Fixyahttps://www.fixya.com > ... > Miele
Mar 18, 2016 - How can I reset the descaling process on a Miele CVA 5060 which is stuck at 1 minute. Placed the machine on descale - Miele Coffee Makers &
Question edited for clarity.
Question moved to Miele.
This particular machine ends up on Fixya a couple of times every week!
Some Miele machines have a lever to adjust the grind coarseness. Page 27 of the manual below. I would also give it a good clean beforehand to check there is nothing in there that shouldn't be.
The descaling funnel is a small, dull red insert that replaces the capsule holder and is used during the descaling cycle. I purchased a used CVA2650 that came without the funnel. I called Miele concierge service for help. They stock the descaling funnel and sell it for $15.95. In my case, they simply mailed one at no charge without me even asking. Great customer service!
Your nozzles could be clogged or the percolator itself is clogged. Try to stick a toothpick into the nozzles to clear up any blockages, then perform a descale on the system using 2 large tablets. Make sure the tablets dissolve completely, if not you risk the chance of clogging the whole system.
The coffee system must be descaled regularly. The time period depends on the water hardness set. The appliance will display a reminder message and will eventually lock if not descaled. The message window will first display: "DESCALE AFTER COFFEES: 100". This message will appear until the appliance is descaled or locks. When the count is down to zero, the appliance will lock and the message window displays: The appliance can only be used again once descaling has been performed. Let the machine cool before descaling. Remove the sleeve of the steam nozzle to avoid damage from the descaling agent. Only use the enclosed descaling tablets for descaling. The descaling tablets are specially designed for descaling this coffee system. Other agents may damage the machine and affect the taste of the coffee and hot water. The descaling tablets can be purchased from Miele. To prevent damage to the exterior of the machine wipe up any descaling solution spills immediately! Add 2 liters of water to the water tank. Dissolve two of the enclosed descaling tablets in the water. ^ Close the water tank and insert into position. ^ Close the door. The descaling will take place in the automatic descaling program. Automatic descaling ^ Turn the program selector counterclockwise to the "Program mode" position.Press e, to select "Descaling" with the asterisk. Press ENTER.
