Question about Twinhead DURABOOK Ruggedized Laptop 819959001699
Keyboard not working
From the 'h and over to the left and the bottom left are messing up, when i push 'h' or 'g' i get 'gh' 's' or 'z' i get 'zs' 'a' i get 'a\' 'c' i get 'c=' ' v ' or 'n' i get 'vn' 'b' or 'x' i get 'xb' 'f' i get '=f ' 'd' i get '=d' left 'shift key' i get '=' and when i press the pace bar i get ' . . . . .' i am using an on-screen keyboard right now........please help!!!!! also, there was nothing spilled on it, it was fine and thn it just started doing this.
thank-you,
s.m.
  • Anonymous Apr 14, 2008
    ayaw gumana ang ibang letters sa keyboard ko like letter c,v,b,.space bar,numlock,<,>,ESC.can you pls help me in fixing this problem.im using an external keyboard.
On my Lenovo g500 laptop many keys(gh and many) are not working, what should I do?
Connect to external usb keyboard to check. If works ok, your keyboard is defective and you should change it.
See tutorial
How to replace or remove keyboard on Lenovo G500 keyboard replacement
How to replace the keyboard of Lenovo g500 g510 g505
LENOVO G550 Keyboard Installation Replacement Guide Laptop Remove Replace...
Lenovo G580 G570 G500 G510 disassembly replacement keyboard hard disk full...
A warning: might look easy but if you are not really familiar with dismounting a laptop, you might end taking your device to a repair shp in a shoebox.
Jul 20, 2015 | Lenovo Computers & Internet
Vgn-nw150j keyboard Sony Vaio many keys stopped working all of a sudden need help?
Laptop keyboards do deteriorate from time to time. Once any key stops working, it is time for a replacement. Doing so is not difficult. Simply undo the case screws and gently separate the case to expose the keyboard. The keyboard floats inside and lays in the main board. Lift gently and pull out the small flat wire connection. The keyboard slides out and replace with a new board. Place flat cable in port on the main board, lay keyboard on top of chassis, close the top/bottom of case, tighten screws and all done. Go on line for Keyboards.
Feb 04, 2018 | Sony VAIO VGN-NW150J/S Notebook
I can't solve it no matter how I try Puzzle 69 nintendo ds blocks
Sorry, that is why they call them puzzles. All the advice I can offer you is to be persistent. You will be rewarded with the feeling of accomplishment when you succeed in finishing the puzzle.
Apr 03, 2011 | Nintendo 50 Classic Games for DS
Remove keys for cleaning sticky children
theres screw holes in the bottom of the the laptop and 2 or 3 have a "K" next to the hole. The "K" stands for KEYBOARD. undo those and then right above the "F" series of keys (F-1 F-2 F-3) etc there is 4 tabs evenly spaced out from left to right and u push them towards the monitor and the keyboard will pop right out. DON'T PULL ON THE KEYBOARD AFTER IT"S FREE!!! Its attached to the mother board by a 2inch wide electrical strap. U can undo that on the mother board side only. Be carefull it's very fragile and sensitive to humans messing with it. Installation is the reverse of these instructions. Hope it works out for you.
Mar 16, 2010 | HP Pavilion zd8000 Notebook
My left and up arrow keys don't work
Try another keyboard. If the problem is fixed then get a new one. They are really cheap now a days.
Oct 04, 2009 | Dell Dimension 2400 PC Desktop
My kramer Gutar controller for gh 3 work
try turning off the playstation and turn it back on
Jun 19, 2009 | Activision Guitar Hero Kramer Wireless...
Problemwith spacebar
If you take all those tiny screws out of the bottom of the keyboard you'll see a circuitboard with three copper "design" spots(usually 3) under the spacebar..........the ones NOT in the center of the spacebar are dirty. You could use some alcohol or acetone to clean the outside "designs".....(warning) Acetone will damage plastic!!!!!!!!
there are a lot of rubber caps that WILL fall out of place when you turn it over) (the actual keys could fall out too) (Be careful when you take off the bottom of the keyboard!!!!) Clean the ones that align with the SPACEBAR!!!! Dont touch or clean anything else that wasn't working....... Gently place the bottom back on and screw down the bottom cover with a cross pattern.....(left>right...top>bottom).....If this dosn't work....the best part is that a new keyboard........is fairly cheap....mtg
Apr 14, 2009 | Computers & Internet
Keyboard not functioning properly - ple'se ple'se help
This keyboard doesn't work on another computer? This really sounds like the keyboard is malfunctioning.Since keyboards are so cheap nowadays, why not just get another..
Mar 23, 2009 | Acer Aspire 2100 (91.AB675.D02) PC Desktop
Wireless keyboard won't work. The batteries have been left out over 24 hours
you need to push the button on the receiver the push the button on the keyboard on the bottom it is a link initiation so that they can talk to each other
May 01, 2008 | Computers & Internet
Twinhead DURABOOK Ruggedized Laptop 819959001699 Logo
59 people viewed this question
Top Twinhead Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Alun Cox
Carl Rick
Are you a Twinhead Computer and Internet Expert? Answer questions, earn points and help others
