Question about Microwave Ovens
Short life of appliance bulb,40 w clear. ordering code bc40tbn 130v soft light last atleast 1 year bright light last atleast 2 years. mine lasted less than 6 weeks,, are they garunteed ??? William wunduke 20 Diablo ct. umatilla Oregon 97882 bduke@my180.net
  • bduke954bill Mar 09, 2008
    I bought my bulb at home depot..
  • Microwave Ovens Master
  • 9,098 Answers
When I hear of light bulbs not lasting, the first thing I suggest is to measure the voltage level of your power line at a few sockets in the home. They should measure 110-125V AC.
Measuring between ground and the larger terminal of the outlet should be virtually zero volts, and from ground to the smaller terminal should be 110-125V AC.
If these readings are off, please reply back with details. In some cases, a loose neutral can occur, causing voltages to vary at dangerous levels.
OTHERWISE, I would suggest making sure you get good quality bulbs. Sadly, since we handed over our manufacturing base to China, the products we get in return are barely adequate.
I would visit a home center like Lowe's or Home Depot (as opposed to a grocery store or dollar store or Wal-Mart) and see if they have more rugged bulbs. You're likely to find good ones with guarantees.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 08, 2008
Whirlpool builtin microwave model mh6130xeq1. I replaced the 2 bulbs that were underneath the unit that shine on the oven, but the replacement bulbs do not work. They are 40w appliance bulbs; the same...
You know how when you turn on a regular light bulb and it burns out with a bright flash? What happens is that when the filament burns out, it breaks and bounces back and hits the other electrical post and basically shorts out causing that bright flash. Sometimes, when 1 of the light bulbs in the microwave burned out, it shorted out, and caused the circuit-board trace to burn up. (This is not just conjecture; I've seen it.) If that's the case, then you would have to replace the main control circuit board. A rather expensive repair for no lights. BUT BEFORE YOU DO THAT, get an ohmmeter and check your new light light bulbs and make sure they are really good. Also, if you can, get a bright flashlight and check the light bulb sockets in the microwave (unplug it first). Check for possible corrosion or signs of arcing on the center electrode of the socket. If that's the problem, you might be able to use a small screwdriver to scrape off the corrosion of the socket (make absolutely sure you have your microwave oven unplugged before you do that!).
Jan 09, 2015 | Whirlpool Microwave Ovens
JVM1340 lights not working
Behind the top grill above the door is an access panel to change the light bulb. If the bulb is good but light still don't work, its possible the door switch is bad, but normally if the switch is bad the turn table won't work either. Most likely just a bad bulb part number you would seek is WB36X10003 this is not cheap for a bulb, you maybe able to get a replacement from a local lighting center near you. its a 40 watt, 130V bulb
Good Luck
Nov 03, 2013 | GE JVM1650 1000 Watts Microwave Oven
I have an Electrolux High Speed Oven E30SO75FPS that's 3 years old and the Magnetron has failed for the 3rd time. What can be causing this?
Is the internal cooling fan working?
Are the ducts and vents clear?
Problems with any of those can result in overheating, which destroys magnetrons.
I have seen high voltage rectifier diodes interact with magnetron in funny ways. I'd replace the diode, too.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Finally, baking potatoes and making popcorn really give the magnetron a workout.
You should put about 1/2 cup of water in the rear corner of the microwave when cooking those foods.
It helps "preload" the oven to prevent execessive microwave energy reflection back to the magnetron.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Dec 12, 2011 | Microwave Ovens
We have a Jenn Air Microwave Over our built in oven. The light is burned out. How do we replace it? it is a jmc 7010ADB. Thank you Jan G
Mine is JMV8166BAS over-the-range model, and yours may be similar. Disconnect electric source (pull plug, or turn off circuit breaker).
1. Locate and remove 2 Phillips head screws on top projecting from cabinet/wall,etc,
2. Carefully & slowly, slide entire front vent 1/4" towards your left simultaneously pulling toward you.
3. Remove vent filter, if any.
4. In very center maybe beneath filter space, locate approx.4" width aluminum colored metal cover, possibly held in place with Phillips head screw.
5. Remove screw, exposing small light bulb.
6. Gently pull back on bulb, replace with identical wattage, 120V bulb from big box or appliance store.
7. Human touch may shorten life of bulb, so carefully push wire prongs into plastic bulb inlet socket using whatever allows you to grip bulb in the limited space.
8. Reverse 5 - 1 for reassembly. Before replacing vent assembly, notice the small notched angle clips on the bottom before aligning to microwave unit, as these were slightly tricky on my unit when inserting & sliding assembly 1/4" toright.
Jun 30, 2010 | Microwave Ovens
I replace my light bulbs underneath the microwave, and they last less than 2 weeks and both burn out at the same time. I have gone through at least 8 lightbulbs in the past 3 months.The first pair of bulbs...
If they are halogen types, oils from the skin will shorten their life. You should never touch them with bare skin.
If someone slams the door (a nono!) while the lights are no, that can shorten their life or blow them right away.
If they are left on for hours at a time, that will reduce the number of days they will last.
I would recommend a good quality replacement (not made in China if possible!) from a home improvement center such as Lowe's, Home Depot, etc., as opposed to the grocery store types.
Or you can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
May 14, 2010 | Frigidaire FMV156DC Microwave Oven
Amana Microwave bulb I cant seems to access, model # AMV5164ACS??
The owner's manual shows you to to access and change them.
Your exact model is not there, but the similar models (like the BCS suffix) should work just fine.
COOKTOP/NIGHT LIGHT REPLACEMENT
CAUTION
To avoid personal injury or property damage, wear gloves when replacing light bulb.
1. Unplug the oven or turn off power at the main power supply.
2. Remove the bulb cover mounting screws.
3. Replace bulb with 40 watt appliance bulb.
4. Replace bulb cover, and mounting screws.
5. Turn the power back on at the main power supply.
OVEN LIGHT REPLACEMENT
1. Unplug oven or turn off power at the main power supply.
2. Open the door.
3. Remove the vent cover mounting screws. (3 middle screws)
4. Slide the grille to the left, then pull straight out.
5. Remove the charcoal filter, if present.
6. Press and hold the center snap while lifting the tab on the left corner. Remove the cover. Remove
the bulb by turning gently.
7. Replace bulb with a 40 watt appliance bulb.
8. Replace the bulb holder.
9. Replace the grille and 3 screws. Turn the power back on at the main
power supply.
Jun 26, 2009 | GE JVM1650 1000 Watts Microwave Oven
40 watt night light bulbs constantly burn out short out.
Is they are left on all the time, this can reduce their life, and they are more susceptible to vibration.
Have you checked at home center or home improvement centers like Lowe's, Builder's Square or Home Depot?
You can order quality parts such as lamps by entering your full model number or part number WB36X10003 here.
Always be sure the microwave is unplugged or the breaker is off when installing or removing bulbs, and be sure the bulbs and and your hands are clean when installing them.
Feb 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave interior light has gone out twice in one year
If the warranty covers changing the light bulb, you can find other GE-authorized servicers by calling GE Appliance Service at 1-800-848-7620 or visiting here.
If the warranty does not cover the bulb, it's really not too hard for you or someone you know to do it.
There is a handy step-by-step guide with pictures here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
These use halogen lamps, so you must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Jan 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How to stop the beeper and reset the "code' light on panel?
You have a shorted 2 pad on the keypad.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
Aug 21, 2008 | Microwave Ovens
Microwave Ovens Logo
81 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
