Question about De Dietrich DOP390 Pyrolytic Electric Single Oven
Oven Light does not turn off
The oven light on the De Dietrich DOP390 Oven will not turn off, but when you put the oven in cleaning mode it does turn off
  • 1 more comment
  • helpanyone May 20, 2008
    Same problem, oven light does not go off with any setting other than pyrolytic stttings, in addtion fan and fan element do not heat oven.
    Think from surfing that it may all be down to fan element??
    Please confirm same....
  • Anonymous Jun 04, 2008
    Bottom light stays on unless switching to pyroclean. The only thing working on the bottom oven is the grill.
  • ndes Feb 16, 2009
    I have the same problem with De Dietrich Double Oven Model No DOD 448, light on but no heat ,only the grill works, have a new lock assembly, require instructions on how to fit.
The problem is due to a faulty door switch, this is part of the door lock mechanism. The reason is that the oven thinks the door is open , this puts on the light and stops some of the oven functions ie the fan the fan element and probably the bottom element.
The answer is to fit a new door lock mechanism.
Posted on Jun 16, 2008
  • Mark Earl Apr 12, 2013
    and how do you fit that door lock mechanism. I have got a new one which I confirmed with De Dietrich was the right part but the cabling looks completely different to the original - any ideas?
I have a de Dietrich double electric oven with pyrolysis. I did a clean and now the bottom oven won't heat and fan not working. Top oven is fine, thank goodness
Many times when the self clean function is used they seem to melt connections internally . call your local repair company and have it checked out
Sep 24, 2016 | De Dietrich Ovens
Hot air blowing out at the top of De Dietrich oven, just after putting on new oven seal, fan seems ok what could it be.
Pending on the location of the oven (i.e. not where the seal is) it could be natural ventilation of the oven. Many ovens have ventilation underneath the stovetop.
Sep 02, 2015 | De Dietrich Ovens
How do I find the instructions manual for De Dietrich DOP705X Multifunction Plus Electric Built In Single Oven (DOP705X)
Go here: http://www.dedietrich.sg/sg/collections/oven.html#/others/user-manuals-10/ then look under User Manuals. Put in Model Number Collection - Cooking Range (or Product Number, if known), Available Language (EN), then download Manual in PDF
Dec 26, 2014 | De Dietrich Ovens
I got a key sign on the screen and since then I cannot operate the oven
This is telling you that the oven is locked. You will need to unlock it to use it.
Mar 18, 2011 | De Dietrich DOP390 Pyrolytic Electric...
My de dietrich oven is not heating. the light and fan are ok
If the fan is working o/k, then the oven element is most likely faulty.
This is located at the rear of the oven compartment behind a removeable cover.
Feb 28, 2011 | De Dietrich Ovens
I have a UMP 404 de dietrich oven user manual
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jul 17, 2010 | De Dietrich UMP404 Powerclean Stainless...
I need to remove an integrated oven - any advice please
The main advice is to make sure that the AC power breaker and isolation switches are off before you do anything else. Once the oven is pulled forward support it on a bench if it is up high or on a piece of wood if it is low. Then disconnect the electricty supply cable from the rear of the oven and either terminate it safely or remove it from the isolation switch.
Nov 14, 2009 | De Dietrich DOP390 Pyrolytic Electric...
Why does my De Dietrich oven trip the RCD fuse?
You need to replace the oven element, as this is what is causing the prob.
Please rate my solution.
Thanks.
Nov 06, 2009 | De Dietrich DOC310 Electric Single Oven
De Dietrich DMP502E1 oven not switching off
There is not a lot of information regarding this oven, but you may want to contact these guys. If you send them the control boards and a wiring diagram they can fix almost anything and give a great warranty: www.fixyourboard.com
Apr 15, 2009 | De Dietrich UMP404 Powerclean Stainless...
De Dietrich DOP390 Pyrolytic Electric Single Oven Logo
1,180 people viewed this question
Top De Dietrich Ovens Experts
ashburton
Shehu Pro
Shehu Pro
Electro Med Services...
Are you a De Dietrich Oven Expert? Answer questions, earn points and help others
