Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
Ge quiet power 3 troubleshooting
By moxpatrol on Mar 08, 2008
our dishwasher runs through a cycle but does not clean. the dish soap remains in the capsule. thanks
Same Problem
Feb 15, 2009
-   I have the same problem, but with a Kenmore 15892. The workaround has been to turn this into a "manual" dishwasher. When the cycle clock hits 76 I open the dishwasher door so the soap dish opens all the way and the soap packet drops into the dishwasher. At the end of the rinse cycle, just before drying starts (at the 32 minute point), I open the dishwasher again and manually rinse the dirty glasses and dishes. The dirt is sediment that has been pushed into the glasses on the top rack and in the corners (front and rear). Some large bowls on the bottom have sediment, as does the side of a cutting board facing the side of the dishwasher.
This is very perplexing because the glasses did not have visible dirt on them at the start of the cycle, but the dishwasher shot the dirt in but is unable to clean it out. Over the years we have used powdered soap, liquid, tablets and currently use (Cascade) gel packs: they all leave dirt.
I hope to find out what causes this so I know what to look out for before purchasing a new dishwasher.-   AlanS1
Dec 14, 2008
-   Dishwasher came with the house and we have had the same problem of detergent remaining in the dispenser.  We also had knocking noise whenever it is running.  -   DIYnewbie
Nov 24, 2008
-   Mine is a Quiet Power 1, but same problem-   wapsullivan
Nov 20, 2008
-   Help....I hve the same issues. How can we fix it?-   debbiee3
Oct 19, 2008
-   Dishes do not get clean and the soap remains in the dispenser though it does open and some of the soap spills out. I took everything apart cleaning anything I could and adjusted the hot water heater to make the water hotter. If I rotate the timer manually after the complete cycle I can drain any additional water out so I know the pump is working.-   c214dick
Solution #1
posted on May 08, 2009
Somewhat Helpful)
buddywa
Rank: Apprentice
Rating: 79%, 6 votes
Change soap. I had the same issue and then I changed brands of soap and now it works geat!
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
we are about to buy new dishdrawer lookin fisher and paykel
Answer
clean light is blinking and the washer will not restart and run a cycle.
Answer
Our dishwasher is not ejecting water at the end of the cycle and we have already cleaned out clogged... (More)
Answer
water does not pump out
11 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Oct 07, 2008
We have the same problem. Ours wasn't draining, then my husband took it apart and cleaned any screens and filters he could find. He put it back together, it goes through all the motions, but the dishes are still dirty? Anyone please help!
Comment by sbowling, posted on Oct 05, 2008
we have a brand new set that came with the house we built and it doesn't drain and leave the dishes dirty. what do we do?
Comment by Guest, posted on Jul 16, 2008
We have the same problem. Been getting worse over the last 2 months, with a LOT of soap build up in the all the water holes. I have to constantly scrape them out. I've switched soaps 4 times, thinking it was that. Finally had the repairman out and we cleaned out all the residue, only to find that now the pump isn't draining the tub. All the dirty water is recirculated. I spent $115 for the first "repair" and now will need a $50 pump and another $100 in labor, apparently. This dishwasher is only 2.5 yrs old!
Comment by supersmallch, posted on Jul 12, 2008
Same problem. It goes through the motions but the dishes don't get clean. Any suggestions?
Comment by Guest, posted on May 19, 2008
The dishwasher runs through the cycle but the soap doesn't dissolve, becomes clumpy, and the result is dirty dishes!
Comment by dirtyglasses, posted on Apr 19, 2008
I have the same problem. the dishwasher goes through all the motions of a clean cycle, but there is at least half of the soap left in the dispenser and the dishes are grimy...any thoughts anyone?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dishwashers:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
