Dell All-in-one Photo 944 Carrier Jam....help me please!
Out of nowhere, my printer has a carrier jam. I tried taking the cartridges out and putting them back in and wiping the track and turning it off and on. Nothing works. It'll reset itself and then when it starts to pull the paper in, I hear a LOUD click and it all stops there.
HELP ME PLEASE!
Thanks so much
Lara
  • 3 more comments
  • Lucy Ford Mar 08, 2008
    I'm actually a lady but hello :)
    I'm not electronics savvy at all ... what is the drum? LOL
    I did that. I manually moved it back and forth a little on the track and it was fine???
    Someone suggested that I check the drum.
    What is a safe way to clean it?
  • 42 Answers
There might be a problem inside the printer. The motor of your printer which collects the paper maybe damaged, this might be the problem why it makes load noise. Or something was stuck in there.
Do you have the manual for the printer ? Try to see if anything says about this?
This is all i can say.
Posted on Mar 08, 2008
  • Rajh Uddin
    Rajh Uddin Mar 08, 2008
    This Is called a DRUM, i dont know why your talking about a drum, since your printer doesnt need any !
    Look At this website :
    http://img.alibaba.com/photo/11452501/La...
  • 790 Answers
Hello ,
check the catridge carrier once ... guess it has stuck or misplaced!!
    Guru:
  • 1,894 Answers
Hello sir
  • dewan nafees ahmed Mar 08, 2008
    may be the printer drum has jammed...
    try to clean the path of the drum
    drum is the section from where the ink is sprayed or printed
I have a printer dell 944 and I can,t print anything because of carrier is jam
remove all paper from printer look inside carrier with a flash light to see if something is obstructing paper flow
Jan 30, 2011 | Dell 944 All-In-One InkJet Printer
Carrier is jammed dell printer all in one 944
check and clean the paper carrier and if it continues change the cartridge.
Nov 13, 2009 | Dell 944 All-In-One InkJet Printer
Dell 944 error message 1102 after fitting new DellBlack Cartridge
hi there,
you can try these steps:
try to remove the new black cartridge. get a clean cloth. gently wipe the copper strip of the cartridge. unplug the power cable of the printer. gently wipe the contacts of the black cartridge carrier (where you put the black cartridge in). close the carrier, plug the power cable back in. install the black cartridge. then check for the error code.
if you still have same error code, try the old cartridge.
if the old cartridge still works, you need to contact dell for the replacement of the black cartridge (if you purchase the black cartridge from dell)
if the old cartridge is also giving same error. try the steps on the color cartridge as well, it might be with the color cartridge error.
or both.
worst case scenario the contacts on the printer carrier might be broken already.
but in this kind of situation. 98% it's the cartridge that's causing the issue.
have a great day :)
Oct 02, 2009 | Dell 962 Photo All-In-One InkJet Printer
Dell 944 carrier jam
THE CARRIER MAY HAVE A FINE PEACE OF PAPER STUCK IN THE FEEDER ROLLER OR IN THE ROLLER PANS, REMOVE EVERYTHING, GET A CAN OF AIR AND BLOW IT OUT GOOD AROUND WHERE THE PAPER FEED AND EXITS THE PRINTER, THE CARTRIDGE MAY MAYBE GETTING SNAGED ON THE PRINT HEAD ALSO. SHACK THE PRINTER UPSIDE DOWN TO GET ANY TYPE OF MATTERAIL IN THE MACHINE, IT CAN BE PAPER, PAPER CLIP, STAPLE, PENCIL, ERASER MATTERAIL,
INK BUILD UP ON THE ROLLERS, CHANGE THE TYPE OF PAPER YOU ARE USING, IT MIGHT BE CHEAP PAPER PRODUCTS, LABEL GUM STUCK INSIDE THE PRINTER HOUSING AND EVERY TIME YOU USE IT JAMS.
ROD
Feb 13, 2009 | Dell 944 All-In-One InkJet Printer
Dell Photo All-in-One Printer 944 cartridge carrier malfunction
Nobody fixes ink-jet printers anymore.
If the old cart will go back in OK, it could be a bad cartridge.
Dec 28, 2008 | Dell 922 All-In-One InkJet Printer
How to clear carrier jam in Dell Photo All in One 944
simply open up your printer and see if there is any residual paper that get stuck, in some case if you can find some small miniature piece of sensor it might cause a erratic sensing that there is a presence of paper while there isnt, try to clear this or clean.
paper jamming indicator means there is some paper in the paper path, unless otherwise ou clear this up you cannnot print.
after you may need to power down or restart your printer once again
cheers
Nov 27, 2008 | Dell 924 All-in-One InkJet Printer
Dell 942 carrier jam
This morning I replaced the cartridges in the Dell 942 printer, they jammed to the left which made a loud grinding noise and the cartridge jam error came on.
I solved the problem by turning the printer on with the top up which moved the cartridges to the right a little so I could reach back, push one down a little manually which freed them to move over to the middle.
Feb 28, 2008 | Dell 942 All-In-One InkJet Printer
Carrier Jam
The top of my ink cartridge had fallen off and was in the printer... I hadn't seen any paper or anything and was completely stumped, when I picked it up and heard something in there... It was hard to get back on, but now it works!
Jan 08, 2008 | Dell 924 All-in-One InkJet Printer
Carrier jam on dell 924 printer??
I was able to fix this issue on my all-in-one 944 printer. What happened was that one of the ink cartridge lids had popped open. The hard part was that the carrier was stuck on the far left side, and I wasn't able to pull it over for easer access. However, I was able to fit a finger in and push the cartridge back down. Then when I turned the printer back on the error went away.
Hope this helps
Dec 13, 2007 | Dell 924 All-in-One InkJet Printer
Dell 944 All-in-One Printer - printhead carrier jam
I just found that one of the little feeder rollers (??) on the roller bar has jumped out and is sitting (still attached by its spring) on top of the roller bar. I reckon that's curtains for the printer. Am I right or is it repairable?
Nov 25, 2007 | Dell 924 All-in-One InkJet Printer
105 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
