I only need to touch a key to turn it back on.
Hope this helps - Cindy
Nov 06, 2014 | IBM Wheelwriter 6 Typewriter
IBM Wheelwriter 6 typewriter. The print wheel does not move when typing and acts as if in stencil mode
From your posting it sounds like you have cracked plastic print solenoid cap. We sell them for 20.00 with instructions.
DickyO
216-269-3918
Apr 29, 2014 | IBM Wheelwriter 6 Typewriter
Ribbon will work in one Wheelwriter 6, no print output in another one
Your print solenoid probably has a broken cap. There are some companies that sell the "kit" with instructions on how to replace the cap.
Jan 16, 2014 | IBM Wheelwriter 6 Typewriter
I have a wheelwriter 6 type 674X IBM typewriter. I do not have a manual, and it seems like it has started striking softer and not making a very legible letter. How can I change the setting to make it...
First try a little WD40 on the print solenoid plunger, If that dosen't help you probably have a broken plastic print solenoid cap. We vsell replacements for 20.00 including instructions and shipping.
DickyO
Cleveland Business Machines
216-241-0027
Sep 30, 2010 | IBM Wheelwriter 6 Typewriter
How do I make key srrike harder on an ibm Wheelwriter 6? The print is to light on carboned forms.
The print solenoid cap is probably cracked or the solenoid is gummed up or there is som debris in the print area. Look for debris, Give the back side of the solenoid located just inside the L. printer side frame under the ribbon. If these don't help we sell the cap with instructions and shipping fot 20.00.
DickyO
216-241-0027
May 15, 2010 | Office Equipment & Supplies
Wheelwriter 6 stopped printing. everything works
Tou most likely have a broken print solenoid cap. We sell them for 20.00 includes instructions and shipping.
DickyO
216-242-0027
Apr 23, 2010 | IBM Wheelwriter 30 Typewriter
How do I make key srrike harder on an IBM Wheelwriter 6? The print is to light on carboned forms.
If it prints well on 20# bond and the carbons the problem may well be the paper the forms is printed on. Otherwise the print solenoid cap may be cracked. You can try a Lexmark Brand #1380999 for hard to image paper. There are some circular plastic shims on the front side of the solenoid, remove one and it will print darker. If you need the solenoid cap we bsell them with instructions and shipping for 20.00.
DickyO
216-241-0027
Mar 29, 2010 | IBM Office Equipment & Supplies
No user manual for my IBM Wheelwriter 6
You can download the IBM Wheelwriter 6 series II 6784 Operator 's Guide from Lexmark site (look for "IBM Typewriters" in the bottom of the page):
http://images.lexmark.com/publications/pdfs/2007/index/en.html
If all you remember is the # 80, maybe what you have to do is insert the the paper in the machine and then press [PLAY] + the number 80 and, then, each time the playback stops at a stop point, type the variable text to be inserted (check the " Playing back a repetitive letter" section of the manual).
You can also get a print "directory" of all text stored (check the "Advanced Storage" chapter).
Hope this helps.
Jul 23, 2009 | Lexmark Office Equipment & Supplies
IBM wheelwriter 6
If this ia a wheelwriter 6 on the l. side of the keyboard are 3 keys store, play & delete. To store hold store and press an address 01-99, rel the store key, type info., then press store again. To print hold play and type address 01-99 info. will print.
Dicky O
Oct 31, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 15 Series II-Program the memory
The WW15 does not have a recallable memory, it has a reprint memory that will repeat what you have JUST typed, code reprt top left kry on the keyboard will activate if you want a full memory get a WW5 or 6.
Dicky O
May 05, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Typewriter Logo
145 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
