Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
How to refill Canon FX3 Laser Toner Cartridge
How do I refill my Canon FX3 Toner cartridge? Where would I drill the hole for refill? Thanks
  • 1 more comment
  • Ray777 Apr 30, 2008
    Where do I place the hole to refill an FX3 Toner Cartridge?
  • borra143 Aug 26, 2008
    where will I drill hole to refill my fx-3 catridge
  • Anonymous May 15, 2009
    how to refill fx3 cartridge
I drilled the hole on the side with no handle. I put packing tape over the hole and it worked fine. I'm refilling it again right now... Good luck, have fun, and save some $$$!
Posted on Sep 17, 2008
  • 30 Answers
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
takio-27
Posted on Sep 04, 2009
Canon monochrome laser LBP3108b printer cartrige can be refill?
I would not advise on refilling a toner cartridge, the toner power is very fine and you do not want to breath in this toner powder.
You can purchase a new toner cartridge or a recharged toner cartridge these are cheaper than a new cartridge.
You can get a few more print pages out of a empty toner cartridge by shaking the toner cartridge in a horizontal position and inserting back into the printer.
Dec 04, 2010 | Canon LASER SHOT LBP-2900 Printer
How to refill a canon lbp 2900 printer cartridge
  1. Remove the old ink jet cartridge from the printer following the manufacturer instructions. Close the lid on the printer to keep it free from dust and debris while you are refilling the Canon ink cartridge.
  2. 2
    Locate the ink tank on the cartridge. Put a 3mm drill bit in a drill. Drill a hole in the top of the ink tank on the cartridge.
  3. 3
    Gently insert the needle on the bottle of ink into the hole you just drilled in the ink cartridge. Avoid squeezing the bottle until the needle is completely inserted in the ink tank.
  4. 4
    Squeeze the ink bottle gently to refill the cartridge. Fill the tank with a little at a time until the cartridge is full.
  5. 5
    Remove the needle from the ink tank. Wipe the top of the Canon ink cartridge off with a paper towel. Place a small piece of duct tape over the drilled hole. Rub the tape to remove air bubbles and to make sure it adheres to the cartridge.
  6. 6
    Put the refilled ink cartridge back into the printer. Clean the head of the printer by running the printer software and following the instructions for head cleaning.
Nov 10, 2010 | Canon LASER SHOT LBP-2900 Printer
How to refile the cartridge of canon pixma ip1300 printer
Instructions :
  2. Locate the ink tank on the cartridge. Put a 3mm drill bit in a drill. Drill a hole in the top of the ink tank on the cartridge.
  3. Gently insert the needle on the bottle of ink into the hole you just drilled in the ink cartridge. Avoid squeezing the bottle until the needle is completely inserted in the ink tank.
  4. Squeeze the ink bottle gently to refill the cartridge. Fill the tank with a little at a time until the cartridge is full.
  5. Remove the needle from the ink tank. Wipe the top of the Canon ink cartridge off with a paper towel. Place a small piece of duct tape over the drilled hole. Rub the tape to remove air bubbles and to make sure it adheres to the cartridge.
  6. Put the refilled ink cartridge back into the printer. Clean the head of the printer by running the printer software and following the instructions for head cleaning.
Good Luck!
Aug 28, 2010 | Canon PIXMA iP1300 Printer
I want to refill cartridge of my canon LBP 3300 printer,please guide me
Take out the cartridge and make a hole on the surface of the laser toner container with a sharp tool. Then you can refill the tonner inside it using one small coke.
Aug 11, 2010 | Canon LASER SHOT LBP 3300 Printer
How i can refieling cartage
Its best that you go to web page of OASIS IMAGING, there are detailed instructions for Canon and HP remanufacturing.
But the most easyest way that you punch, or drill, or with soldering iron make an hole in crg, fill with toner and tape the hole.
But I recomend the Oasis whole procedure.
Jun 02, 2010 | Canon X25 Toner Cartridge for imageCLASS...
I refilled my toner cartridge and now I can't get it to print. how can i reset it? thanks
You need to reset the flag gear for the cartridge to function. I own a Cartridge World printer cartridge refilling store and I would not recommend drill and fill of this cartridge unless you absolutely don't care about the quality of your prints. This cartridge recycles toner, so you build up paper fibers in the toner which wears on the drums and blades of the cartridge to give you very decorative streaky printing. I'm sure you can find flag gear reset instructions on the internet.
Jan 23, 2010 | Brother HL-2170W Laser Printer
Where do you get refill ink for canon fax phoneL80
The Canon Faxphone L80 takes a Canon FX3 cartridge. To get the highest quality refill I would first see if there is a Cartridge World store in your area. Cartridge World stores refill most cartridges in house with American made parts. Then try Office Depot. Office Depot is the only big box store that actually "remanufactures" toner cartridges. I would not recommend cheap refills or refill kits from the internet. Many use very low quality toner that wears on parts leading to print defects or they reuse parts that already generate print defects. DO NOT buy a "compatible" cartridge, these are not refills. They are new cartridge replicas and have no recycled components.
Dec 16, 2009 | Canon FAXPHONE L80 Laser
How I can refill canon lbp2900b cartridges
Take the cartidge to any refill point he will take 200-300 and fill the cartridge without any damage to the cartridge. He will open the cartidge and refill the same.
Aug 02, 2009 | Canon LASER SHOT LBP-2900 Printer
Canon MX850 Empty Cartridge override
That code is "out of toner". I would try a genuine Canon Toner Cartridge.
Sep 24, 2008 | Canon FaxPhone L75 Plain Paper Laser
Refill Toner Cartridge for Laser Printer
Nobody has a clue how to refill a laser cartridge with ink. :)))
OK< just kidding, here it is:
First of all, laser-cartridges have toner (a fine black powder) and not ink.
Second: There are 2 methods to refill a laser cartridge: dismounting it to get to the toner chamber (involves a lot of tehnical skill) or the melt-and-pour method (see here http://www.urefilltoner.co.uk/), but you need the melting device.
But because from your question i see you dont know a thing about refilling, better go to a refill center.
Feb 14, 2008 | HP LaserJet 1012 Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
1,265 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
