Top load washer spin cycle not working sound but no action
  • 247 Answers
There's a good chance that it's something as simple as the drive belt having come off.
Disconnect the power and pull the machine away from the wall a bit then tip it back a little (judge "a bit" and "a little" so the top of the machine leans against the wall without risk of it falling in either direction) and have a little peek underneath without putting your head in harm's way.
If the belt is off, you're best to replace it with a new one. Prop the front of the machine up with something secure before you try to manhandle the new belt into position.
A.
Posted on Mar 08, 2008
AGITATOR WILL NOT SPIN, WATER WILL DRAIN BUT NO SPIN
Does your motor sound like it is running in the agitate or spin cycle or is it quite? If the motor makes no sound, then you need to replace the lid switch with this part.
If you hear the motor running in the agitate or spin cycle but you don't see any action, then replace the motor coupler with this part.
Dec 25, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag Nuptune... when it reaches the spin cycle, it spins, reverses direction spins , then stops. I push the start button and once again it goes through the one spin and reverse and stops again
""when it reaches the spin cycle, it spins, reverses direction spins""
So I understand do you have the washer top raised to view this action? The wash basket rotates one rotation or are you talking about the tumblers?
If you raise the washer lid and rotate the wash basket CCW the Spin direction will it rotate CCW with very little effort?
Any dC or UC error code on fail to Spin?
If you do Spin Only Cycle do you have the same results.
I would enter Service Mode and do the Quick Spin test on page 14 of the Service Manual and see what the results are.
You can get the SM from this forum once you join.
16022808 Maytag Top Load Neptune Washer Service Manual
Oct 25, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Spin cycle won't work. Wash works OK.
sounds like motor brushes may need replacing.
Feb 17, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer fills up but doesnt start washing
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The first thing I'd do is see if the washer will continue it's cycle in a different mode. i.e. Try to start it in a different cycle, or try to move the timer knob to the spin cycle.
Following is a Whirlpool / Kenmore installation and maintenance PDF on how top load, direct drive washers work.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It has a troubleshooting section as well as detailed descriptions of how this type of washer works.
Sep 30, 2009 | Kenmore 13202 Top Load Washer
SPEED QUEEN TOP LOAD WASHER HA4011W. Motor trips at SPIN start
I would call whoever repaired the washer back out and have them diagnose.
Jan 23, 2009 | Speed Queen AWS52NW Top Load Washer
Whirlpool Washer LSR7233BQ2 Buzzes/Humms during spin cycle...no movement
No belt on your machine. Sounds like motor coupler that joins motor and transmission is broken. Very inexpensive part but a few steps involved in getting machine disassembled Look up YouTube video on replacing motor coupler on Whirlpool washer.
Sep 26, 2017 | Whirlpool LSR7333 Top Load Washer
Washer wont wash- nothing...
Remove the back panel if it has one and look for belt that is off.Before you put it back on check the pulley for any looseness.It should be tightened if you need to.I'll assist you further if you need my help. Please Rate this !!!
Sep 09, 2008 | Frigidaire GLTF1240A Front Load Washer
Maytag Neptune front load washer (top of the line)
some of the early washers had problems with a weak or faulty motor . take front panel loose and look at motor board it may look burnt on some of the resistors or look at the clear fuse at front of board it may be burnt if so use a motor/board conversion kit p#12002039.
Oct 26, 2006 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
