Question about Panasonic SC-HT895 System
110v - 220v power short problem
We recently plugged in our home theatre system that was purchased in the US (110v) into an outlet in India (220v). We did not see the instructions to flip the switch in the back to 220v before plugging it in. Now the player does not even power up (it did power up a few times initially before finally giving in).
Just wanted to know if something can be done to fix this...
  • tarek_25 Sep 09, 2008
    I plugged a sharper image massager in a 220v outlet.OOPS!
    Anybody you know does repair in southern California. Is it worth fixing?
No major worries. Only "Fuse" would have gone. You can get this replaced with some good electronic repair shops. Might charge you around Rs. 100 (else Rs. 500 since it is a "US return" item :) )
Posted on Feb 03, 2010
Can harmony touch work in country with 220 volt. Does it control the home theatre lights also
Your Logitech remote should be able to work on a 220 volt system so ling as the AC adaptor that plugs between the wall and the charger is rated 110-220v. Unplug it from the wall an read what it says on the outside. In should say "Input 110-220v" to be safe to put on a 220 system. If it is only rated 110v input power, you may need to purchase a universal power adaptor in order to provide power to the charging cradle. Another solution is to buy a "power transformer" which is a box that plugs into the wall and steps down the voltage and provides an outlet that can be used to power multiple 110 devices. What ever you do, do not plug in a 110v only device into a 220v circuit. If you do, it will "fry" the electronics rendering them useless, but it could potentially even start a fire.
With regard to your lighting system, the Harmony will emulate just about any remote controlled system that uses an IR signal. You may just need to program that device into your remote. Since you will not always want lights on or off during a movie, I would teach the remote the the audio systems * key is the same IR command as your lighting system. That way you can control the lights at the push of a button, independent of that activity.
Feb 02, 2014 | Logitech Harmony One Advanced Universal...
I accidentally plugged in my pulmoneb in a 220v outlet
plugging a 110v device into a 220v outlet is not likely, as the plugs are a different configuration. In the event that you somehow managed to do that, your device is probably fried, as that would be to much voltage. Hate to say it; but you are probably gonna need a new one
Nov 27, 2012 | DeVilbiss PulmoNeb Compressor Nebulizer...
How to use it if we have 220V outlet?
If the AC unit is 110V then you must plug it into a regular 110V outlet. You cannot plug it into the 220V outlet. Either get a bigger 220V unit or use a 12 gauge extension cord to get it to a 110V outlet.
Sep 06, 2011 | Haier Mechanical Air Conditioner HWF05XC7
My son accidentally plug a 110v bose 3-2-1 to a 220v outlet. What do you think is the damage? Do we still need to send it to a service center?
If you are lucky you would have lost the fuse on the sub woofer module which powers the whole unit. If not, yes you will need a qualified technician to look into the matter because its not a small offense to plug a 110 device into 220v.
Jul 06, 2011 | Bose 3 2 1 GSX System
I wanted to purchase a Bose companion 3 set from the US through ebay. i wanted to know whether they work on 220V and if not how can I make them work at 220V.
Since this unit dose not come with power adaptor. It has direct plug in in to the port behind the sub-woofer unit and other end to the wall outlet. Is there any way to convert the power supply from UK to US (220v to 110v). For example Desktop PCs have a switch behind every desktop unit to change power from 110v to 220v or vise versa.
Anyone has any idea how to make this happen in Bose Companion 3 system.
I bought it from UK and now moved to US and I want it to work in US.
othervise use waltage adapter to use it
Aug 08, 2010 | Bose Companion 3 Computer Speakers
My system 110v mode i am connect 220v now not working my be what is the problem
your power supply is shorted.. make sure to connect your new power supply to the actual voltage .. 220V is for 220V input PSU.... if you connect your 110V PSU to 220V outlet... it will fry your power supply..
May 24, 2010 | Gigabyte GA-945GZM-S2 Motherboard
Toshiba Laptop not charging
So confusing...Laptop AC Adapter nowadays has AUTOMATIC VOLTAGE, meaning it doesn't matter if it is 110v or 220v. Maybe you've got a FAULTY BATTERY. Remove the battery and plug in your AC Adapter to outlet and to your laptop and try to power-on.
machinetosh of (tipidpc.com) site
look for kuya boy laptop
Global PC Laptop Professional Services
09126888500
Apr 02, 2010 | Toshiba Satellite A100-S8111TD Notebook
Power conversion
Ram,
Good day mate, no problem you can plug your dvd direct to your outlet since it indicates 100 - 240V it only means your player is capable of having either 110V 0r 220V.
note: also try to check 1st if you will see a voltage selector at the back of your dvd player. it's either a slide switch indicating 110 or 220V. if no sign of this selector no problem you can plug your player straight to your socket.
cheers
mark
Jan 29, 2009 | Durabrand DVD-1002 DVD Player
Sound goes off
You probably have too much power running to your power strip that you probably have your xbox, playstation, tv and home theatre system plugged into, try using seperate wall outlets for your tv and home theatre system
Dec 20, 2008 | LG LHT854 Theater System
Power outlet
Here is the specification sheet for that machine. Look at the power section.
http://www.patriotgroup.com/colorcopiers/af6513specs.html
Oct 22, 2007 | Ricoh 6513 Copier
Panasonic SC-HT895 System Logo
389 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
