During the wash cycle, "5ud" error started to flash on display. I hit pause/stop then start and it continued. 5 minutes later started beeping and flashing "02" and then "F" repeatedly. Again I hit pause/stop then restarted and it finished. Is something going out?
The two error codes together indicate you have something restricting the drainage system. "F02"is a Long Drain error code, "SUDS" occurs when too much air is sensed in the drainage system. In most cases, the drain pump reservoir needs to be cleaned out. The following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If you check the drain pump reservoir and the problem still persists, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, first and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
It does not take much to damage this small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
Hello & Welcome to FixYa
Sud error is displayed when the washer is unable
to drain, press PAUSE/CANCEL button twice to clear the display. After this
please check the drain hose and drain pump filter for any blockages and make
sure it is not clogged with foreign particles. You can also check the drain
pump to verify that its working. Please get back to me if you have any other
questions.
Kevin
