Question about Candy Dishwashers
Power light on but nothing happening. 2 days ago door to dishwasher started to stick and it took a lot of force to open the door
Switch on door had blowen when tested with circite tester
Posted on Mar 10, 2008
SOURCE:
Dishwasher is a whirlpool DU940QWDB3. When yu press button to start washing, lights go on but nothing happens. Where should i start trouble shooting this? Thanks
Dear Sir:
see the wiring diagram attached.
1) I recommend the switch door, if are open the machine will not close the starting relais as you will see in the diagram.
sincerely. God bless you.
May 07, 2012 | Whirlpool Dishwashers
The dishwasher won't start, its stuck, pots/pan button is blinking, & the timer has (2)_ _ bars blinking. I tried to reset/pushed the start/resume button nothing happened. I pushed the cancel/drain...
did you hold the start/resume button for at least 3 seconds if this works the dishwasher will start ok but if there is a fault it will fail again best you contact your nearest service agent good luck
Apr 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Won't start. Seemed to be working fine a day ago. Then in mid cycle I opened the door because I was on the phone and it was too noisy (normal noise). Now , I shut the door and press start and nothing...
You may have simply tripped a breaker, but if not it may be this.
This may be a faulty door switch. If you look into the door locking mechanism carefully, you can see a small plastic bulb located either to the right or left of the locking Jaw. Sometimes this switch arcs out if it is opened under load. Sometimes it just wears out or bends back if the latch is pulled too hard. Disconnect the power, unscrew the front panel of the Dishwasher, avoiding the fiberglass padding. Look near the locking jaw for 2 wires going to a switch.
Use your own judgment here now.
If you are comfortable with electricity and experienced enough, use a low amperage automotive fuse (the plastic type) 5 amps should be enough.
Slide the clips onto the fuse, then tape the exposed parts with electrical tape, and try latching the door.
If you can choose a cycle and the lights come on, you have found your problem. If not, you will likely need a technician to diagnose for you since this sounds like an electronically controlled model.
Mar 05, 2010 | KitchenAid 24 in. KUDU02FR Built-in...
Maytag Quiet Series 300 Dishwasher not working (Model MDB5601AWS)
in such cases it is always the control panel(touch panel) that needs to be replaced.it is very simple 2 chg and u could save lot of money.to chge cntrl panel ,open the door and remove all the screws around the white plastic part of door.then pull apart the inner part from outside part.the cntrol panel is held to outer panel with 4 screws.b4 that remove 2 screws holding the control board to panel.do not forget 2 unplug the unit from power b4 doing anything.
Aug 21, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Dishwasher won't do anything at all.
please give us the make and model of your dishwaser and I'll try to help.
Apr 29, 2009 | Dishwashers
Kitchenaid kudso1dlss3 clean light flashing cannot do a new cycle
I do not have the same model as you, my model is KUD01ILBS6 but I have the same problem. A service tech told me it was a error code and here is how to fix it.
1 open the dishwasher door
2 hit high temp scrub button
3 then hit energy saver dry button
4 do step 2 & 3 again
5 close the door
6 hit the cancel button
7 you can hit cancel button again then try to start your dishwasher
This works for me, you may have to do this every few months because there is a glitch in kitchenaid where if the water temp is not sensed right it will keep the dishwasher from working. It took me 3 service calls to find this out.
Jan 17, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kenmore Elite wont power on
Door switch. If the washer thinks the door is open, it won't run.
Jul 31, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Nothing is working!
UNLIKELY YOU HAVE A MAJOR PROBLEM. USE AN EXTENSION AND TRY ANOTHER PLUG AS WELL AS CHECK YOUR DOOR LATCH.CLOSE DOOR FIRMLY AS THIS CONTROLS POWER GOING TO THE VARIOUS COMPONENTS.
Aug 22, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Won't turn on
The door switch is definitely not the problem if the indicator lights are not coming on. These lights are supposed to come on when the door is open.
The problem is 1 of 3 things:
1) No power to outlet that DW is plugged into;
2) Bad connection where power cord is connected to dishwasher (see very bottom front, under kick panel)
3) Some problem internal to the DW (eg., bad switch, shorted wire, etc., )
Our SHX46A is definitely having problem 3, but Bosch's manual gives zero help. So, off to find more info online or, lastly, to call Bosch repair person. Sigh.
Jun 13, 2007 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Dishwashers Logo
96 people viewed this question
Top Candy Dishwashers Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Paul Carew
Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
