Question about Jenn-Air JED8430 Electric Cooktop
Stovetop 3 wires to wall 4 wires
GE stovetop has red, black and ground. The wall has 2 blacks, white and ground? In reading different online articles, it appears some recommend capping the white off and others recommend combining the ground and the white. This presumes the red to black, black to black and ground to ground.
Which approach is best?
  • Kaptan Mar 09, 2008
    Thank you. While waiting for a reply, I asked the helpful ex-contractor at Home Depot and he concluced that it must be a 110v stove top. Based on this, he suggested, hooking red to black, black to white, ground to ground and capping the extra black. I hooked it up this way and it worked, albeit at 110v.
    After seeing your email, I looked the
    GE
    JP346SMSS
    30" Smoothtop Electric Cooktop up on the site from whom I purchased the unit and it is a 240v unit. Now what do I do?
    Novelist:
  • 142 Answers
I'm assuming this is a 220/240v unit. The wall has two blacks, each with reference to white is 120v. Since you need 240 volts, you need to use both blacks. The third wire you'll need is ground. ALWAYS make sure you use a ground wire!!
Realistically, the white is connected to the Ground terminal in your circuit breaker box. Best practice says cap off the white, and use the GROUND.
Posted on Mar 08, 2008
How do i wire a ge cooktop
most stoves are 220 and will have four wires(red,black,white and ground). If you only have 3, black to black, ground to ground, red to white
Aug 16, 2012 | GE 30 in. JP326 Electric Cooktop
Do i connect the red and black wires together
No you do not. You have a 220 system. What you do to hook it up is. In the box in the wall you should have 3 wires. 2 black and one white. Then on the cooktop you have the 3 wires 1 black, 1 red, and 1 white. You take the black from the cooktop to the black in the wall box. Take the red to the other black in the wall box. then take the whites and put them together. Now if you have a green or bare wire that is the ground. Just hook that to the wall box.
If you have any questions please ask.
May 09, 2010 | Jenn-Air JED8230 Electric Cooktop
Wire from circuit breaker is Black/White/Bare(ground). From Jenn Air is Black/White/RED/Green (ground). How do I wire? Jenn Air Black to Black, Jenn Air Red and White to White? Grounds (Jenn Air Green to...
depending on your local electrical code:and I see that the unit is 240 Volts A.C., then RED=Power/Black=POWER(L1 & L2)/WHITE="N"Neutral/and GREEN=SAFETY GROUND,on the new unit, then use from the wall power BLACK = L1 and White= L2. then on the unit RED=L1 and BLACK=L2(either way you hook these 2 up there isn't a polarity issue on these 2 wires) on the units hook-up/then use the BARE supply wire as neutral and tie BOTH WHITE and GREEN from the unit together to this BARE wire
Apr 29, 2010 | Jenn-Air JED8230 Electric Cooktop
Help with wiring for a drop in stove top
This is not to code. The white is neutral and is of the same polarity as a bare wire. The red and the black are considered hot and would be 220.
Apr 07, 2017 | GE Cooktops
On-site breaker panel routing
white and ground are grounds there should be a ground rial in the fuse box, stove is 220 black and red go to 2 seperate breakers, 25 amps, and 15 amp is for 110 regular outlet
Oct 08, 2009 | GE Cooktops
I need a wiring diagram hook up for a Jenn air 201595D Range top & also for a GE Double oven JKP36G0D1B0
Cook top manuals and installation.
http://www.jennair.com/catalog/product.jsp?parentCat=2&cat=12&prod=1457&tabOption=specs#info
Could not find installation manual on oven but did find manual. If you are just trying to wire to the house wiring you need to conect this way. Yo uwill have 3- 4 wires from the house. 1 white, 2 black or 1 black and 1 red. From range hook white to white Black to black or red they both are the hot line. and the other black or red to black or red from the house. If you have bare wires that is the ground There is 2 ways to do the hook up on the ground. 1st way is if you have ground in box from house wire them together. 2nd way is if there is no groung just wire it up with the white wire that is the netural line. It will be fine that way. If you can see in you main braker box the netural and the ground go to the same bus bar.
http://genet.geappliances.com/DocSearch/pdf/49-4751.PDF
Good Luck and If you have any more ? fill free to ask befor you rate.
Jan 16, 2009 | Jenn-Air JED8430 Electric Cooktop
JED8430BD has 3 wires no ground. Wall has 3 wires including ground
I think the white on the cooktop should be on ground.
cooktop wall
Red White
Black Black
White Ground
Sep 04, 2008 | Jenn-Air JED8430 Electric Cooktop
JEC8430 ADB cooktop wiring doesn't matchup - no instructions for this situation
hook the copper and white together. DO NOT leave the white unhooked.
Nov 24, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430 Electric wiring confusion
On Cooktop From Box
Black to Black
Red to Black w/red stripe
White to Ground
Green to Cooktop frame
Nov 16, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
135 people viewed this question
Top Jenn-Air Cooktops Experts
Marvin
Marvin
Paul Carew
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
