Question about Microsoft Xbox Console
Lost menu How do I get my original menu screen back?
    Sergeant:
    Champion:
  • 427 Answers
Try to restore the factory settings.
Posted on Mar 23, 2008
My tv is zoomed in and the remot is lost so I can't access the menu to fix it is there a way to reset the screen to normal view.
Going to need an original remote to attempt to undo this--universal will of course not work for this issue.
Apr 04, 2012 | Toshiba 19HLV87 19 in. LCD HDTV
Tip
Lost your File Menu in IE (Internet Explorer)? PC's/Laptops
Do the following to retrieve your File Menu. Lock the ToolBar instructions as well, and how to minimize and maximize (restore) your IE screen.
Alt - F. This will bring up the file menu.
Use the arrow keys to scroll over to the "View" tab.
Select Toolbars, (do not click) and move the mouse over to "Menu Bar" and click if there is not a check mark.
Once this is checked, the File Menu should stay. Close out IE and re-open to save the changes. The file menu should then remain at place. You can also "lock" the tool bar as well: Follow these same steps: this time at the bottom of the list under Toolbars: make sure the Lock ToolBar is checked. If not, if desired, click this.
Also, if this does not work, you may have accidentally hit the F11 button which maximizes the screen to "Full View". If this is the case, simply push the F11 buttom to minimize back to original size. If the screen minimizes to it's smallest view setting, simply click the box in the middle (next to X close out button), and it will Maximise the screen, but to normal size, and the file menu will remain as well. If the file menu is not there, hit F11 again, and then if still not there (making sure screen is at normal view). Follow the instructions above to retrieve the file menu.
carsandcomps,
Guru, Premium Expert @ Fixya.com
on Jul 10, 2010 | Computers & Internet
Lost remote. Must do manually on t.v. Two problems:\r\n1) I cannot get channel back on channel 3. It skips from 2 to 4. 2) TV has large black box on screen covering most of screen. I can push buttons...
Try website like Remotes.com to buy the tv original remote to used.U will used the tv original remote to turn to channel 3 with ease.After u have the tv original remote push the menu button go into Closed Captioning functions turn off like TEXT 1,2,3...The big black box will not appear on the screen again.Tv used it manually control buttons up and down channels trying to get to channel 3.U will never get it to tv channel 3 because tv channel 3 was not save on it memory list of on the tv turn manually channels buttons programming memory.Tv have a manual button said MEMU button on it tv front bazel frame?Yes.Might could used the Menu button on the tv frame to get in to turn off TEXT 1,2,3...to stop the big black box to show up on the tv screen again.
Aug 17, 2011 | Toshiba 36A50 36" TV
Lost my original clock how do i get it back
You can restore the clock using the same procedure as putting any widget on your phone.
Go to the screen where you want the clock and then do a "long press" on an empty portion of the screen. Basically hold your finger on the screen for 3-5 seconds until the widget menu appears.
- Tap Widgets (it may be under a separate menu like "Sense Widgets"
- Scroll to the widget that you want and tap to select it. If there are any customization options, they will come up now. Choose the options you want and then select Done. Your widget will now be on your screen.
You can move your widget by doing another long press on the widget and dragging it where you want it and then releasing.
Mar 06, 2011 | HTC Desire HD Cell Phone
My hisense locked and I don't have the original remote
This worked like a charm for me. I used the buttons on the side of the TV, since I've lost the original remote. Good luck! I HAD THAT SAME PROBLEM ALL YOU DO IS HOLD THE MENU BUTTON UNPLUG THE TV AND PLUG IT BACK WHILE STILL HOLDING THE MENU BUTTON GO TO GENERAL SETTINGS AND TURN ON RESET MENU ON FROM THIER AUTO SEARCH YOUR CHANELS NOW U CAN HEAR THE TV BUT BLACK SCREEN NOW UNPLUG YOUR TV FOR A FEW MINUTES PLUG IT IN AND YOUR TV SHOULD BE BACK ON THIS IS THE 3RD TIME IT HAS HAPPEND TO ME IT WORKS
Oct 25, 2010 | Hisense TL1700 17 in. LCD Television
While trying to change settings on my computer I lost the Browser bar ie. file, edit, bookmark, icon for home forward and back feature, address bar
Most probably you pressed the F11 key in the upper key row on your keyboard, and it entered "full screen" mode.
Press F11 to exit full screen mode, this should do the trick.
If this is not the case, please come back and write a comment to that effect, we'll try to assist you further.
Good luck :)
Jul 10, 2010 | Gateway MT3705 Notebook
Computer keeps rebooting at login page. It starts up by saying it has 3 of 3 updates and don't turn off the computer and it then goes to the login page for a split second before it reboots, How do I fix...
Hi, this is a common problem with a vista update, dont know why it does it, just does! When it tries to restart keep pressing the 'F8' button and you should get advanced boot options menu where you can get windows to try and repair itself to an earlier restore point, if the problem persists then I'm afraid you'll be looking at restoring back to original factory settings. Below is an extract from the Dell manual found at
http://book-lab.ru/pdf/DELL-INSPIRON/service_manual_for_DELL_Inspiron_1525.pdf
Restoring the Computer to the Default Factory Configuration
The Dell Factory Image Restore option allows you to restore your hard drive
back to its original factory configuration as when you first ordered it from
Dell. This option appears on Dell computers that were originally pre-installed
with Windows Vista® and does not include computers purchased through
the Express Upgrade promotion or computers that were upgraded to
Windows Vista from another version of Windows.
NOTICE: When you restore the computer to the default factory configuration, all
data on the C drive is deleted. Before performing this procedure, back up personal
files. If you do not back up personal files, the data is lost.
1 Restart the computer. To do this, click Start → → Restart.
2 As the computer restarts, press <F8> until the Advanced Boot Options
menu appears on the screen.
NOTE: You must press the <F8> key before the Windows logo appears on the
screen. If you press <F8> after the Windows logo appears on the screen, the
Advanced Boot Options menu will not appear on the screen. If you do not see
the Advanced Boot Options menu, restart the computer, and then repeat this
step until you see the menu on the screen.
3 Press <Down Arrow> to select Repair Your Computer on the Advanced
Boot Options menu, and then press <Enter>.
4 Specify the language settings that you want, and then click Next.
5 Log in as a user who has administrative credentials, and then click OK.
6 Click Dell Factory Image Restore.
7 In the Dell Factory Image Restore window, click Next.
8 Select the Yes, reformat hard drive and restore system software to factory
condition checkbox.
9 Click Next. The computer is restored to the default factory configuration.
When the restore operation is completed, click Finish to restart the computer.
Hope this helps!
Jun 04, 2010 | Dell Inspiron 1525 Notebook
How do you reset lost password on Nurit 8020
Power down the unit and with your right hand hold down the 1 5 9 and enter keys down. While those keys are pressed down with your left hand turn on unit it should take you to that nos loader menu. Once in the nos loader menu choose back to NOS password is 1947. Once in the NOS menu choose number 6 Service Menu
then 1 Hardware test
then 15 RAM test this will state this terminal will self destruct continue. Hit enter and it will create a new RAM disk once you see the date & time if correct hit ESCAPE if not correct D & T hit enter then put the correct info in Military time MM/DD/YY format. Hit enter and it will take you back to your main screen with the original password of MMDDYYYY that is your password.
Nov 21, 2009 | VeriFone (M19755014US1) Magnetic Card...
"ch set" appearing on screen
Need to get into the menu pages to setup the tuner. Just buy a under $10 universal remote but make sure it has a menu button.
Or - many other products that use remotes often have an option for programing it to work with other equipment.
Dec 30, 2007 | Emerson TS1997 19" TV
Microsoft Xbox Console Logo
27 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
