SOURCE: 2001 yamaha r6 speedometer reads in kilometers not
you can switch this...just read the manual
SOURCE: yamaha R6 2003, water pump leaks antifreezer
You can do a free download of a service manual and a parts fitch manual at the site below. At the bottom of the Yamaha section you will find 6 R6 manuals. Yours is in there.
http://www.carlsalter.com/motorcycle-manuals.asp
What you will be doing is replacing gaskets/seals. If you find the water pump casing is cracked or corroded away, check the cost of a new casing at the dealership then Google " motorcycle salvage yamaha " and you can probably get a replacement there for less than at a dealership.
Please rate this solution. Thanks Red!
SOURCE: Bogging out
The TPS after installed must be adjusted and that is a delicate procedure so you better take it to a dealer's workshop.You should also check the fuel pump if it works properly.
SOURCE: JUST TRING TO FIND OUT HOW TO STRAP HELMET TO BIKE
open face shield and run a small coiled cable through helmet and under mid section of handlebar you can also run a jacket through it also...if long enough for both.
SOURCE: error code yamaha r6 2007 51 how can i erase it?
could be a safety shutdown by computer, only your dealer can erase the code....and then you'll find out whats wrong...and why the computer doesn't want you starting and damaging the bike.......Good Luck to you friend....Tim
