Question about Sis 6326, (4 MB) Graphic Card
Sis 672 series-mirage3+
I used lcd tv-sony bravia-as pc monitor,but my display card can not give resolution more than 1024-765
  • 1 more comment
  • Anonymous Nov 27, 2008
    jai une carte graphic sis mirage3+ de capacité de 128 mai pourtant il arrive meme pas a fonctionner des jeux demandant une memoire de de 64 very bad mark
  • Anonymous Jan 07, 2009
    Have this Graffic 3d function?
  • b7bkya3omry
    b7bkya3omry Oct 28, 2012
    thank
  • 73 Answers
Hi samsoon,
the graphic cards does not support.its resolution will be less than 1024-765 but not more for that u have purchased a new one such as nvidia that will solve ur problem
shailesh
Posted on Mar 10, 2008
Thank
Posted on Oct 28, 2012
Thank you
Posted on May 16, 2008
ASUS P4SP-MX detect the new LCD monitor VH197D as an CRT. picture is stretched; circle's becoming a ellipse. Can you help me!?
Wide screen monitor distortionDepending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down theShift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolutionslider, increase or decrease the screen resolution then bring the circle imageto the front and check the image, if the circle is still distorted then changethe screen resolution and check the circle again until you are satisfied withthe image of the circle. When you are satisfied then click apply.
Feb 21, 2012 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
How to get 1080p - it is only showing 720p
TV will display what it is being fed with, the signal sources will tell what resolution the TV to display, just like your PC where you set the resolution at the PC not at the monitor.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Aug 08, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I'm trying to use my bravia as a computer monitor.
Your Bravia should have a 15 pin PC input, this input can take most standard PC resolutions, however if you a have a video card with an HDMI port, you should set your resolution to 1920 x 1080 @ 60Hz refresh rate so that the signal can be recognized and processed, many standard PC video resolutions are not compatible with the HDMI inputs. You should not require audio cables unless you are using a DVI to HDMI connection.
Crampy
Dec 11, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
LCD not being detected
Restart computer -> Keep tapping on F8 key till safe mode option appears-> login using safe mode -> when login complete -> rightclick on my computer -> properties-> hardware tab -> Device Manager -> click on Sub-option "Display Adapters"-> Right click the adapter inside -> properties -> driver tab -> rollback drivers.
Follow instructions and restart and choose normal windows if asked.
If not successful, goto start -> all programs -> Accessories -> System tools, -> system resore -> choose restore to a previous... -> choose a date before the date you updated drivers. dont go 3-4 month, you might loose data. choose a closer date to the date you found the issue. follow the instructions.
restarts automatically and recovery screen comes. dont worry this is normal. when done, restart the system and see if resolution is alright.
get back to us with what has happened, we will support you further.
thanks, have a nice day....
Sep 16, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Sony KDL-40WL140 vs KDL-40Z4100
KDL40Z4100 Product Features
  • 16:9 Full HD 1080p Resolution (1920x1080p) LCD Panel
  • Motionflow 120Hz; improves TV & DVD viewing
  • DMeX compatible; allows seamless feature upgrades
  • DLNA® Compliant - view photos from another room
  • HDMI x4, HD Component x2, PC Input
Technical Details
  • Brand Name: Sony
  • Model: KDL-40Z4100/B
  • Display Technology: TFT active matrix
  • Display Size: 40 inches
  • Image Aspect Ratio: 16:9
  • is_hdtv_compatible: Y
  • speakers_included_description: 2 speakers
  • Height: 23.9 inches
  • Width: 37.2 inches
  • Depth: 2.8 inches
  • Weight: 39.7 pounds
  • Refresh Rate: 120
KDL-40WL140 Product Features
  • Motionflow™ 120Hz - clear, smooth motion for DVDs, TV
  • DMex ™ compatible; allows seamless feature upgrades
  • Enhanced XMB™ with 3D graphics incl. TV Guide
  • HDMI™ x4, HD Component x2, PC Input
Technical Details
  • Brand Name: Sony
  • Model: KDL-40W4100
  • Height: 25.4 inches
  • Width: 38.8 inches
  • Depth: 4.3 inches
  • Weight: 44.1 pounds
  • Refresh Rate: 120
Bottom line for the extra connectivity and DLNA certification i would go with the
Bravia Z-Series KDL-40Z4100/B 40-Inch 1080pBecause if you connect this to your in home network you can stream music videos and music off you PC onto your TV without the need for extra wired or memory cards etc.
Otherwise if you don't need this feature the other options are identical on the other TV so it is just as good a choice.
May 25, 2009 | Sony Bravia Z KDL40Z4100 TV
Connecting Vostro 1400 to Sony Bravia BR6?
To properly drive your TV set, your computer will have to be able to supply 1366 x 768 with a 60 Hz refresh rate.
A resolution of 1280 X 800 is high. LCD and Plasma sets are very critical for the maximum resolution. You can go lower but not higher. If a lower than native resolution is used there may be some aspect ratio distortion, and the picture quality will be degraded.
There is a spec list at the link below:
bravia-kdl-v40xbr1/4507-6482_7-31470102.html?tag=mncol;psum">http://reviews.cnet.com/flat-panel-tvs/sony-bravia-kdl-v40xbr1/4507-6482_7-31470102.html?tag=mncol;psum
Jerry G.
Jan 29, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Pc setting for sony bravia
'Unsupported Signal' Error indicates that TV is accepting the signals for Video but not able to display because resolution doesn't matches. Else the message would be 'No Signal'.
Follow the steps-
NOTE- Make sure cable is 15 pin(at both ends) VGA cable, working fine between PC & Monitor.
1.The standard resolution of laptop(any) which would support is 1024*768.
2. Toggle the display output from Laptop Fn Keys depending on Laptop Brand.
3. Connect the cable after settings made.
Also PC Settings will not be highlighted until connection is made.
Jan 20, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
PC input to Sony Bravia - from Sony Vaio Laptop - unsupported sig
"Unsupported signal" suggests one of two things. Either the refresh rate on your computer is set too high (it MUST be at 60 Hz.) or you have the display resolution set too high
Nov 15, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sis 6326, (4 MB) Graphic Card Logo
3,529 people viewed this question
Top Sis Computers & Internet Experts
ashu k...........
Level 1 Expert
David
David
Alun Cox
Are you a Sis Computer and Internet Expert? Answer questions, earn points and help others
