Is there a patch for Etherlords 2 to make it Vista compatible?
  • 655 Answers
I can't install Print Shop Duluxe 22 with windows 7. What can I do to install this program?
The most important thing to keep in mind about installing Print Shop 22 on any computer is that Print Shop 22 requires that .NET Framework 1.1 be installed on the hard drive before Print Shop 22 is installed. (Print Shop cannot work with any other version of .NET Framework.) So, the first thing that the Print Shop 22 installation process will look for is whether or not .NET Framework 1.1 is installed. If .NET Framework 1.1 is not installed, it will be installed from the Print Shop 22 install disk before Print Shop 22 is installed.
32-bit version of Windows 7:
When a 'clean' install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 32-bit version of Windows 7, with two incidents.
1. The "Program Compatibility Assistant" in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 32-bit. To continue with the installation, select "Run Program".
2. At the end of the installation, this message will be displayed
The Amyuni Document Converter mentioned in that message is the Broderbund PDF Converter. This problem can be fixed by downloading and installing the Print Shop 22 Vista patch, which can be found here
I am looking for the Vista compatibility patch.
and which works equally well on Windows 7.
NOTE: Even though the information on that patch site says, "Note: This patch will only work for Vista 32-bit and not the Vista 64-bit operating system," I have confirmed that the patch works quite well on the 64-bit version of both Vista and Windows 7.
It should be noted, however, that when the patch fixes the problem with the Amyuni Document Converter, the Broderbund PDF Creator 3.0 will be installed - instead of the Broderbund PDF Converter, which was installed with WinXP and earlier versions of Windows. The Vista patch installs the Broderbund PDF Creator because the Broderbund PDF Converter is not compatible with either WinVista or Windows 7.
NOTE: One Windows 7 beta user has reported that his DVD drives disappeared after PS 22 was installed on Windows 7 beta 32-bit. This is a known problem with WinVista. So, it would be a very good idea to install the Vista patch BEFORE rebooting the computer.
If your DVD drives disappear after installing Print Shop 22, the only known solution is to uninstall Print Shop 22.
Jul 22, 2011 | Broderbund The Print Shop Deluxe Version...
Cannot load easy creator 10 onto vista
i Think you do not have vista compatible softwares i.e.
Roxio Easy Media Creator 10 Suite . So please buy vista compatible software or path with vista patcher . You can easily download vista patch from www.rapidlibrary.com . Patch and run the software in vista. Best of Luck.
Nov 06, 2009 | Roxio Easy Media Creator 10 Suite
Monster Madness: Battle for Suburbia not working
a large number of older games do not work on vista, they are incompatible, you can either download the patch from the games site, which i see youve tried and it did not work, in this case, try to run the program in windows xp SP2 mode. to do this, fidn the application or executive file, it will have .exe at the end of the filename or will say application, then right click it, properties, compatibility, then check the box to run in compatibility mode for:, then choose for Windows XP (Service Pack 2), use those settings then try it again, if it still doesnt work then you simple can not use that game on vista. your last option you can try has a small risk of virus, only because it is user created, but seacrh the internet for a patch that allows it to work on vista. some people make their own patches to allow the program to work on vista.
Dec 03, 2008 | South Peak Interactive Monster Madness:...
Will rrt3 work with vista
Try running the game in Compatibility mode. Right click on the game icon, go to Compatibility at the top, then check the box that says "Run in compatibility mode". Then select the compatibility mode for the reccomended operating system for the game.
Nov 21, 2008 | Take 2 Interactive Railroad Tycoon 3 for...
Need patch for free space 2 game to play in windows vista needs to recognize I have 4 gigs of memory
is it not installing,try to browse setup.exe or install file for the game,right click and choose run as administrator..it should be installed w/o any problems,or if you were able to install this and the game just crashes upon playing it,you need to put it to compatibility mode,To do this search for freespace.exe (Probably in C:\Program Files\Volition\", right click and select the "compatibility" tab. Check the box that says "run this program in compatibility mode for" and select "Windows 98"
Sep 29, 2008 | Computers & Internet
Patch fo Vista
Go to the manufactures site and download driver for Windows VISTA.
May 25, 2008 | Microsoft Windows Vista Ultimate Edition
Game patchs
do you mean the sims 1 or 2?
well, you can run either one of them in compatibility mode, rightclick the exe or shortcut, press options, press compatibility (if i'm right, my pc is in another language) and choose windows XP service pack 2
good luck
Apr 13, 2008 | Microsoft Windows Vista Ultimate Edition
Olympus ps-1oo vista driver or patch
I don't know how you got it to work in compatiblity mode but according to their web page the p-s100 is NOT vista compatible
http://www.olympus.co.jp/en/support/imsg/digicamera/compati/winvista.cfm#printer
Dec 16, 2007 | Olympus P-S100 Thermal Photo Printer
Call of duty 2 patch for vista
Since Vista has compatibility problems, i suggest downloading and installing the lastest from www.microsoft,com
or
you can go to the product's website and see if there are any solutions on call of duties' website.
hope this helps
Nov 12, 2007 | Microsoft Windows Vista Ultimate Edition
Not compatible with windows vista
Hey Guyz Just Go 2 Google And Search for lgs501.exe or LGS501.exe to Download, and then download and install the application on your Vista PC .Plug in the Gamepad(Rumblepad2 or 1) In ur USB Wen ur Installing it.
THEN UR RUMBLEPAD 2 OR 1 SHOULD WORK 100% PERFECLTY + BIT MORE EFFECTS AS YOU HAVE DX10.
If youll have any problems\Errors in installing or playing or if you need any original softwares,Games,Cracks,Patches,Drivers,Help,Gamepad Drivers or Help JUsT EMAIL TO --- arjunmanoj23@hotmail.com
Nov 01, 2007 | Logitech Rumblepad 2 Vibration Feedback...
Computers & Internet Logo
130 people viewed this question
Alun Cox
David Payne
David Payne
