Question about Mitsubishi VS-50605 50" Rear Projection Television
TV problem D955 and D953 seem to check good out of circuit with both analog and digital meters. Tell me what is correct way to check for leaky diode? REDCAT55
  • Mitsubishi Master
  • 8,617 Answers
Use the analog meter reverse your probes you should get no reading one way and get a reading when the probes are reversed. You will need a diode vhecker to test for a leaky diode as often times a diode will fail under load. Its best to replace a questionable diode if you dont have an actual diode checker meter.
Posted on Mar 08, 2008
Tv not switching on just makin noise from power supply & hissing @ the flyback transformer with horizontal becoming extremly hot then afew min later horizontal burns out(D1398)
If the horizontal transistor getting shorted, this could happen.
Check the transistor 2 SD1398. If found faulty replace it.
But replace black colored doides in the circuit as a whole.
Leaky diodes can not be determined easily with the multi meter.
Especialy the small high voltage diode near the small transformer
connected to the 2 SD1368 transistor.
Sep 03, 2010 | Televison & Video
Grundig LCD TV
try to resolder the pins of the chroma IC and some possible lose connections you can see in the PCB board...
Aug 01, 2008 | Televison & Video
My TV picture has collapsed to a single horizontal line
If it is an standar analog tv, I'm sorry to tell you but, is time to get a new one.
Dec 05, 2009 | Panasonic Televison & Video
Astar LTV-32HGB blinking power indicator light
this sounds like typical power supply problems. these units have a stand-by power thats always active;even when unit is off. this allows the settings to be remembered by the u-con. (microprocessor) when you unplug the unit it will reset to factory default, thus erasing faulty power-supply data from improper voltages.(usually low readings) swollen capacitors on power-pcb will effect operation. recommend replacement of all electrolytic caps on power board. even smd's (surface-mounted-devices) can be leaky. they can be checked in circuit with an ESR meter. this is an analog sweep meter (needle gauge, not digital) that can detect faulty, leaky capacitors.
Mar 09, 2009 | Astar LTV-20PW 20 in. EDTV-Ready LCD...
Please help!!!!!!!!!!!!!!!
Good Day;
It sounds like you may problems in the TV's circuits, but try resetting first by unplugging TV from power source. If no fix try these areas of concern:
1. SHUTDOWN CAN BE CAUSED BY NO VERTICAL DEFLECTION. SINCE THE VERTICAL CIRCUIT IS POWERED BY THE SWITCHED POWER SUPPLY THE UNIT MUST BE TURNED ON TO TROUBLESHOOT THE CIRCUIT. THIS CAN BE ACCOMPLISHED BY TEMPORARILY DISCONNECTING THE VERTICAL INPUT TO THE X-PROTECT CIRCUIT. ** TO PREVENT DAMAGE TO THE CRT'S YOU MUST UNPLUG THE CRT PCB'S. ** TO DEFEAT THE X-PROTECT CIRCUIT, UNSOLDER D4A1 LOCATED OFF THE COLLECTOR OF Q4A1. IF THE UNIT POWERS ON AT THIS POINT, YOU HAVE CONFIRMED A VERTICAL FAILURE AS THE CAUSE FOR SHUTDOWN. ** D4A1 MUST BE REINSTALLED IN CIRCUIT TO PREVENT CRT DAMAGE. ** 2.CHECK PIN 1 OF IC401 FOR 10.7VDC. IF LOW OR MISSING CHECK FOR SHORTED D4000 LOCATED OFF PIN 1. (PCB-MAIN) D4000 PART #264P487030 3. CHECK PIN 8 OF IC401 FOR 27.7VDC. IF MISSING CHECK FOR OPEN D955 AND L961 AT S1 TERMINAL OF T902. (PCB-POWER) D955 PART #264P102040 L961 PART #411P012010 4. CHECK FOR DEFECTIVE IC401. IC401 PART #272P239040, OR INSTALL PT# IC-401, THIS KIT CONTAINS CAPACITOR C920, D4000 AND IC401. BE SURE TO MOUNT C920 ON FOIL SIDE OF PCB. 5. EXCESSIVE 130V SUPPLY. CHECK C911 47 UFD 100 V AND C914 47 UFD 50 V, IN THE IC900 CIRCUIT. Good Luck, big IRISH.
Sep 26, 2008 | Mitsubishi Televison & Video
Model vs-4543 mitsubishi tv
Good Day;
One of these may be your problem:
Sep 14, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubisihi hd 1080 t.v.
Good Day;
Try this when th TV wont turn on:
Aug 21, 2008 | Mitsubishi WS-55807 TV
TV problem
Over Current Protection
Pin 1 of IC951 is also the Over Current Protect input.
The internal FET.s ground return is at pin 2 of
the IC. The voltage drop across R955 and R956
indicates the FET.s current, and is coupled through
R953 to pin 1 of the IC. The Over Current Protect
circuit is activated if the voltage at pin 1 of the IC
exceeds 1.35 volts.
Stabilization and rough regulation are provided by
feedback from pin 3 of T951 to pin 1 of the IC. Fine
regulation feedback is from a secondary supply,
through the Photo Coupler, PC951, to pin 1 of IC951.
Its possible that Diode D953 is leaky allowing the voltage to rise on pin 1 of the IC
Feb 23, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Sony MODEL KV-2585 TV
You have your information incorrect, Q is not the designation for diodes, Q657 would be a transistor. First give us the correct number for the diode and how do you know it is shorted?
Aug 13, 2007 | Sony KV-36FS17 36" TV
TV Turns off on its own ?
You can check the board where the components are mounted and resolder any that look bad. a brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. all can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced.
Dec 21, 2005 | Panasonic PT-53WX42 53" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
70 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
