Question about Canon PowerShot A570 IS Digital Camera
My Powershot (A570 iS) will not power on at all. I recieved this brand new camera as a gift this year for christmas, which means it is not quite 3 months old. This camera has only been used maybe three times. I am using high quality rechargeable batteries that have been fully charged but I can't get anything, not even a sound out of this thing.
  • 9 more comments
  • Anonymous Mar 13, 2008
    Same problem bought camera (570 IS) for christmas. It will not power on Since March 7.
  • Anonymous Apr 12, 2008
    same thing
  • Anonymous Apr 23, 2008
    After two or three uses, the low battery indicator was flashing. After replacing the batteries, the camera would not power on.
  • VonRosa Aug 22, 2008
    Same problem here but
    Same here but it was a gift so can't use the waranty :(
    Any ideas anyone ?
  • lindak9196 Sep 04, 2008
    Yes, we are having the exact same problem. Ours is 16 months old and won't power on.
    Took to local camera store and they told me it would be about $150 to fix it.
    I may never buy another Canon product after this.
  • Anonymous Oct 09, 2008
    Same problem with an 10 month old A570. Sending to Canon for repair. Thanks to the gentleman below for the link.
  • Anonymous Nov 27, 2008
    same problem there a way to do a master reboot sequence?
  • chickasawed Dec 21, 2008
    I took a great photo and the camera was working perfectly but not one hour later the camera refuse to power on. Changed to brand new lithium batteries and still nothing. It's as if it doesn't know I'm hitting the on button. My camera is almost two years old.
  • sdfsd616 Dec 30, 2008
    Same problem, I wonder why is this camera so useless ?
    I only used it for like a few times and now it cannot power on with BRAND NEW batteries, fully charged.
  • Rmanner May 06, 2009
    I replaced the batteries; even removed the cr1220 battery for 30 seconds (as was recommended). The camera does not respond to the power on button.
This may sound silly, but make sure that the battery compartment is fully closed *and* that the little slider that opens it is fully retracted into the closed position. Sometimes it does not retract on its own and this can cause the camera not to power up.
If that doesn't work, carefully clean the battery contacts both inside the camera and on the lid, using isopropyl alcohol and a cotton bud.
You might also like to try *very gently* prising the battery contacts on the lid upwards slightly to ensure they are making good contact with the batteries. They do not have very much "springiness" to them.
Also make sure that the small lithium battery (inside the subcompartment next to the main batteries labelled CR1220) is present, correctly fitted and still has sufficient power.
Posted on Feb 12, 2012
Rechargeable batteries don't produce enough voltage to power the camera. I tried using them and couldn't get much life at all with an older camera, and then noticed that the rated voltage for rechargeables is 1.2 volts. New lithium batteries put out over 1.7 volts, and new alkalines put out over 1.6. I've had to ditch the rechargeables and just use lithiums to get the best life.
It's a scam that the rechargeables don't do any better than they do. All you can use them for is dim flashlights and kid's toys.
Posted on Mar 24, 2008
  • Canon Master
  • 4,738 Answers
Your camera is still under warranty. Recommend letting Canon try to correct this, instead of trying to fix this yourself.
Here's the support page for your camera:
Or you can call them directly at 1 (800) 828-4040.
Posted on Mar 08, 2008
Canon Powershot A570 IS Problem- Photos deleted when new folder was created?
I would seek professional advice, there is recovery software out there that are very good, you have tried two, if there is any chance to recover more you need to talk to someone that is experienced in these matters. Best buys may be able to help and worth a try, a camera repair store would be another option.
Apr 02, 2012 | Canon PowerShot A570 IS Digital Camera
E 18 problem
Please follow the directions found here.
Jan 07, 2008 | Canon PowerShot A570 IS Digital Camera
I'm using a Canon PowerShot A570IS, and am getting only 20 to 30 photos from fully charged Sanyo AA HR6 2000mAh batteries. I'm using the Sanyo Ni-MH quick charger that was sold along with the...
Unfortunately, this is not unusual with rechargeable batteries. The best thing you can do with a rechargeable battery is to fully and completely discharge it, and then recharge it fully. After that, there's nothing else you can do except buy a new battery. You can get brand new, unbranded ones on eBay for a fraction of branded ones, and they work great. Just buy from a seller with a good reputation, and you can't lose. I usually buy multiples and never run out of battery power this way.
Feb 18, 2011 | Canon PowerShot A570 IS Digital Camera
Canon Powershot A570 keeps showing change the batteries
I had the same problem. Here's the solution. Go into menu settings, then over to tools, select reset all at the bottom of options list. You may have to re-enter the date and time. This solved the low battery problem for me. I hope this helps.
Apr 02, 2010 | Canon PowerShot A570 IS Digital Camera
Canon A570 IS corrupted images
Go into the camera menu and find "reset"...follow the on-screen instructions. Then, format the card in the camera.(download any pics first using a card reader if necessary).
Dec 26, 2009 | Canon PowerShot A570 IS Digital Camera
Short battery life
Use the best name brand batteries you can find. Energizers and Duracell work best. Chance the size of your pictures to the smallest you can. At 300 X 300, you can still make 8 X 10 enlargements clearly. The larger the pic, the more power it takes to process it.
Aug 09, 2009 | Canon PowerShot A570 IS Digital Camera
Brand New Canon Powershot A1000 IS battery power always low
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pictures in a digital camera. Some may also have reached their shelf life, and though right out of the package may even have problems just powering startup of the camera. Digital cameras that use AA's for the most part should only be used with rechargeable NiMH batteries. If you read the camera's instruction manual concerning batteries, you may see the same recommendation.
Keep in mind rechargeable NiMH batteries will save you money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Jun 22, 2009 | Canon Powershot A1000IS Digital Camera
Battry problem
couldn't get my hands on eneloop...but this camera is power consuming....just chunk it away and get a new camera
Jun 17, 2009 | Canon PowerShot A570 IS Digital Camera
Cannon A590 "Change the batteries" after replacing new batteries
Off-the-shelf NiMH rechargeable batteries, and the special lithium nonrechargeablebatteries sold as esepcially good for camera use, don't have enough voltage output for this camera. Try using regular alkaline batteries or the rechargeables sold by the manufacturer.
Mar 27, 2009 | Canon PowerShot A570 IS Digital Camera
Canon PowerShot A570 IS Digital Camera Logo
310 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
