Question about Whirlpool LEQ9858P Electric Dryer
WHIRLPOOL DRYER WON'T START
I HAVE HAD THE START SWITCH TESTED. IT IS FINE. THE DRYER JUST WON'T START. I HIT THE START BUTTON AND YOU CAN HEAR IT CLICK BUT NOTHING HAPPENS. FRUSTRATING!!!!!!!
  • 2 more comments
  • ff27 Mar 13, 2008
    Dryer will not start. When I push the start button nothing happens. If I put my ear close to the timer I can hear a faint hum. Door switch and thermal fuse have both been ruled out. What is the next step? "On" switch reads 1.60 on the multimeter when I disconnect everything from it and test it. Is that switch bad? It is a 1988, should I take the hit and buy a new one?
  • whittinc Oct 01, 2008
    My dryer will start when I hit the start button but will not continue to run. I changed the door and light switch because it was bad but the dryer will not run unless I tape the start button down. Any suggestions? Thanks! And Jesus does Save.
  • Anonymous Oct 05, 2008
    same prob on my end..it will not start. Was working fine last time I used it
  • anniehoon Feb 07, 2009
    We're having the same problem. Has been working just fine... now when we push the start button, it just clicks. Can also hear the timer humming, but nothing else. Power is on, as the light comes on when you open the door. Tried replacing the Wrinkle Guard switch, which was acting up earlier, but it didn't help. Please HELP!!!
    Novelist:
  • 131 Answers
It may be as simple as a thermal fuse. Some Whirlpool dryers have power for the motor going through the theraml fuse.
Posted on Mar 10, 2008
    Problem Solver:
  • 8 Answers
Do you have power to dryer?
Posted on Mar 27, 2008
    Problem Solver:
  • 13 Answers
Test the door switch.
Posted on Feb 24, 2009
I PUT the theraml fuse. NEW STILL WON'T START
Posted on Sep 26, 2008
Dryer won't start when start button is pushed.
you might want to check the door switch , its possible when the door switch is open the unit will not start
Aug 04, 2011 | Whirlpool Inglis IP8200 Dryer
My Kenmore Dryer model # 110.65942401 will not start. The door switch seems fine. When I hold the start button in I can here the timer clicking, that's it. Any suggestions? Thanks!
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com What to Test When Whirlpool or Kenmore Dryer Won Start or Run
Apr 29, 2011 | Kenmore 659 Electric Dryer
take dryer apart and look for a reset(break belt switch) on the motor:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Dec 25, 2010 | Whirlpool LEQ9858P Electric Dryer
Hit start button but dryer will not start can hear the timer running
Open the dryer door and press the door switch , to make sure you hear a distinct " click " . If the door switch seems ok , then remove the rear dryer panel ( UNPLUG DRYER FIRST ) . On the blower housing , you will see a white 1" long piece ( thermal fuse ) with 2 wires plugged onto it . This is the piece you need to replace . #3392519 is the Whirlpool part number .
Apr 18, 2010 | Whirlpool LER5636P Electric Dryer
My dryer does not start when i hit the start button. I have checked power to the dryer, it is good. I have taken my digital multimeter, to check start button, that tested fine. I checked all connections on...
It is probably one of the limit switches inside the dryer most likely the high limit went bad and will not allow the dryer to run or the door switch could have gone bad these are two very good places to start check the door switch first and if that checks out I would check the high limit.
Jan 17, 2010 | Dryers
Dryer wont react when hit start button
HI, Sounds like Normal 0 , UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
Please let me know if this help or if I can assist you further.
Thanks
Vic
a fuse. Try this,
May 30, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Whirlpool Duet GEW9200LQ0 Dryer
can oyu oppen the door nad physically push in on the door switch( little grey switch atop the door opening). do you hear it clicking on/off??? if not you have a bad door switch.
Mar 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LEQ9858P Electric Dryer Logo
1,074 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
