Question about Akai CF2791 27" TV
Volume the volume on my akai television is internally stuckon 100. When you power the set on the volume goes to 100 where it stays. You cannot turn thevolume down or mute the television
  • Anonymous Dec 24, 2008
    had the same problem on my 32", tried everything. even took the tv apart and disconnected the front panel. nothing worked.
  • Anonymous Mar 12, 2014
    Volume is at 100% and you cannot hear it
  • 682 Answers
Confirm that volume contro plus (+) button does not stuck inside.
try to apply good contact cleaner in volme button and press it many times until it released.
Posted on Mar 08, 2008
Volume stays at 100 i try to turn it down and goes back up
Does this TV have a touch-pad on the TV for the channel/volume/on-off control of the TV? If it does, I would suspect that this board has a problem that is keeping the volume+ function stuck on.
Mar 21, 2014 | Element Televison & Video
Power outage
It sounds that the main system control memory IC data has been currupted.
Sep 26, 2013 | RCA L32HD31 32 in. LCD HDTV
My akai lct3201ad tv volume just stays at 100 cant turn down or mute or source to change tv to channel 3 what can i do to fix this problem?
replace the main board. You can get the replacement main board from www.tvcircuitboards most likley if they dont have it listed I would send a email as they only list boards that they have more than one of single boards are not always listed.
Jan 02, 2013 | Akai LCT3201AD 32 in. LCD Television
Volume automatically goes to the loudest
There should be a setting that allows you to set the "Power On" volume level. Check the menu Under Volume settings.
What is the make and model of the Television set?
Nov 22, 2012 | RCA Televison & Video
TV will not stay on.
bad capacitors on the power pack need to be replaced.
Apr 15, 2009 | Akai LCT2715 27 in. LCD Television
Volume Control
check the up volume button on the set. it sounds like it is stuck in the on position. You can open the back and disconnect the wire harness to the control buttons. This will verify if the volume up button is the problem.
Feb 11, 2009 | Akai LCT3215/26 32 in. LCD Television
Akai TV volume control stuck on 100%
try leaving the set unplugged for several hours, this will reset it to factory settings. If this does not work you need service.
Jan 10, 2009 | Akai PT5492S 54" Rear Projection...
AKAI LCT3201TD
Is sounds more like a button got stuck or you could have a main board failure since the TV is powering up normal; but it could also be a power supply not providing the proper voltages to the main board circuitry and the microprcessor does not know what to do.
How old is your TV?
May 13, 2008 | Akai LCT3201TD 32 in. LCD Television
Volume Controls Are Frozen
Try unplugging it from the wall for about 2 minutes and then trying again. This will force a system reset as it sounds like it locked up.
Feb 13, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
TV doesn't want to turn on
power transformer shorted ,looks like a little 2" sqare block middle rear of set there' a fuse like a relay that clicks out keeping from shorting whole set power transformer about $100
Oct 28, 2006 | Akai PT4799HD Rear Projection Television
Akai CF2791 27" TV Logo
188 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
