Question about Lexmark JetPrinter X1185 All-In-One InkJet
Color resolution is all wrong
  • chassieh5 Mar 11, 2008
    my lexmark all in one printer will not print color
    yes it has new cartreges but it still dose not print coller
    Genius:
  • 3,587 Answers
Are you perhaps referring to the color resolution from a print job? have you tried the test print page, to see if there are obvious issues with that?
and here's a good place to get fresh drivers for your printer
Posted on Mar 08, 2008
I have used last 4 year canon 2900B printer. How to set 300 dpi printing resoluation
Canon PIXMA Manuals MG2900 series Resolution
Resolution The data in the image you have scanned is a collection of dots carrying information about brightness and color. The density of these dots is called "resolution", and resolution will determine the amount of detail your image contains. The unit of resolution is dots per inch (dpi). Dpi is the number of dots per inch (2.5 cm). The higher the resolution (value), the more detail in your image; the lower the resolution (value), the less detail.
How to Set the Resolution You can set the resolution in Resolution on the (Scanning from a Computer) tab of the Settings dialog.
Appropriate Resolution Settings Set the resolution according to the use of the scanned image.
Item Type Use Color Mode Appropriate Resolution Color photo Copying
(Printing) Color 300 dpi Creating a postcard Color 300 dpi Saving to a computer Color 300 dpi Using on a website or attaching to e-mail Color 150 dpi Black and white photo Saving to a computer Grayscale 300 dpi Using on a website or attaching to e-mail Grayscale 150 dpi Text document (document or magazine) Copying Color, Grayscale, or Black and White 300 dpi Attaching to e-mail Color, Grayscale, or Black and White 150 dpi Scanning text using OCR Color or Grayscale 300 dpi Important
  • If you double the resolution, the data size of the scanned image quadruples. If the file is too large, the processing speed will slow down significantly, and you will experience inconvenience such as lack of memory. Set the minimum required resolution according to the use of the image.
Note
  • When you will be printing the scanned image by enlarging it, scan by setting a higher resolution than the recommended one above.
Oct 07, 2014 | Canon LASER SHOT LBP-2900 Printer
Color of edges turned into green
Check out your \Display\Screen Resolution It my be that it is set wrong
Dec 31, 2013 | Samsung SyncMaster 753S 17" CRT Monitor
When I plug in my MacBook Pro (Mid 2012) via Mini-display to HDMI or even VGA the color of the Samsung TV changes color (Super Saturated). Oddly enough when I BootCamp into Windows 7 via same connection,...
There are issues with OSX on some monitors. On Lion and older OSX, you may get better results by playing with your Macbook screen settings and resolution. OR I found many of these issues were addressed when I upgraded to OSX Mavericks (free) it now handles external displays and resolutions much better. But you might simply have inadvertanly set the wrong color profile. Go to Finder: then System preferences then Displays. Choose the Color tab/button and select one of the color profiles or choose calibrate and follow the prompts
Nov 05, 2013 | Samsung LN-T1954H 19 in. LCD HDTV
My display driver R3000 or w/e, messes up like everyone elses, but not while im on yourube..only while im on World Of Warcraft.. ive spent months trying to fix the problem..ive done everything i believe i...
It is possible that your VGA is malfunctioning. But you will notice it when the screen resolution is set to a specific resolution and color depth.
Games play at it's own resolution. Not at the resolution you set for Windows. Probably WoW is setting the screen resolution and color depth to a values at which the VGA fail.
Did you try changing the screen resolution in WoW options? If not try it. Also try changing color depth.
Also, download GPUZ and check your VGA.
Best of luck!
Aug 20, 2011 | Toshiba Satellite A135-S2276 Notebook
My monitor gives 16-bit color at 640x480, but will only offer 256 colors at 1024x768 -- and only displays 16 colors when I select that... In order to access resolution options, I have to go into Advanced...
The monitor has no influence here - something is wrong with your video card: either its driver is missing (or corrupted) or the video chip has failed.
Uninstall all the drivers for the video(except the generic VGA one), from Programs and Device Manager
http://pcsupport.about.com/od/windows7/f/open-device-manager-windows-7.htm
and reboot several times then go to Dell
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs
select your pc and get the correct driver.
If that doesn't fixes it then the video chip has failed, you will need to buy a new video card.
Aug 02, 2011 | Dell Dimension 4600 PC Desktop
I recently bought a used Dell E193FP flat panel LCD monitor that was working properly on the computer it was taken from. I tried plugging it into my Dell Dimension 3000 computer and the colors are all...
1280 x 1024 at 60 Hz (optimal) resolution is the maximum resolution with 16 color if the other computer had it on 32 bit color setting or the resolution of the monitor aspects ratio changed than it will not display anything on your computer
Solution is plug in your old monitor and change the settings to lowest with the aspect ratio as what the screen size is then plug in the new one that should do it
May 16, 2017 | Dell E193FP 19" Flat Panel LCD Monitor
It only displays 4bits
If your computer monitor displays 4 bit color and a resolution of 640X480 and you cannot increase the color bit and the screen resolution then the display graphics card driver was not installed or the wrong graphics driver was installed.
Install or re-install the correct graphics card driver.
Nov 18, 2009 | MPC Computers ClientPro 414 All-In-One PC...
DLP HL-R5067W RESOLUTION
Please provide all part info for verification.....Your model is
HL-R5067W.......Engine # = ? , DMD # = ?.....Possible wrong part installed or bad new parts............T.
Dec 21, 2007 | Samsung DLP HL-P5663W 56" TV
Color wrong and red spots
Sounds like CCD sensor problem . It starts with 'noisy' pictures ( colors not true and resolution deteriorates )but eventually the sensor stops outputting anything and you end up with blank screen. Have the sensor replaced and camera will work fine.
Sep 11, 2007 | Fuji FinePix 2800 Zoom Digital Camera
Lexmark JetPrinter X1185 All-In-One InkJet Logo
79 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
