Question about Dryers
Kenmore Electric Dryer
Ultra Fabric Care model # 86980800 69808
Serial # MX2521390
We replaced the starter Switch and also the Timer and it still will not start please help
Thank you
  • passion_1031 Mar 13, 2008
    We replaced all the fuses, had a repair man come out to look at it he said was for sure our power cord... got new cord and nothing so we called him back out since he got $30 for his diagnostics, and he said nothing wrong with the dryer HAS to be our power is bad some pace. so we called electrition and he said NOTHING wrong woth our power lmao we are $220 into the dryer in parts and Diagnostics and now the electrition. We still have no answers on whats wrong with it. Should have seen the dryer on sale @ Home Depot for $219
  • 20 Answers
Check your fuses.one runs the dryer and other heat the dryer.
check to see if belt is broke or wire is burned off of motor.
Posted on Mar 12, 2008
Ultra fabric care electric dryer model 96588210 stopped heating all of a sudden. I cleaned vent tube out. Flipped circuit breakers. still not heating. Thank you
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 06, 2011 | Kenmore 62622 Electric Dryer
Kenmore Ultra Fabric Care dryer Model/stock number 96595220 65952 Dryer shuts off all the time. Runs, heats, works, then just stops. This happens repeatedly. Please help!
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 13, 2010 | Kenmore 659 Electric Dryer
Kenmore dryer Ultra Fabric Care 90 series. No
If you have a gas dryer check out this tip...
If you have electric check out the tip for electric at the bottom of the gas tip...
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
heatman101
Mar 25, 2010 | Kenmore Dryers
Buzzer won't shut off. only when door is left open
could be a number of things, but you may want to test with an ohmmeter if you have one.
It sounds like your timer needs to be replaced. If the buzzer is not shutting off, the timer may not be turning to the off position. It may be really slow our out of wack, not letting the dryer completely dry. It also could be an error with the dryer's control module (kind of like a computer for the dryer)
I also recommend playing around with door switch, it to may be faulty. If the dryer does work with door closed, it is unlikely to be the door switch. You will have to test timer and door switch with ohmmeter or voltmeter to determine that the voltage current is constant and not speratic or shorting out.
May 18, 2009 | Kenmore Dryers
Kenmore Ultra Care Fabric Series 80 dryer works sometimes
This sounds like the motor is bad. Hope you didn't pay too much for it. ;-)
Apr 01, 2009 | Kenmore 659 Electric Dryer
Dryer won't start due to delay button lights up and won't go off
1. No power to the dryerMake sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
Nov 09, 2008 | Kenmore 659 Electric Dryer
Kenmore ultra fabric care
only thing i can think of without being there and able to test parts is your door catch could be faulty
Aug 10, 2007 | Kenmore 659 Electric Dryer
Dryers Logo
277 people viewed this question
Top Dryers Experts
